Question about southland Garden Cultivator Tiller S-cv-43 -
Southland Starts runs for a couple of seconds and shuts off?
I have a 83 xs650 starts for 2 seconds then shuts down, what is causing this?
I found that with mine. It would start and run for 10/15 seconds and stop. Leave a couple of minutes and start no problem then stop again. Took whole ignition system to Boyer Bransden and they tested it and the brain box was faulty. Replaced that and bingo. SORTED. Over 40 Years Proven Performance
Jun 12, 2014 | 1979 Yamaha XS 650 SF
I've got a little southland tiller and the thing
Remove the air cleaner and spray carb cleaner into the throat of the carb then try to start. If it starts right up for a second then its a fuel problem and the carb will need to be rebuilt, also check the fuel lines and filter. If it wont run for a second on the prime then you have an ignition or compression problem.
Sep 24, 2012 | Garden
My ice machine manitowoc q 132a starts up stops after few seconds while water pump start
There is a high pressure switch that stops the unit running if a fan fails or the condenser is clogged. Next time you start the ice machine, watch the bottom led on the pcb. It will tell you if there is a fault. Meantime, reset the hp switch and clean the condenser thoroughly.
Sep 06, 2012 | Refrigerators
Starts up but seem to run out of fuel in a couple seconds. Shut off the key and it will restart no problem but shuts off again in a second or two. It seems like I had this on a Camaro and it was a oil
Depending on what kind of car you have, it may be the antitheft security system shutting the fuel injectors off. This link explains if you happen to be driving a GM.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Mar 09, 2012 | Cars & Trucks
2000 2.0 vw beetle starts then dies
computer possibly has noticed a reason to shut down engine try checing the oil low oil psi will cause the computer to shut down engine before damage occurs
Jun 21, 2009 | 1998 Volkswagen Beetle
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
The van starts right up but shuts right back off
you might have a regular key instead of a microchip key. the micro chip key sends the signal to the computer. If you have a regular key it will start and a couple of seconds it will shut off and do it over and over again.
Oct 12, 2008 | 2004 Ford Freestar
southland Garden Cultivator Tiller S-cv-43 - Logo
46 people viewed this question
Top southland Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a southland Garden Expert? Answer questions, earn points and help others
