Question about Nortrac 20XT 20HP 4WD Tractor - with Ag. Tires
The tractor started fine, moved it out of the way and let it run for about 10 minutes and then turned it off. Now it will not start and acts like it isn't getting any power from the battery, so I tri
Tractor won't start. It doesn't get any electric but the battery is good. What could the problem be?
I have 1995 5.8 Bronco. Startturn off. Come back in few minutes won't start, but will wait for 10 minutes or so and then starts fine...until turn off again. Solenoid?
By suggesting solenoid I guess you mean it will not even crank. Heat soak can make solenoid act this way. If it cranks but will not start, I suspect leaky fuel injector(s) flooding engine.
Jul 30, 2015 | 1995 Ford Bronco
I have a 2002 Pontiac grand am se 2.2 ecotec. It
reprogram the key by putting it in the ignition and turning it to the run position. let it set for exactly 10 mins turn off and immediately return to the run position for 10 more minutes exactly. after the second 10 minutes turn off and immediately try to start the car.
Oct 05, 2014 | 2002 Pontiac Grand Am
I have a troy built riding mower it starts up fine , runs 10 or 15 minutes, then it starts spuppering and dies. then it acts like its flooded when you try tostart it again. then the other day while tr
is it starving for gas the gas cap vent could be plugged keeping the fuel from flowing leave the cap loose and run it/are you loosing spark when this happens like the coil is going bad?
May 08, 2012 | Garden
Tractor dies
my lx173 quits running after a while and will start back up and run for a while longer and quit again
May 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Instructions for fixing the choke on a Craftsman LT-1000 lawn tra
I have been hearing alot of this problem. Well it is gravity flow. I just bought a 2002 lt1000 17 hp without a carb the guy was having the same problem so he sent the carb away to get checked out and low and behold it got lost. He waited the summer to see if it would show up but it did not. He got mad and bought a new bigger one. Any ways i am waiting on a new one. Now in my reading these problems i discovered that the fuel line coming out of the tank to the carb is lower. Might be somthing to look at. JIM
May 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Farmall Cub 1955, runs fine for about 20- minutes
I have cub that done same thing, there was crud in orfice between tank and sediment bulb, cleaned orfice, runs fine.
May 30, 2009 | Farmall Cub Tractor Radiator
Nortrac 20XT 20HP 4WD Tractor - with Ag. Tires Logo
Top Nortrac Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Nortrac Garden Expert? Answer questions, earn points and help others
