Question about Plumbing
I want to restart aqua 2 34u after 10 years
It came with the house but was disused
I have an Aqua Glass Jaccuzzi that I haven't used in 10 years. The last time it was used it worked perfectly. Now I can't turn it on at all. I don't remember is just the round dial that
Check the circuit breaker and make sure you have power to the pump.
If you have power to the pump and it is not operational when the tub is full of water and you are in it then I would say you have a serious problem.
Most all of the older control that Aquaglass has used in the past have been discontinued.
You may want to visit this link and identify your control before you begin t trouble shoot your system.
Rod
US Parts Center
888-521-6183
Feb 27, 2013 | Whirlpool Safety Bath Walk In Bathtub -...
My galaxy aqua 2000 shower has started to cut out the last 2 after 10 mins. I'll turn it off n leave it for 10 mins ten turn it back on then it will happen again. I've taken the head off n
my Galaxy Aqua 2000 Electric Shower keeps running (cold water) even after swithing power OFF it used to completely shut down b4..what should I do 2 rectify the problem ...Please advise.... Thanks a bunch
Oct 18, 2012 | Galaxy Aqua 2000
I have an Aqua Pure model 268 /760 that is leaking from the base of the motor to the tank. Can this be fixed easily? I am unable to locate any manuals.
You will find a manual for the Autotrol Logix 268/760 here:
http://www.pentairwatertreatment.com/en-us/Products/Electronics/Logix+740_760.htm
Oct 01, 2010 | House Brand Aqua-Pure AP102T Whole House...
I would like to know the recommended fuel octane for my 1982 Honda VF750 S Sabre. I don't have the owner's manual and this information is not in the Clymer Service Manual. I am bringing the old bike back...
You are correct; the (minimum) recommended fuel octane rating for your bike is 91. In fact, this applies to nearly every Honda motorcycle that I can think of. Back in the 60's and 70's, Honda used to recommend an octane rating of 95 - or higher.
Oct 28, 2009 | 1982 Honda VF 750 S
Lost instruction for Thetford Aqua Kem and Aqua rinse.
Aqua Kem recommended dose: 75ml of fluid per 10 litres of waste tank capacity.
Aqua Rinse can be used daily as a toilet bowl cleaner. It will lubricate the bowl to prevent staining and once in the tank will help lubricate moving parts down there.
Jun 24, 2009 | Sport & Outdoor - Others
Could this hard drive have failed plain due to long period of disuse?
Generally drives can be left sitting for a year or more without problems but if it was bumped or jarred hard enough the heads may not be releasing from the park position, otherwise clicking sounds usually mean problems with the circuit board. If you give it a visual inspection(requires removal with a torques 5 or torques 8 bit) you can look for any signs of a burnt out circuit.
Respond back on this post if you have any further questions.
Chris
May 08, 2009 | Western Digital Caviar SE WD1600AAJS 160...
What is the diference of 12'' rought or 10''on a installation
if you have a 10" rough in your house you can not install a 12" rough toilet. but if you have a 12" rough in your house you can install a 10" rough you would just have a 2 inch gap between the toilet and the wall.
the rough is measured by measuring the middle of the sewer hole. that your toilett sits on. to the back of the wall this is important because the tank sits behind the toilet. if the tank is too big then the toilet wont fit over the sewer hole.
your house shouldnt have a 10 inch rough unless its about 90 to 100 years old most home's now days go off a 12" to 14" rough.
if you do have an old home you can order any 10" rough toilet at a plumbing supply store. or lowes. they probably wont carry them in stock though because 100 year old houses aren't very common
Nov 15, 2008 | Toto Aquia II Dual Flush Toilet
My brother is giving me an 11-year old Maytag washer which has sat in his basment for 10 years, unused. Should I expect it to work - or will I need to replace rubber washers which may have dried out due...
  • if the basement was fairly dry, and the machine is not rusted, then it should work.
  • the hoses on the inside are very thick and durable and should not be cracked or anything.
  • i would use new fill hoses.
  •  just as a precaution you can turn the timer around a couple times to loosen up the contacts in the timer.
  • also let it spin with no water in it for a few minutes, this will help the center seal (long, boring explanation on why).
Jun 30, 2008 | Maytag Washing Machines
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
