Question about JVC TH-M303 System
No sound from sub not coming on
Not coming on
The sub woofer had a distorted sound.
the distorted sound coming out of your sub-w is actually originating from your audio unit, Have your audio unit check for possible repair
Oct 31, 2015 | Audio Players & Recorders
My wireless subwoofer keep cutting off and coming back on when the music or movie is playing
Some/most Sub Woofers have a Switch that turns them Off/On/ or Auto. On Auto, the Sub only turns on when there is a signal present. ( sound coming into the Sub ) When there is no signal, the sub goes into standby mode. Wireless subs may be made to be in standby mode as the default.
Dec 21, 2014 | Audio Players & Recorders
Why is no sound coming through my Sub speakers??
Some sub-woofers need a separate amplifier. Is yours powered?
Jun 14, 2014 | Pyle PD1000A Player
I have a low red light on my amp and no sound coming out of my sub, any help please
Check the wire connections from the amp to the sub. Connect them to any other speaker instead of your sub. If you hear sound the problem is your sub. If you do not the problem is that your amp is not supplying a sound signal to your sub.
Dec 20, 2013 | Boston Acoustics GT22 Car Audio Amplifier
Light blinking and sub just sounds like a heart beat
Swap the wires of your Sub with another channel and if the same sounds comes out, you blew your sub. If a different sound, you blew a channel on your Amp
Apr 11, 2013 | Audio Players & Recorders
I have two kicker cvrs 2003 model wired at a 2 ohm load, one
Sounds like the sub is blown. Swap the two subs and see if the sound comes from the other sub in the original location as well. If not, then you have a bad sub. If the bad sound happens with both subs then you need to look at wiring and the Amp.
Mar 07, 2010 | Kicker CVR12 Car Subwoofer
Jvc 6500v no sub signal on soround sound
Hi, I had the same issue but if you change the front spk and center spk settings to "small" rather than large, the lower frequency is sent to the sub instead
Oct 11, 2008 | JVC RX-6500V Receiver
Subwoofers not getting music
looks like you need to check the SOURCE of where the signal is coming it could be that your CD car stereo SUB opt. is turn off , check the menu of SOURCE and switch to SUB on , hope this helpful
Apr 28, 2008 | Kenwood KAC-9152D Car Audio Amplifier
JVC TH-M303 System Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
