Question about Bvlgari Bulgari 4045B/V 5138 eyeglasses size 52mm : Black
Round full face, want a rectangle shape pair of eyeglasses black color 56mm lens width
Black color frame
How to find the right eyeglass frames for your face shape?
I've worn spectacles for the last 51 years. I've always used a looking-glass.
Feb 20, 2015 | Cameras
Tip
Identifying Your Reebok / Robix Studio Cycle
  • 9600
    Black matte finish on 1-piece welded frame. Black crank arms (generally) and dual brake pads.
  • 9800
    Black matte finish on 1-piece welded frame. Black crank arms (generally) and single brake pad.
  • 9900
    Glossy finishes w/angled back legs (stabilizer). Bolt-together frame (assembly required). Rectangle shaped stabilizers.
  • 2000B
    Glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and single brake pad. Silver crank arms and belt driven.
  • 2000C
    Glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and single brake pad. Black crank arms and chain driven.
  • 3000B Robix
    Black glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and frame down tube. Belt driven with single brake pad.
http://www.sportsmith.net/Categories.aspx?did=CEF96124-843A-4128-9B53-8E10980C9920
on Mar 11, 2015 | Exercise & Fitness
Tip
Sunglasses for Your Face Shape: 5 Tips to Help You Buy Sunglasses.1. Wear only...
Sunglasses for Your Face Shape: 5 Tips to Help You Buy Sunglasses.1. Wear only small sunglasses if you have a small face, and big sunglasses if you have a big face!<br />2. The frame shape must be in contrast with your face shape: If you have round face wear square sunglasses, if have a square face wear round sunglasses!<br />3. If you can't determine your face shape, you can always buy Aviator Sunglasses that matches every face shape!<br />4. Be careful! If though oversized sunglasses are in trend, the frames shouldn't be over your face contour!<br />5. Don't choose frames that are "too cool for you", just because they look good! They will remain in your drawer. Or, you'll have to buy yourself a new wardrobe leaving a hole in your budget, that will not perfectly synchronize with your summer vacations
on Nov 07, 2010 | Clothing Accessories
I want to know what sizes is the frame of the versace VE 4157, as in the outer edges of the frame horizontally, i reference whit the width of the face,
Frame Size: 65MM 17MM 125MM
Typically there will be three standard numbers imprinted on one of the temples or the bridge, indicating respectively the sizes of three frame parts. All sizes are marked in millimeter.
1. Lens size: The first number 65 represents the lens size, which is also called eye size or lens width. Lens width is the most exact name of this size, describing precisely the distance between the vertical sides of a rectangle containing the lens shape. It is important to differentiate it from lens height. A large lens for a big guy usually has big sizes at both dimensions.
2. Bridge length: The second number 17 represents the bridge size. Other sayings include bridge length and bridge width. In detail, it is the minimum horizontal distance between the nasal surfaces of the rims. This size varies only slightly because people's noses will hardly differ significantly. When the frame is sitting too high on the face, it is necessary to increase this bridge size. In opposite, a shorter bridge is needed when the frame sits too low on the face.
3. Arm length: The third number 1125 describes the length of an arm or temple. This is the whole length of a temple, consisting of the length to the bend and the length of the drop.
Jul 18, 2011 | Versace VE 4157 Sunglasses
Tip
Purchasing sunglasses for round faces
This facial type is easy to spot as the face is completely rounded within minimal check-bone edges and the face is circular. Buy a pair of sunglasses that makes your face appear to be longer. A larger plastic square type frame suits this face very well. The large plastic square frames add some angle to the face and really help balance the face out.
How to Buy Fashion Sunglasses that are perfect for my face?
First of all, determine Your Face Shape.The right ones will looking flattering on you by balancing out the shape -- creating a proportional and visually pleasing face shape. Like for example, if you have a wide jaw, wide forehead, round face, long face, etc., the wrong frames will only highlight that.
Second, Decide What Complements Your Face Shape Best
Two rules of thumb when choosing sunglasses for your face shape are:
1) Wear a pair that are of the same size of your face, and
2) Choose a pair with frames that contrast with the shape of your face and facial features
Pay Close Attention to Your Facial Features - you have strong features (strong chin, prominent nose etc.), choose a pair that softens them. Or if you have delicate features ( like a short nose, rounded jaw etc.), choose a shape opposite from it to visually sharpen them a little.
How could I know which sunglass suites me?
Well, here are some advices on how to match your sunglass to your face: 1. Suare face: Most complimentary style of sunglasses for a square face: To minimize the width of the face, it is best to choose sunglasses that add length. This can be best achieved by buying sunglasses that are not as wide as the widest part of your face. It is also a good idea to soften the "squareness" of a face by more fluid, rounded style frames, so as to decrease the perception of a broad jaw line. 2.Oval face-Most complimentary style of sunglasses for an oval shaped face: Generally any type of sunglasses suits an oval face, but just make sure that the size of the frame is proportionate to the face. 3.Round face: Most complimentary style of sunglasses for round shaped face: To sharpen a round face, select frames with straight or angular lines that will help make the face look thinner and longer.
4.Diamond face:Most complimentary style of sunglasses for a diamond shape face: Glasses that are oval, shaped or rimless are very complimentary for this type of face.
5. Rectagle face-Most complimentary style of sunglasses for squar shaped face: To compliment this style of face, it is best to choose sunglasses that will shorten the face and widen the face, both at the same time. The best style of frame to choose is one that is round, or deep to help soften the face.
6.Triangle face-Most complimentary style of sunglasses for a Base-Down Triangle face: To compliment this style of face, it is best to emphasis the top part of your face with strong balancing frames. 7.Inverted triangle-Most complimentary style of sunglasses for an inverted triangle face: Choose a type of frame that balances your face and broadens the lower part of your face. Low temples and rimless style of sunglasses are a good style to consider.
What kind of sunglass frame should I choose for my square face?
If you have an equally strong forehead and jaw line that match the sides of your face you have a square face.
The very best frame shape for you is an oval or round shape that will help soften and minimize your jaw line. Look for larger oval or round frames if you have a larger face, and smaller frames if your face is smaller.
Some great frames for your face type include the Dragon Spree, Coach Lindsay, Julbo Colorado and Drus, and the Ralph Lauren 876/S. You should be able to find just the right frame to fit your face and your budget!
How can I measure a sunglasses frame?
A frame has 4 basic frame sizes.1. Eye Size - refers to the horizontal width in millimeters of one of the frame's lenses.
2.Bridge Size - measurement is the distance in millimeters between the two lenses. It is measured between the two closest points of the two lenses.
3.Temple Size - is measured along the length of the temple, from one end to the other, including the bend.
4.Vertical Size (B) - refers to the vertical height of an eyeglasses lens, and is measured from the tip to the bottom of the lens aperture of the frame. The measurements are taken from a horizontal line intersecting with the top of the lens, to the horizontal line intersecting with the bottom edge of the lens. The B measurement is only important when ordering multifocal lenses; follow this link to read more about progressive lenses.
Bvlgari Bulgari 4045B/V 5138 eyeglasses size 52mm : Black Logo
24 people viewed this question
Top Bvlgari Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Bvlgari Health and Beauty Expert? Answer questions, earn points and help others
