Question about Canon imageCLASS MF6550 All-In-One Laser Printer
Wont make copies
Won't make copies
Sony rdr dvd recorder / vcr combo.... I put a instructional video and the dvd won't go past the copy write warning.
have you checked the cd for deep scratches because i had a dirt bike game that did the same thing
Mar 05, 2013 | Sony RDR-VX525 DVD Recorder/VCR
Kodak dc 200 says wont download in use drivers wont download
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 29, 2012 | Kodak EasyShare DX4530 Digital Camera
My d5000 wont tranfer pics to camera. bought new computer cord for camera and still wont work
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa or Nikon Transfer.
Apr 30, 2012 | Cameras
Wont to view pic on CX7300 on my PC
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery and Picasa.
Jan 23, 2012 | Kodak Cameras
My hp pavilion 522a i cant log in to it because it keeps coming up with this copy of windows must be activated with microsoft before you can log on. do you want to activate it no. and no mater what i do it...
You need to activate it, no way around it. When installed you have 30 days to activate it or it won't let you log on.
There should be a a choice to activate and it will only let you go to a activation window. You can do it over the net in a few seconds. After it is done it should work normally. If it is a valid installation you will click a few buttons and you are done. If there is a issue with a valid serial number ie your buddy gave you a copy then you won't be able to activate it (easily anyway) and need to get a new copy to install.
You may need to log on on under administrator before it takes you to the activation stuff but that depends on the windows version and so on.
Once you get it activated you won't forget and the next new computer you will probably get it activated after it runs for a few minutes to avoid this again. It's annoying, it's Windows! ;-]
Sep 01, 2011 | Computers & Internet
Printer won't let me photo copy anything
have you checked ink supply. wont copy if there isn't ink
Aug 25, 2011 | Office Equipment & Supplies
MY USB ON MY VPC-5580SANYO CAMERA WONT LET ME UPLOAD PICS ON MY PC I THINK I NEED A NEW WHERE CAN I GET ONE..
Consider NOT using the USB connection.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Even if you have to buy a card reader, it won't cost any more than a USB cable.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Mar 16, 2011 | Sanyo VPC-S880 Digital Camera
My fujifilm finepix j30 wont upload pictures,it will show the page but wont upload any pictures
Aug 04, 2010 | Fuji FinePix J10 Digital Camera
PowerShot SD1100 IS Digital Camera: sd1100 wont connect to mac...
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
May 17, 2010 | Canon PowerShot SD1100 IS Digital Camera
Copier wont work
true, the l error codes ar efor the laser l6-00 is the polygon motor, you should change this if you know how to, you need to take a lot apart
Oct 30, 2007 | Sharp AR-5320 Black and White Copier
Canon imageCLASS MF6550 All-In-One Laser Printer Logo
24 people viewed this question
old marine
old marine
