Question about Konica Minolta Office Equipment & Supplies
Where is sensor for universal tray - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,696 Answers
Depend on the model##############################
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 14, 2016
Solve the plroblem in di 620
The 13xx - printer engine malfunctions
13F0 -400 dpi SOS sensor detection failure.
13F1 -600 dpi SOS detection failure.
13F2-universal tray adjustment failure maximum.
13F3-universal tray adjustment failure minimum
13F4-optical system out of adjustment
Dec 15, 2013 | Minolta DiALTA Di520 Laser Printer
My minolta copier ep3010 espro universal tray and A3 tray are no longer working and my toner cup doesn't supply toner any more to my developer unit I have to be doing it manually, its showing error...
NEED to have the developer replaced. try the web site below they mite have. also the counter need to cleared before replacing the developer and the F8 functions need to be run once the new developer is replaced. As for the trays do you have small wrench Icon at the lower left of the control panel if you do touch it, it will send you to another screen when the second screen shows up open close the front door to reset the 0900 series codes
Jun 25, 2011 | Minolta Office Equipment & Supplies
Hello, My daughter was printing off her university notes perfectly tonight and all of a sudden my Samsung SCK - 1400 printer stopped printing and said [No Paper] Add Paper. So I added the paper and i...
there is a paper sensor in a paper tray where you put papers just near the pick up roller kindly check it out that it actuates when you put papers in it
Jan 20, 2011 | Office Equipment & Supplies
Hello We have a HPLj3005n printer and it keeps asking wich tray t oselect when I try to print, the paer is in tray2 and tray2 is selected in all the settings. After I push the confim button a few times...
The manufacturer recommends you install the universal driver from HP website. The wrong driver can cause the messing up of the paper tray selection. We had the right driver for our printer installed and the support guy told us to put the universal driver on.
So, here's a link to the universal driver PCL6 and PostScript. If you have 64 bit computers on your network then you will have to put the 64 bit universal drivers too (PCL6 and PostScript).
Dec 10, 2010 | HP LaserJet P3005n Printer
We have a Canon ImageRunner 8500 and we get this error code E000542 0003. How do we fix it?
In this case the finisher motor or motor sensor does not work properly. AS SM Main cause - The tray B lift motor (M12) is faulty. The tray B idle rotation sensor (PI18) is faulty. The tray B lower limit sensor (PI24) is faulty. The tray B paper sensor (PI17) is faulty. Main cause The tray B lift motor (M12) is faulty. The tray B idle rotation sensor (PI18) is faulty. The tray B lower limit sensor (PI24) is faulty. The tray B paper sensor (PI17) is faulty. Try operating copier without finisher or contact an technician to repair finisher.
Jun 10, 2009 | Canon imageRUNNER 8500 Copier
- "No cassette with paper of size requested ...
One of the cassettes is usually universal, if they tray has moving edge guides, the put in the paper you need and adjust the guides.
If the paper needed is in the cassette and you still get the message then the document feeder sensors are miss reading your original size, thy cleaning out the document feeder with a vacuum or compressed air, especially around the paper sensors..
Hope this is of some help
Ed
May 26, 2009 | Toshiba e-Studio163 Copier
I have a T620 that won't print from the trays because it continues to show ''Load MP tray'' on the display. When I drop down the tray and load the multi-purpose feeder, it will print what's in the queue....
Turns out that the paper tray was damaged - the tray was unable to determine the correct paper size, despite fooling with the green paper stop. I had to compare it with a known-good tray to see the problem.
Apr 28, 2009 | Lexmark Optra T620 Laser Printer
BizHub 450 Universal tray won't pick up paper
Sounds like either a loose drive connection or there is some trace piece of paper still left in the device.
BNe sure not to overload or UNDERload the tray as well.
Aug 25, 2008 | Konica Minolta bizhub C450P Laser Printer
18 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
