Question about Sharp Stx-2 Stx2 For H20 H2o Wireless Unlocked Slider Qwerty Internet
Please insert battery
I need to know how to change the battery
How to change the battery in my Anycom HCC-250
A rechargable Li-Polymer battery should be included with a charger for it when you bought it.
Note:
It is recommended to charge your Car-Kit when it is not in use.
Please note that "inserting" charger will cause a device reset. However, when the Car-Kit is in charging (the charger has been inserted), the Car-Kit is in normal
operation
Oct 16, 2015 | Anycom Radio Communications
How do I change the battry in a toshiba tecra laptop
Most laptops of external (replacable) batteries. However, if this is not true for your laptop, the battery is located inside and it is best to have a computer expert remove and replace the battery as any and all warranties valid on the laptop may be void if you attempt this yourself. There should be an indicator on the bottom of the unit with words to this affect. If the battery IS external, look to see if there are two "clips" that slide back and forth on each end of the battery. You'll know them when you see them. These "lock" the battery in place once the battery is inserted and usually automatically lock when battery is inserted. Hold each one in the indicated "unlock" position and pull out on the battery. These should not need to be "held" in the unlock position, and should stay on on their own once moved. Pull battery out and insert new battery if applicable. Please let me know if this was helpful, and contact me if further assistance is requested. Thank you.
Nov 28, 2014 | Toshiba Computers & Internet
Battery changes
Usually there's a cover that opens to give access to the battery compartment. Remove the old battery and insert the new. Your manual should explain the process.
If you need further details, please feel free to respond to this post but be sure to specify the make and model of your digital camera.
Mar 06, 2012 | Cameras
How to remove acertravel mate 252 bois password? i enter 3 times wrong password and i recive system disable code 12717
Hi saeedbjaan.
You may reset the BIOS password by removing and re-inserting the CMOS Battery.
The CMOS Battery will store the Computer date, time, BIOS password etc.,
Hence, removing and re-inserting the CMOS Battery will reset the BIOS password.
However, please let me know if you need detailed information to remove the CMOS Battery.
Hope this helps.
Please feel free to contact for further information and assistance.
Sep 23, 2010 | Acer TravelMate 252LMi Notebook
I changed over to other nam and powerd down phone
PLEASE BACK UP YOUR FILES BEFORE UNLOCKING
This will also bring the phone to default settings
1. First do a CUSTOM reset: *2767*2878#
turn off the phone
2. take out the battery and sim and put wrong network SIM and insert only a half of it,
Very important so it won't ask for network password and shows "Insert SIM" message.(possibly in a different language)
Now put the battery ,and switch the phone on .(phone shows "Insert SIM" message.)
3.push the sim fully in at this stage the phone is still asking to "Insert SIM"
4. Make a FULL reset: *2767*3855#
5. The phone should reboot working with "wrong" sim inside.
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
7. Now Disable network lock By typing: #7465625*638*00000000#
Phone is unlocked
Mar 06, 2010 | Cell Phones
Wont start
Hi there, please explain what's you face. Also you can follow the steps.
1. plug on the the power cable. Is there green light are on in adepter? Is not then your power cable damaged.
2. if you r battery fully charged then turn on your laptop with out connecting power cable. If your laptop booting then system is perfect.
3. Try to plug on by a different Acer laptop users power cable. and see what's going. I need these information for further instruction. You just say "wont start" i don't want to give you any blind suggestion. so please let me know more about it.
Thanks.
Feb 11, 2010 | Acer Aspire One Netbook 8.9" Notebook
How do change batteries on mouse
HI,
All you have to do is flip the mouse over and remove the battery cover by pulling it up gently.Next remove the batteries from the mouse and insert the new batteries.Make sure the positive and negative connectors are lined up properly.
Insert the battery cover again and your mouse is now ready to use.
If you need any more help let me know.
Thank you.
Aug 07, 2009 | Dell U0636 Mouse
How to change the sims card on the i730 nextel.
The SIM card in a i730 slides out of the side of the phone. Remove the battery and simply slide the card to the right toward the push to talk button.
Once removed you will see a diagram that shows how to insert the new one. You need to insert it with the angled edge down to the left.
If it is a new SIM card you will need a SIM copier to copy the contacts from one card to another (if you want to)
You will also need to activate the new card before using it. Go to a Nextel store for this or try customer service.
Jan 16, 2009 | Nextel i730
Sim card problem
The problem is with ur SIM.
Replace the SIM with same number.As it is much older AND may have scratches.
Jan 21, 2008 | Nokia 7250i
6600 insert sim ways
try the nor way turn off phone and disconnect the battery and insert the sim and put the battery >and use the phone
Oct 14, 2007 | Nokia 6600
Sharp Stx-2 Stx2 For H20 H2o Wireless Unlocked Slider Qwerty Internet Logo
16 people viewed this question
Top Sharp Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
pontelemon
pontelemon
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
