Question about Samsung SMH1816W Microwave Oven
No power Power at the plug but nothing on the display
My modle # mmv4205aab lost all power, no display, no nothing. thank you
Hello- Unplug, open door, and remove screw holding display panel. Be careful, some wires may need to be unplugged. 20a fuse should be visible. If this fuse is bad- replace and address any power supply issues, such as age of wiring or circuit load-(other stuff plugged in) Hope this helps-ED
Mar 01, 2010 | Maytag Microwave Ovens
Just quit. No power, no display....nothing
there are several possible causes, check voltage at outlet
check the 20 amp bus fuse on the main board ohm out the cavity thermostat, replace the bad part
Sep 10, 2009 | Samsung MS1040BB Microwave Oven
Emerson Microwave stopped working
Have 1 of 2 choices, the main fuse or the control board for the front switches and clock. primary of the small power transformer has opened. Unplug the unit and take case off and measure the fuse with an ohm meter. if u read 1 ohm or less then fuse is good. then measure across the main power plug tips. If read open then the power transformer is bad. Need to replace the board as not sure if transformer is available.
Jul 26, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Has power to unit but nothing works, ie. oven, clock, timers, etc
If you don't see any light in the display or from the light bulb inside it you probably need to replace the fuse inside the microwave, it should be by the place where the cord goes in the microwave.
Apr 08, 2009 | General Electric Microwave Oven
Neff Microwave H6871 no instruction book - unable to operate it
This is more of an idea than solution but have you tried disconnecting the power supply and then plugging it back in? If the red led display lights up you will know it works. Otherwise I would say it's time to replace the microwave. If you don't have access to the power supply try flipping the breaker.
Jan 14, 2009 | Neff Microwave Ovens
No power
The door switches are designed to prevent the unit from running while the door is open. You probably have a blown fuse, and it's a white or dark grey ceramic fuse of 15A or 20A, available from local big box stores or appliance parts stores. The fuse is usually located on the floor of the chassis behind the control panel, or mounted in the same area as the door switches. Also, I'm really curious how the door switch got stuck while cleaning? That sounds scary...
Nov 13, 2006 | Kenmore 62622 Microwave Oven
Samsung SMH1816W Microwave Oven Logo
15 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
