Question about Sony Cyber-shot DSC-HX20V 18.2 MP 20x Optical Zoom Ultrazoom Camera 8GB
Replace protection glass on sony hx20v
Protection glass is mottled. rear case is cracked
Dsc-hx20v only takes one photo
You have a memory card in? Formatted? Not full?
Sep 04, 2014 | Sony Cyber-shot DSC-HX20V 18.2 MP 20x...
How can I remove dust from the lenses?
I checked the web and there seem to be a few people experiencing dust issues with the Sony Cyber-shot DSC-HX20V. Perhaps a strongly worded letter or email to their customer service might help, citing the fact that there are others with the same problem. Dust will get onto a camera's image sensor (DSLRs are subject to this - changing lenses and exposing the sensor), although with a fixed lens camera, I would think (do not know) that dust issues should be minimized. Anyway, best of luck!
May 09, 2014 | Sony Cyber-shot DSC-HX20V 18.2 MP 20x...
Mottled background
Sounds like you may need a new lamp according to my Samsung DLP manual for a HLR4667W.
"Why do I need to replace the lamp?
The lamp used in a DLP TV has a limited lifespan. For the best screen quality it needs to be
replaced periodically. After replacing the lamp, the screen quality will be bright and clear as new."
Nov 12, 2013 | Samsung HLP4663W 46" Rear Projection HDTV
How do you change the language on a Sony DSC-HX20V digital camera from French to English
Press the MENU button. Select the toolbox icon, then select the wrench-and-hammer icon. Select the third item on the menu.
Jul 18, 2012 | Sony Cyber-shot DSC-HX20V 18.2 MP 20x...
Vtech Mobigo screen cracked can it be repaired?
If this device is still working however the crack is small or not deep enough to affect the picture quality of the device, buy a cheap glass repair kit. This will not only fill the crack but ensure the glass stays protected and will look new. Also, after using the repair kit, be sure to use a anti-glare shied to further protect the screen.
If the screen is cracked to a point where the image is blurred, distorted or the colours are not accuratly displayed, unfortunately the glass will not be able to fix without speacialty parts specific to that device. If this is the case, I suggest you visit the site provided at the bottom and follow the steps indicated on the page.
Glass repair kit and demo:
http://www.youtube.com/watch?v=1FwIC7-bttk
http://www.amazon.com/Fix-Flat-Windshield-Do-Yourself/dp/B000EA5WLS
Replacement Parts:
http://www.vtechkids.com/support_replacement.cfm
Hope this helps. Good Luck!
Mar 13, 2011 | Vtech MobiGo Touch Learning System - Blue
Where can I get a replacement plactic screen cover
This set has 3 screens---the outer one is really only for glare--clear plexigalss--no longer available from Sony.
Sony 4-070-602-01
SCREEN, FRESNEL Sony 4-064-343-11
SCREEN, LENTICULAR Sony 4-058-894-11
SCREEN, PROTECTION (CONTRAST)Outer one is (Contrast) the other two inner ones are showing as available and about 180 each.
You would have to either have someone dismantle or do it yourself---most of these sets you have to remove all three screens from the rear of the set---then remove the outer contrast one if it is scratched or cracked--
If you get it out and measure it: It is possible you may be able to find a company who can cut you a plexi-glass piece to replace it with--lots of work to do this and you have to use extreme care when you remove the two inner screens--easy to damage them---Usually the inner two are taped along all the edges to keep dust etc from getting between them and the front one is a short distance forward of them.
The front protective screen is really only there for glare and to protect the inner screens from damage---I have seen people who had a cracked outer one just dismantle and remove that one---put the others back and use the set that way---have to be careful as the inner screens are easy to scratch or damage with the outer one removed.
Also---I have seen several where someone removed the outer one and got a piece of plexi glass big enough to put on the outside of the front of the set---secured all around the edges with velcro--does not look as good as the original but prevents glare and protects the inner screens.
If this told you something you did not know or helped you rate this solution as I do this here for free.
SD TECH
Jan 03, 2010 | Sony KP-53V80 53" Rear Projection...
I have an aqualand duplex and the protective glass is
HI
So is the glass cracked? or do you have an watch protector on it which is broken (usually a rubbery type protector which slips on over the glass)?
Kind Regards
Shenlun
Jul 12, 2009 | Citizen Aqualand Duplex JP104009E Wrist...
CRACKED SCREEN
this might possess giving an arm and leg for new screen glass there might be a way to fix it and its a long shot
glass repair for auto mobiles that little filler they use for cracks is what i can suggest off hand
i hope this can be of use
May 07, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony Cyber-shot DSC-HX20V 18.2 MP 20x Optical Zoom Ultrazoom Camera 8GB Logo
21 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
