Question about Epson PLQ-20 Matrix Printer
Extension setting There no extension setting in windows xp as i can found in windows 7 under preferences setting. Please assist cause i need to change the offset setting vertical.
  • Epson Master
  • 783 Answers
HI nurul ,
Hear is your solution please read this article http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQ&oid=14426&prodoid=8252&foid=42877 Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Epson Printer Support
Posted on Mar 27, 2014
  • Nurul Amalina HAT
    Nurul Amalina HAT Mar 29, 2014
    Seem like the link you give me is for MAC OS 8.x, I'm having a problem to change the offset setting for my Windows XP.The image i attach is offset setting in Windows 7 only.
Why have ive lost the function to use the at key
Hi Diane Andrews
You stated as you have lost the @ function on your keyboard . And by looking at your DP i suppose its a laptop . Well then if so you might need to reset the keyboard layout settings for your laptop . Different OS has its different settings . You might have changed your language settings which may or might have caused it . Steps on how to its here . But if you have lost the @ key itself then ... you might need to get it change at your nearest computer repair shop or bring it to the vendor . Or maybe for time being you can use the on screen keyboard
CLick start - under the search - type On screen Keyboard and select it to use it .
Basic .. Fix an external keyboard and try if it works on that keyboard . If it does then your laptop keyboard might be at fault or need to change the settings .
Method 1 of 3: Changing the Language Settings (Windows)
If your keyboard is not displaying the correct characters when you press keys, your language settings may have gotten changed. If you have the incorrect region selected, your keyboard will act differently. To change it back, open the Control Panel.
You can access the Control Panel from the Start menu. Windows 8 users can right-click on the Windows button and select Control Panel from the menu
Open the Language settings. How you access this depends on which version of Windows you are using.
Windows 8 - If you are in Category mode, select "Change input methods" under the "Clock, Language, and Region" section. If you are in Icon mode, select "Languages".
Windows Vista and 7 - If you are in Category mode, select "Change keyboards and other input methods" under the "Clock, Language, and Region" section. If you are in Icon mode, select "Region and Language" and then click the "Keyboards and Languages" tab. Click the Change keyboards... button.
Windows XP - select "Regional and Language Options", click the Languages tab, and then click Details..
Select your language. Use the menu to select the default input language you want to use. In Windows Vista and 7, select your preferred language from the "Default input language" drop-down menu. In Windows 8, move your preferred input language to the top of the list.
Sep 15, 2014 | Acer C7 Chromebook
How can I un-hybernate asus eee pc 1215n?
Just go to Control Panel and look for Power Options.
For windows XP:
Uncheck box that says hiberbate under Hiberbate tab.
For windows Vista and 7:
Click the "Change plan settings" options and customize it on your preferences. You have the option to set Sleep to "Never". You can also click "Change advanced power settings" for more options.
Hope this helps.
Jun 20, 2011 | ASUS Eee 1215N-PU17-SL Notebook
Describe how to change printer to print only black from my computer. I am out of color ink and don't know how to change the settings from my computer.
Unfortunately, you need both ink cartridges to print with this printer.
you can print grayscale (black/white) by:
This for XP:
Start
Settings
Printers and faxes
Right click the printer icon an select printer preferences
Click the color tab and select grayscale
Windows 7:
Start
Devices and Printers
Select printer preferences
Select features tab
Scroll down and add a dot to grayscale
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 18, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do I change from colour to black and white on HP930c. NO jargon please I am an oldie Thanks
Hi and welcome barry_nel450 !
Under Windows 7:
Select the file you want to print and click on " print " . A window opens : click on " preferences " \
" features " " print in gray scale " . Click now on the arrow next to" high quality" and select
" black ink only " .
Under Windows XP :
"paper/qulity " and check " black and white " .
Don't forget to click on " apply " when done in both cases !
Best regards ,
Fanaudi .
Feb 16, 2011 | HP DeskJet 930c InkJet Printer
When switcthing on my Advent netbook it comes up with the error message Windows Boot Manager Windows Falied to Start. A recent hardware or software change might be the cause. To fix the problem: 1....
Hi sioban_bros,
Based on your situation. I suggest trying the following steps:
1. restart the computer and keep pressing F8; Use Last Known Good Configuration.
2.If the issue still occurs after that, I suggest testing if we can boot from a Windows XP disk. If so, please install Windows XP on another partition and access your important data.
3. After backing up those data, you can use Windows XP disk to format the drive and reinstall your preferred operating system.
4. However, if we cannot boot from a Windows XP disk, the issue can be caused by incorrect BIOS settings or damaged hardware. I recommend contacting your computer manufacturer to check BIOS and hardware.
To access the data on the drive, you can try to install the hard drive on another computer.
Hope it helps.
Please rate this solution if found useful.
Best regards,
Reyjoshua07
Jan 17, 2011 | Advent Netbook
How do I enlarge the screen to fill the monitor
You can resolve this by checking your computers resolution. How you do this depends on the operating system (ie. XP, vista, Windows 7). In windows XP, click start-->control panel--> display...then under the settings tab you should see a resolution slider. Change that setting to your desired preference. If you are using windows 7 or vista, you can right click on a blank space on your desktop and click "Screen Resolution" . If screen resolution does not exist, just click on "Personalize" and change the resolution settings from there.
Hope this helps
Aug 26, 2010 | Dell Computers & Internet
Laptop running XP desires to connect to desktop running windows 7-driver needed for HP 2840 color laserjet before connection to windows 7 desktop-is driver put on laptop or desktop
There is no driver for win 7, although if you are running on windows 7 32bit there is a work around. Download the software for windows vista 32 bit for the 2840.
Jul 13, 2010 | HP LaserJet 2840 All-In-One Printer
I have a hp pavilion 2120tx with windows 7 and i want to dual boot windows 7 and windows xp [windows 7 first]
You can create a Dual Boot in ur machine....
C: XP
D: or E: or F: as Win7
You need to re-format your disk, back up all critical data in your disk....
once done...boot with XP disk in CD drive....
after format, create multiple partitions....C: , D: , E: etc as per your preference
install XP in C:
once done...start PC and let the machine boot from C: XP...once you get Desktop in XP
install Win7 in D: or E: as prefered....once done..
in the startup screen you will get these 2 options
1 load earlier version of Windows
2 Windows 7
to make Win7 as default, right click on My computer (Win7), Properties / Advancd System Settings / Advanced Tab / Startup and Recovery / Under System Startup - Chose the Default OS by the down arrow and the time to it must be displayed in the startup to chose the OS....by this method you can chose Win7 or Xp to load...make your choice as prefered...
reg
for more info on formating and loading OS visit my site
www.sureshayyar.110mb.com
May 08, 2010 | Computers & Internet
Remove..administrator
HI!, I had met the headache things that I had forgotten Windows login password. The login screen rejected my passwords. I was frustrated because there was very important data on my disk and I couldn't reinstall the OS. ............. However, I fortunately got to know the Windows Password Recovery Tools below .
1. Windows Password Recovery Tool 3.0( http://www.windowspasswordsrecovery.com )
2. Windows Password Key 8.0( http://www.lostwindowspassword.com )
3. Windows Password Recovery 6.0( http://www.recoverlostpassword.com/products/windowspasswordrecoery.html )
4. Any Windows Password Reset 7 ( http://www.windowspasswordreset.net )
5. Windows 7 Password ( http://www.windows7password.net )
6. windows password cracker ( http://www.windowspasswordcracker.com )
I compare these tools and try the first one, it help me to recover my forgotten windows xp password in only five minutes.
May 04, 2010 | Apple MacBook PC Notebook
In my Paint Shop Pro 7 program, my photos show in color. However, when I go to print preview, they are shown in grayscale. If I print them on either of my two printers, they come out in grayscale. I do...
its possible that in your printing preferences you have black and white selected. you can also try reinstalling the drivers for your printers, first uninstall them and then install the drivers again preferably newest drivers from the makers website.
Oct 20, 2008 | Computers & Internet
Epson PLQ-20 Matrix Printer Logo
43 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
