Question about Tunturi Exercise & Fitness
Broken consol Is it possible to buy a replacement console for a R25 rowing machine
SOURCE: Old sewing console with new machine
I have a very old Necchi machine and I need a new belt for it.
Posted on Apr 11, 2008
SOURCE: 2002 camry - Need to replace broken console lid
Solved it. Found a small shank screwdriver that fitted into the opening with a little bending of the plastic frame. managed to replace it with a new one without trouble. No further help needed. dave
Posted on Nov 09, 2009
  • 86 Answers
SOURCE: clasp to lid console top box broken. How do you
This part is available at your local Infiniti dealer. The plastic part is replaceable.
Posted on Feb 14, 2010
  • 1024 Answers
SOURCE: the center console lid is always broken. My
you can check with your local junk yards/ auto salvage and they can find what you need
Posted on Mar 13, 2010
maxtreadmill
  • 832 Answers
SOURCE: replacement console
Unplug unit then remove the upper console, their are 4 allen bolts holding it udder the console their is a panel held by 4 phillips head screws also remove them . Look inside the compartment and their should be two connections, disconnect them. Now pull console off its tower. Lay it upside down on a thick towel remove all phillip head screws you'll notice where the emergency stop button is connected. I have found that this connection 7 out of 10 times is causing the problem. Buy cutting the lead connector stripping the wires and soldering back on the male connection will resolve the problem. If not their is a emergency stop kit may be purchased and replace. The only other thing that may cause the problem is the function key pad itself. Try the first solution if your not good in soldiering go to a computer shop , t v shop they should be able to do this very quickly for while your at let the check the switch itself.
Posted on May 18, 2010
Testimonial: "This guy really does know his stuff. I am very pleased I was able to fix the treadmill with absolutely no expense. I simply followed the clear instructions and the machine was up and running in an hour. I would rate this expert 10/10 but actually he warrants 11! maxtreadmill yo da man !"
Snes reset button
Well you could try buying a broken Super Nintendo console off of EBay and get the part that you need to be replaced. If you find a broken SNES console with a reset switch button that is fine then.
Jul 29, 2012 | Nintendo Super NES Console
I have a wieder platinum but the console isn't working
I have one the motor is out . has new console and wire leads whole machine is like new. will sell as is for parts 563-543-4347
Feb 15, 2012 | WEIDERFITNESS.COM Weider Platinum Plus
Cabrio top load washer (WTW6600SB1) start button broken - I can feel that the device behind the "Start" display has broken. It doesnt depress like usual. I removed the entire control panel. When...
Unplug the machine or disconnect power then remove the three hex-head mounting screws from the rear of the console. Tilt the console forward toward the front of the machine then disconnect the user interface board cable connector from the machine/motor control and lift the console off the cabinet.
Carefully pull the cycle selector knob off the shaft then turn the console on its face for access to the user interface control board. Unhook the wires from the clips then remove the three screws securing the board. Using a flat-blade screw driver, pry the cover's two locking tabs out then unclip and remove the cover from the console.
Lift the locking tab of the encoder then turn the encoder counterclockwise and lift and remove it. Carefully pry the font edge of the user interface board up then pull the board forward and remove it from the console. You may glue the broken part back in place or replace the console with part number W10070060.
Jul 18, 2011 | Washing Machines
Playstation 3 (PS3) Console: the disk drive is broken...
It probably needs a new laser because the old one is "burnt out". It's a really common problem with them.
You could replace the laser or the entire Bluray drive.
You can buy these online at may online stores or eBay.
May 18, 2010 | Sony Playstation 3 (PS3) Console
My joystick is broken - is it possible to get fixed?
If you have a PSP-1001 you can get a replacement thumbstick here.
If you have the PSP-2001 or PSP-3001 you can get a replacement thumbstick here
There are also tutorials on how to fix this without buying a replacement which can be found here
Dec 04, 2009 | Sony PlayStation Portable (PSP) Console
Game card reader with brokn pins...
Yes you can buy it in the ebay...
Regards,
VOTIT
Aug 21, 2008 | Nintendo DS Lite Console
Broken internal screen
if the system is still functioning it is possible to get the screen replaced. i have replace PSP screens before. if u want that service done by me let me know.
there is a link to do it urself, <if you think u can> http://www.llamma.com/PSP/PSPTearDown.htm
this is where u can buy one
http://www.echostore.com/psp-lcd-screen.html
enjoy ! Geeksquad
May 13, 2008 | Sony PlayStation Portable (PSP) Console
Broken Hinges
i suggest you buy a replacement shell from ebay and check out the u tube video on disassembling
Feb 26, 2008 | Nintendo DS Lite Console
Nintendo ds
Its possible though sometimes it is expensive so dont worth the work.
-Top screen broken: you can buy a replacement and carefully do the work by yourself with the help of a guide (youtube have many) and some tools (3 winding screwdriver is the less common though not much). The foil data ribbon can be bought separatelly for the original NDS though the new NDS lite have it soldered and very difficult to work.
-Broken plastics: a broken hinge means you need to buy a replacement shell. Anyway buy a complete shell from a DS modding shop or take parts from a non broken plastics DS (water damaged one may be good) in a place like ebay. You would be lucky if you find a non broken screens and good plastics DS for parts.
At the end you may be over your repair budget and not only that, you would be very near to buy a new unit with this money. Each one make its own choice.
Good Luck...
Dec 03, 2007 | Nintendo DS Lite Console
Exercise & Fitness Logo
44 people viewed this question
Top Tunturi Exercise & Fitness Experts
gbob59
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
