Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
My viera panasonic plasma television screen keeps going black/off
I have a viera panasonic plasma television. The screen is perfect for about 20 minutes then the screen goes black. The green light stays on and only flashes when i try to restart the tv. After 5 mins the tv will turn on but the screen soon returns to black.
SOURCE: Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
Posted on Oct 31, 2007
SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
Puzzler.
  • 330 Answers
SOURCE: my panasonic tv got problem
when it is warm, shut off, then after take a rest it will automatic on again, probably you need change the on anf off switch.
How long have you had the TV?
Posted on Jul 10, 2008
SOURCE: installing wii to panasonic viera 50'' plasma
I could resolve the issue. First of all, the wire supplied with the wii is not compatible with your TV. This 3 point connector, will end up giving you b/w screen. So you need to buy the 5 pin connector. I bought from Frys for $19.99. The box says "High Performance Component HD A / V Cable" (like this one: http://www.bizrate.com/wii-accessories/oid875654433.html )
In any case, do below
1> find the 5 point input row (vertical) on the back of your TV.
2> Insert the connector, in the sequence of Red pin being the bottom most. If its 5 pin connector, then start from the lowest point on the back of TV. If its 3 pin connector, use the top 3 points, on back of your TV. Red always being the bottom most in sequence.
Once again, buy the 5 pin connector, as inserting these pins on the back of your TV when the TV is already mounted on wall, is the hardest part to do...so why to waste your enerty in doing again and again. I am sure you would not like the black & white screen coming with 3 pin connector.
Posted on Dec 27, 2008
rockitman187
  • 2559 Answers
SOURCE: Panasonic Viera Closed Captions HELP
Just use he remote and push the cc button or the display button until cc off appears on the screen
Posted on Jul 29, 2009
My 58 inch Viera has ghosted black lines radomly appearing after being on for 20 to 30 minutes. Where should I start.
It should be due to its Y-Sustain and drive boards. Just enter this site named 'Electro-help'. You can see so many problems that can occur with Panasonic plasma TVs and description related faulty boards . Try this link and select the site. Pull up older posts there.
Jul 18, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
The pictures are mostly green - like instead of black it shows green
It's called Cyan and it's sound like you are having a problem on your D-board. Look for capacitors bulging out and replace first if not then order D-board
May 01, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I am having a problem with my picture on the top
NEED REPLACED SU BOARD Manufacturer Panasonic Part Number TXNSU1HNTU Description PC BOARD
Feb 17, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
Black strip down the right hand side on my viera plasma
Hello
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
Angel
Thanks...
Aug 02, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Iwas watching my panasonic plasma and the screen went green.
One of the "Y" buffer boards have failed. The buffer boards are located on the left side of the set looking from the back. There are two of them. One for the upper half of the screen, one for the lower. Disconnect and replace the one that had the blank portion of the screen.
May 20, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic Viera TH-50PZ80U No sound no audio only buzz.
Found the screen had a small crack and was shorting the video circuit.
Jan 03, 2009 | Panasonic Viera TH-50PZ85U Plasma TV
Screen goes white
The main driver board, or the main processor board most likely has a failure. The authorized Panasonic service rep can replace the defective boards and perform the necessary adjustments to match them up.
If the set is out of warranty it may be expensive to service. Using the set with a defect can cause more damage, and thus may increase the cost of the final repair.
Jerry G.
Oct 11, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
823 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
