Question about Electrical Supplies
I need to replace a broken pull cord on my portable honda generator model ER400
  • jrking378 Jun 15, 2009
    I cant remove the pull cords housing it is behind the flywheel and I dont know how to remove the flywheel. Do I need a puller or does it screw off? It looks like it might thread off but I dont know how to keep the shaft from turning so I can unscrew the flywheel.
  • Anonymous Mar 21, 2014
    spring broken
  • 98 Answers
Just remove pull cords housing the rope is right ther.
Posted on Jun 15, 2009
Starter cord replacement of EF 1000IS Generator
Mentioned here and a general video
Search Results
Recoil Starter Assembly - Yamaha EF1000iS Service Manual [Page 39]
https://www.manualslib.com > ... > Inverter > EF1000iS > Service manual Yamaha EF1000iS Manual Online: Recoil Starter Assembly. ... RECOIL STARTER ASSEMBLY. 1. Install: 1. 2. Install: NOTE: Hook the edge of spiral spring to the ... Inverter Yamaha EF6300iSDE - 5500 Watt Inverter Generator Owner's Manual.
How To Replace Pull Start Cord on Honda eu2000i Generator ...
? 7:07
https://www.youtube.com/watch?v=5WAuEW8decY May 27, 2016 - Uploaded by Tula's Endless Summer
http://tulasendlesssummer.com Here is a short video on how to replace the pull cord on a Honda 2000 watt ...
Yamaha EF1000iS Service Manual Recoil Starter Assembly
May 20, 2018 | Garden
I have an old Wacker Portable Generator that when I pull the start cord, I have no resistance. It doesn't seem to be connected to the motor. How can I fix this?
It could be a few things:
1) The recoil has broken and needs replacing - remove recoil and inspect
2) the valves need adjusting - 0.015 inches on intake and exhaust, if not running right 0.020 inches for exhaust.
3) The piston rings are shot - To check remove the cylinder head and add a tablespoon of oil to the top of the piston. Leave overnight. If it disappears you need to replace the piston rings.
We also we sell parts if you need them :)
https://www.generatorguru.com Parts Spares for Generators and Small Engine Machinery
Jan 08, 2017 | Electrical Supplies
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
WHERE CAN i GET THE SPRING FOR THE PULL START ON ETQ 3000 GENERATOR
Never heard of an etq Honda generator,if is a Honda generator any Honda dealer should be able to help you. If its a Honda knock off ,some Honda springs will work.
May 30, 2014 | Honda 3000 Watt Portable Generator
Have champion 3500 watt generator recoil pull cord wont recoil HELP
need to take the recoil off the engine and check for a broken recoil spring, depending on the engine if it is a honda, they sell a replacement recoil unit, anything else and you will have to get creative....try tapping on the recoil with your palm and see if it trys to rewind, if no resistance or movement when bumping is a good indicator of a broken recoil spring....
Dec 14, 2011 | Electrical Supplies
HAVE A TRANSFER SWITCH IN MY HOME TO PLUG A PORTABLE GENERATOR TO. PROBLEM IS WORKED GREAT BUT WAS ON OTHER SIDE OF HOUSE. I HAD A 4' CORD BUT BOUGHT A 80' CORD TO PLUG INTO THE TRANSFER SWITCH NOW WHEN...
Hello, what you are not telling us is the size of the wires in the 4' cord and the 80' cord. However, you are correct in your thinking that the longer cord is cutting back on the available power that you have. Yes, if you extend the length, then the wire size in the cord has to be increased as well. To give you a size we will need to know the generator size. Having said that, an 80' cord is going to be a BIG amount of money. You might want to tell yourself how much money you are saving pulling the generator around. If you have to use the generator a lot, you might consider installing a cable to run the generator with.
joe
Feb 22, 2011 | Honda Electrical Supplies
The pull cord is locking up and wont allow it to turn over
you need to remove the front cover where the pull start Cord is and check for anything that is blocking the Cord a broken spring under the Cord wheel can cause this as well
Sep 23, 2010 | Briggs & Stratton Briggs Stratton 6200...
I have a honda generator but i change the cordon starter and now i dont now how ensable it, i need a diagrama of this
What you need to do is first remove the new cord that you installed.
(This next process is best performed by 2 people)
Pre-wind the spool gently COUNTER CLOCKWISE until the spring prevents further winding. Have the 2nd person grip the spool so that it does ot unwind. Back off the spool until the re-wind rope hole is aligned with the outer cover rope guide. Insert the new rope through the outer cover rope guide hole and into the spool hole. Pull the new rope through the spool hole and tie a single small knot. Pull the knot into the hole. 2nd person releases the spool and the rope will rewind into the re-coil assy.
Aug 04, 2010 | Honda 3000 Watt Portable Generator
My pull cord is broke. How do I thread a new one through?
unscrew the cover where the cord goes in there is a gap in the wheel where the cord is on. take old one out and make newone in. wind up the spring and test. replace cover.
Feb 10, 2010 | Coleman Powermate Premium Plus 6250W...
Honda 2000i generator need to replace power pull cord
take of cover where cord goes in watch direction and replace cord. wind up spring in right direction, test and replace cover.
Dec 09, 2009 | Electrical Supplies
Electrical Supplies Logo
520 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
