Question about True GDM-12 Refrigerator Commercial
Cooler not getting cold
My true GDM -12 cooler is no longer getting cold. I only hear the fans running, when I use to hear everything. It is also blowing warm air, how do I determine if I need Freon and if the compressor is working
    Problem Solver:
  • 21 Answers
By not hearing anything but the fans I would have to say the compressor is not running. Pull the cover off so you can access the condenser area where the coil and compressor are located. Check the coil and ad make sure it is clean. Then feel the compressor and find out if the compressor is hot. If it is hot and the coil is dirty/dusty I would say it was going off on high head pressure/temperature. Clean the coil and let the unit sit off for a while and then try running it. If it is cool then it may have an issue with the refrigerant or other things like maybe start componenets.
Posted on Apr 12, 2014
SOURCE: True Refrigeration GDM-26 Compressor problem?
More than likely you need a new compressor. It sounds like it's trying to start and then trips on it's overload or capacitor may be out.
Posted on Sep 13, 2008
  • 400 Answers
SOURCE: I have a true GDM-12FC floral cooler that the
You have not said if the cooler is cooling to the correct temperature or achieving the setpoint. Make sure that the correct thermostat has been supplied. Also that the sensor has been installed in the correct location. If all of the above is correct, then I would have the refrigerant level checked.
Posted on Mar 09, 2009
SOURCE: Fan works, just stopped cooling TRUE GDM 26
there is a leak of gas in the system,must see where the leak is, repair it then fill the gas,
Posted on Aug 21, 2009
  • 88 Answers
SOURCE: Tru GDM-47 cooler evaporator icing up.
possible bad defrost timer,or control on an off is bad,were you adjust temperature...thermostat from 30 to 65.00 dollars....possible there is leak or unit is under or overcharged..more than likely under charged...possible defrost heater is not working...good luck..michael doctor airr appl.repair..service tech..843-384-8474...call if need additional help ..its free..
Posted on Mar 27, 2010
  • 266 Answers
SOURCE: i have a true brand
Either the compressor is going bad or the start relay on the compressor is going bad. The relay is under the plastic cap on the compressor it will be a nickle size round disc with one wire hooked to one of the 3 prongs coming out of the compressor. This is what you hear click. But to be honest normally this points to a bad compressor and then its time for a new fridge. Hate to give bad news good luck
Posted on Aug 15, 2010
How do i chage the temperature on a true cooler gdm 49 florial cooler
True GDM-12 Refrigerator... Repair Questions - Fixya
www.fixya.com/support/p22955-true_gdm_12_refrigerator_commercial
Recent True GDM-12 Refrigerator Commercial questions, problems & answers. ...Where is the temp control on the older (14 yrs or so) on GMD-12? True ..
Aug 16, 2014 | True GDM-12 Refrigerator Commercial
Noisy compressor?
My Gdm 12 was doing the very same thing. Remove the from grill plate by taking out the 4 screws below the door. This will expose the compressor mounting plate . While the compressor is running, and is at its loudest, loosen or tighten the two front hold down bolts until the noise goes away. Most likely, when you cooler was moved or transported off the shipping pallet, it was bent slightly allowing contact between the bottom of the compressor, and the mounting plate. Hope this helps.
Feb 03, 2014 | True GDM-12 Refrigerator Commercial
Cooler just stopped getting cold
Can you hear compressor running? Any airflow at the compressor? Might need a start kit. Call someone if your not handy at electrical.
Aug 13, 2013 | True GDM-12 Refrigerator Commercial
I have a coca cola cooler and it keeps running is that normal
same question as is on your post I have coke machine GDM-23 or AE44OA it keeps running and gets a frost build up on tube at top
Jul 11, 2012 | True GDM-12 Refrigerator Commercial
I have a True Cooler GDM-35SL-RF. the fans are not working but the compressor is. What can I do to fix this and where on the cooler would I find the problem?
They have a support line here:
http://www.truemfg.com/24HourTech_en.aspx?language_id=1&event_id=401&from=food
Our Technical Service department is available via Internet or phone
Monday - Friday 7:30 AM - 5:30 PM CST and on Saturday 8:00 AM - 12:00 PM CST.
Via phone please call 1-800-325-6152 and ask for the Service Department
You can also use the page to ask any questions. I suspect you have a fan relay that has failed as the fans should be running anytime the compressor is running. Since all of the fans are not running that leads me to think it is a relay problem.
One thing to need to make sure is to verify that all fans.. condenser (bottom of the unit) and evaporator (inside the unit) fans are not running. If the condenser fan bottom of the unit is running and the evaportar fans are not running it could be something as simple as a door switch that has failed. Call them during business hours and I am sure they will tell you what the remedy is.... and of course.. do their very best to ensure they get to send a repair tech your way.
Thanks for choosing FixYa,
Kelly
Sep 04, 2011 | True 72 cu. ft. / 2039 liter Commercial...
Cooler gets to cold
Try cleaning the condenser coil.
Jul 07, 2010 | True GDM-69 Refrigerator
I have a True GDM-26. The contents get cool inside but not cold. The temperature dial is set at the coldest setting. Also, there is a lot of condensation on the bottles inside the cooler. Any...
I have same problem was told condensing fan not working properly. Easy to see if this is the problem, take out guard in front of machine and put a fan blowing into it. I went to home depot and bought a tornado fan and it cools again. Now if I can only figure out if its the fan or whatever contros its speed. If anyone knows how to check please respond.
Nov 24, 2009 | True GDM-26 Refrigerator
Commercial TRUE GDM soda machine
If the cooler has power, the condesor fan (bottom) and evaporator fan (top) are spinning put your hand on the compressor. Do you feel a vibration? if so, you probably have a refrigerant leak. If not (if its clicking or nothing at all) its a compressor issue.
Dec 05, 2008 | True GDM-12 Refrigerator Commercial
I have a True GDM 33 model is it possible tochange the temperatur
If your cooler is constantly running too cold the thermostat is probably bad. I can hook yu up with a thermostat. ;) www.northeastcooling.com
Nov 18, 2008 | True GDM-33-SSL-54 Refrigerator
More than likely you need a new compressor. It sounds like it's trying to start and then trips on it's "Klixon" overload. Call a commercial refer guy (not somebodys brother in law that works on A/C, it's NOT the same!)
Jul 15, 2008 | True GDM-26 Refrigerator
True GDM-12 Refrigerator Commercial Logo
315 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
