Question about AEG Washing Machines
Aeg lavamat carat 47328
Hello, 1. Our AEG Lavamat Carat stopped working from one moment to the other. 2. When I program the machine, the digital display will show the usual info (but NO error code). 3. Once having pressed the starting button, the cover locks up properly and the pump is starting its routine three seconds or so expulsion. 4. After that the clock will count down, but nothing is happening. 5. The machine is not turning/spinning and no water is being poured in. 6. I tried the error code procedure, but - although many codes appear during the turning of the program-button, no particular code is showing up in its final position (as has been promised by some advice-paper). 7. I also removed the side panels of the machine and opened up the above part of the print and I opened the ENV box below-rear in the machine. 8. I have not noticed anything unusual nor is there a flavor of burned plastic. 9. As far as I can judge, all the connections in the AEG are being well placed. 10. So what in your opinion should I do to solve the problem. kind regards
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
May 22, 2015 | AEG Lavamat 88840 Front Load Washer
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Can I use hot water supply only on my AEG Lavamat W 1159?
A valid point but unfortunately your machine is programmed to take both and will register this as a fault.
This is probably not what you wanted to hear but please dont shoot the messenger.
Jan 22, 2009 | AEG Lavamat W1450 Front Load Washer
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
Mar 03, 2008 | AEG Lavamat 88840 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
