Question about Roadmaster Mt sport sx
Looking for replacement brake pads
Looking for replacement pads and installation
What tools do i need to change brake pads on 2005 yukon xl
Jack, wheel wrench, socket set, large screw driver, pair of pliers or grips. Lithium grease for the pins. Watch all of these videos. .spell{font-size:18px}.spell_orig{font-size:15px}#mss p{margin:0;padding-top:5px}
g-img{display:block}._WCg{display:block;border:0;position:relative} Search Results
    How To Install Replace Front Brake Pads 2000-06 Chevy ...
    9k=? 4:46 https://www.youtube.com/watch?v=nPohZtD8zlA May 27, 2014 - Uploaded by 1A Auto Parts http://www.1aauto.com/brake-pads/i/1abps00080 1A Auto shows you how to ... Front Brake Pads 2000-06 ...
    HOW TO INSTALL REPLACE GMC YUKON DENALI ...
    z? 14:10 https://www.youtube.com/watch?v=um7dt_yvZ1s Sep 20, 2012 - Uploaded by TheRykerDane Video on how to change the brake pads and rotors on a 2004 GMC Yukon Denali. Changing these parts ...
    How to REPLACE INSTALL BRAKES and ROTORS GMC ...
    2q==? 11:32 https://www.youtube.com/watch?v=UWqows3P4DE Feb 11, 2012 - Uploaded by TheRykerDane Video on how to change the brake pads and rotors on a 2004 GMC Yukon. Changing these parts ... Would ...
    GMC Denali Brake Pads Removal and Installation - YouTube
    z? 3:45 https://www.youtube.com/watch?v=uEKs8nphVxU Oct 24, 2012 - Uploaded by AnotherLookFilms Remove and Install rear brake pads on your 2006 GMC Denali XL. ... 9-21-13 2007 GMC Yukon rear brakes ...
    GMC Yukon Denali Front Disc Brake Pad Replacement ...
    2q==? 8:21 https://www.youtube.com/watch?v=w_gn_l5lYkw Jun 20, 2013 - Uploaded by AMS Automotive Watch the proper procedure for replacing front disc brake pads. Featured vehicle: 2007 GMC Yukon Denali ...
Jan 22, 2016 | Cars & Trucks
When I replaced the belt and the auger impeller brake pad,after it broke.The brake pad keeps slipping off the belt .. Why would the brake pad keep coming off the belt ?
Something is not lined up correctly. The brake should be perfectly lined up with the Pulley with no side to side movement
Feb 28, 2015 | Garden
Need to perform rear brake pad change on 2006 Volvo V70 AWD 2,5T wagon
brakes are brakes, push in , turn in, or two piece calipers. remove wheel , remove two bolts that hold caliper in place, remove replace pads if rotors look good if not remove caliper retainer and rotor replace or have resurfaced at local part store with service. if push in piston push in with c-clamp or piston tool, if turn in will be solid on top with slots for tool to turn in turn to right, tool can be gotten at parts store, if two piece take apart and put back then bleed brakes.
Aug 19, 2012 | 2006 Volvo V70
I need to know what is wrong with my dodge ram 1500 . When I brake the truck squeals and its not my brake pads cause they look like new .
Did you install Dodge Replacement pads or aftermarket? With the size of the rotors and pads on your Ram it is not uncommon for aftermarket pads to have squeal. Did you install and use the anti-squeal material that should have come with the pads?
May 15, 2012 | 2007 Dodge Ram 1500 Quad Cab Sport
How to change brake pad and check rotors
Brake Pads Removal & Installation Front for_car_toy_cam_02-04_sst_frt_dsc_asm.gif
To Remove:
  1. Drain brake fluid to ½ full level in reservoir.
  3. Remove the front brake caliper assembly.
  4. Remove the 2 anti-squeal shims from each of the 2 brake pads.
  5. Remove the wear indicator from each of the 2 brake pads.
To Install:
NOTE: When replacing worn pads, the anti-squeal shims must be replaced together with the pads.
  1. Using a large C clamp or equivalent press piston into the caliper.
  2. Apply disc brake grease to the inside of each anti-squeal shim.
  3. Install the anti-squeal shims on each pad.
  4. Install the pad wear indicator clip to the pads.
  5. Install the pads with the pad wear indicator plate facing upward.
  6. Install the brake caliper with the 2 mounting bolts. Torque the bolts 25 ft-lb (34 Nm).
  7. Install the front wheels.
  8. Fill the master cylinder with new clean brake fluid.
  9. Pump the brake pedal several times to seat the brake pads.
To Remove:
  1. Drain the brake fluid to ½ full level in reservoir.
  2. Remove the rear wheels.
  3. Remove the caliper slide pins.
  4. Remove the caliper slide pin bushings (TMMK made) (Kentucky).
  5. Remove the rear brake calipers.
  6. Remove the 2 brake pads with the anti-squeal shims.
  7. Remove the anti-squeal shims and pad wear indicators from brake pads.
To Install:
  1. Using a large C clamp or equivalent press the piston into the caliper.
  2. Coat both sides of the outer anti-squeal shim with pad grease.
  3. Install anti-squeal shims to each pad.
  4. Install wear indicators on the 2 brake pads.
  5. Install the caliper slide pin bushings (TMMK made) (Kentucky).
  6. Install the rear brake caliper with the slide pins. Torque the slide pins as follows:
    • TMC made (Japan): Torque the caliper slide pin 25 ft-lb (34.3 Nm)
    • TMMK made (Kentucky): Torque the caliper slide pin 34 ft-lb (47 Nm)
  7. Fill the master cylinder with new clean brake fluid.
  8. Pump the brake pedal several times to seat the brake pads.
  9. Install the rear wheels.
prev.gif next.gif Brake Rotor Removal & Installation Front To Remove:
  1. Remove the front wheels.
  2. Remove the front brake caliper assembly.
  3. Remove the front brake pads.
  4. Remove the 2 bolts and caliper mounting bracket.
  5. Place match marks on the disc and axle hub.
  6. Remove the front wheel disc.
To Install:
  1. Align the match marks and install the front disc.
  2. Install the brake caliper mounting bracket. Torque the bolts 79 ft-lb (107 Nm).
  3. Install the brake caliper. Torque the bolts 25 ft-lb (34 Nm).
  4. Install new gaskets and connect the brake hose to the caliper with the banjo fitting bolt. Torque the fitting bolt 22 ft-lb (29.4 Nm).
  5. Fill the reservoir with brake fluid.
  6. Bleed the brake system.
  7. Install the front wheel.
Rear To Remove:
  1. Remove the rear wheels.
  2. Remove the brake caliper assembly.
  3. Remove the brake pads.
  4. Remove the 2 bolts and the caliper mounting bracket.
  6. Remove the rear disc.
To Install:
  1. Align the match marks and install the rear disc.
  2. Install the rear brake caliper mounting bracket. Torque the bracket bolts as follows:
    • TMC made (Japan): Torque the bracket bolt 46 ft-lb (61.8 Nm)
    • TMMK made (Kentucky): Torque the bracket bolt 34 ft-lb (47 Nm)
  3. Install the rear brake caliper with the slide pins. Torque the slide pins as follows:
    • TMMK made (Kentucky): Torque the caliper slide pin 32 ft-lb (43 Nm)
  7. Install the rear wheel
Jan 25, 2011 | 2007 Toyota Camry
After front brake pads replacement there is a cranking noise when braking while driving
If there is a noise after replacing the brake pads, then there is a problem with either the installation of the brake pads or you could have the wrong part. Hope this helps :)
Dec 19, 2010 | 2005 Toyota Corolla
How can I change the rotors and brakes on a 2006 Cadillac?
Front brake
Step 1: Identify Front Disc Brake Components
Front Wheel Drive Brake Assembly
Most front disc brake components include: brake rotor, brake pads, brake caliper, caliper mount and brake flex hose. Brake service usual occurs between 20,000 and 40,000 miles depending on driver habits, road conditions and brake pad/ rotor materials used.
Step 2: Remove Brake Caliper to Replace Pads
Removing Brake Caliper Mounting Bolts
Locate primary caliper mounting bolts; apply wrench pressure counter-clockwise (When looking at the head of the bolt) to remove the bolts, upper and lower. Make sure the bolt threads are in good shape and replace if necessary.
Step 3: Remove Front Brake Caliper
After removing the primary caliper mounting bolts lift the brake caliper off of the rotor and then tie or secure to the side, being careful not to bend or kink the brake caliper flex hose. Thoroughly inspect brake caliper and brake hoses for leakage, cracks or chaffing and replace as needed. Next remove the brake pads (If not mounted in the caliper) and secondary caliper mounting bolts. Notice how great protective gloves work, most technicians use them on the job today.
Step 4: Remove Brake Pads
Remove Front Brake Pads
Once the brake pads have been removed, make sure if there is anti rattle hardware to transfer to the new brake pads. Some brake pad manufacturers will include the proper lube (Caliper slides) and anti-rattle hardware to ensure proper performance of their product.
Step 5: Remove Caliper Mount
Remove Caliper Mount Bracket
Finish removing secondary caliper mount bolts and remove caliper mount. Note: clean and lube caliper slides and pad friction surfaces of all foreign material or build-up.
Step 6: Remove Brake Rotor
Remove Brake Rotor
With the caliper mount out of the way you can now remove the brake rotor. Sometimes it can get stuck so you may need to tap it with a hammer or use penetrating oil to free it up. Some manufacturers use small screws to hold the rotor on as well. Clean and inspect wheel studs, replace if any are damaged. Also clean bearing hub rotor mount surface to ensure the proper mounting of the new brake rotor. Inspect the ABS sensor wheel for cracks or damage and replace as needed.
Step 7: Depressing the Brake Caliper
Resetting Brake Caliper
To install the new brake pads you must retract the brake caliper piston. Remove the master cylinder lid or open the brake caliper bleeder screw to allow excess brake fluid to be released if necessary. Install C clamp tool and gently tighten clamp until caliper piston is fully depressed. Note: use old brake pad to protect the caliper piston. Close the bleeders once the piston is retracted completely
Step 8: Installing New Brake Rotor
Install Brake Rotor
Install new brake rotor, the new rotor is manufactured with a protective film over the rotor to keep it from rusting, remove protective film with brake cleaner before installing; also after the brake job is complete you may experience a small amount of smoke from the rotor when first used. This is normal and will go away after the first couple of uses.
Step 9: Installing New Front Brake Pads
Installing New Brake Pads
Reinstall the front brake caliper mount, and then install front brake pads. Make sure the pads are seated properly in the caliper mount; it must be a close fit to work properly..
Step 10: Reinstall Front Brake Caliper
Re-Install front Bake Caliper
Reinstall front brake caliper and reinstall caliper-mounting bolts, recheck all mounts and mounting bolts. Check the caliper slides to be sure there is no bind and that the caliper moves freely back and forth on the caliper slides. Bleed brake system per manufacturer's specifications to relieve any air trapped in the system. Before driving the vehicle, push the brake pedal down and let it up slowly, repeat until normal brake pedal operation resumes, this operation is forcing the brake pads to travel to the brake rotors.
Dec 18, 2010 | 2006 Cadillac STS
What tools needed to replace front brake pads & rotors
Brake Pads
Front
3.4L front disc brake assembly
4.0L and 4.7L front disc brake assembly
To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of
    this section.
  2. Remove or disconnect the following:
    • Front wheel
    • Clip, 2 caliper pins, the anti-rattle spring then remove the 2 brake pads
      and the 4 anti-squeal shims
To Install:
CAUTION
Only replace brake pads on 1 side of the
vehicle at a time. Failure to use this procedure could cause the caliper pistons
on the opposite side of the vehicle to pop out requiring the reconditioning or
replacement of the brake caliper.
  1. Remove a small amount of brake fluid from the master cylinder.
  2. Install a used brake pad into the caliper and compress the caliper pistons.
  3. Apply disc brake grease to both sides of the inner anti-squeal shims.
  4. Install or connect the following:
    • Anti-squeal shims to the new brake pads
    • 2 brake pads
    • Anti-rattle spring and the 2 caliper pins
    • Clip
    • Front wheel
  5. Depress the brake pedal several times to seat the brake pads.
  6. Check the brake fluid level and top off as needed.
Rear
To Remove:
    this section.
    • Rear wheel
    • 2 cylinder slide pins from rear caliper assembly
    • Caliper assembly from rear caliper mounting
    • 2 brake pads with anti-squeal shims from rear caliper mounting
    • 2 anti-squeal shims from each disc brake pads
    • Pad wear indicator plate from the inner side disc brake pad
    • 4 pad support plates from the rear caliper mounting
To Install:
  1. Install or connect the following:
    • 4 pad support plates on the rear caliper mounting
    • Pad wear indicator plate on the inside brake pad
      Note: Install the pad wear indicator facing downward.
    • Anti-squeal shims on each brake pad
    • 2 disc brake pads with anti-squeal shims to the caliper assembly
  2. Apply lithium soap base glycol grease to the sliding part of 2 caliper slide
    pins.
  3. Install or connect the following:
    • Disc brake caliper assembly with 2 caliper slide pins
    • Torque to 65 ft-lbs (88 Nm)
    • Rear wheel
  4. Depress the brake pedal several times to seat the brake pads.
  5. Check the brake fluid level and top off as needed.
--- Removal & Installation
Front
To Remove:
    this section.
    • Front wheel
    • Front brake caliper assembly
  3. Make matchmarks on the disc and the axle hub.
  4. Remove the front disc.
To Install:
  1. Align matchmarks and disc onto axle hub.
  2. Install or connect the following:
    • Front brake caliper assembly with the 2 bolts
      1. Torque to 90 ft-lbs (123 Nm)
    • Front wheel
Sep 23, 2010 | 2003 Toyota 4Runner
Installing new brake pads on 2000 hyundai Accent GL
REMOVAL 8118049.gif 1. Remove the lower bolt and lift the caliper assembly up and secure it with a wire or some other retaining method. 2. Remove the pads. CAUTION: Do not depress the brake pedal while disassembling the pads 30c09b4.gif
INSPECTION 1. Check the pads for wear or oil contamination and replace, if necessary. caution_icon.gif The pads for the right and left wheels should be replaced at the same time. Never "drop" or intermix brake pad sets. All four pads must be replaced as a complete set. When replacing the brake pad, check for deformation. When replacing the guide spring, use a new one or the used one after cleaning away foreign material. 2. Check the pad for damage or deformation. Brake pad thickness: Standard value: 9 mm (0.354 in.) Service limited value: 2 mm (0.0787 in.)21873bf.gif
INSTALLATION 1. Install the pad clips. 2. Install the pads onto each pad clip.
3. Insert the piston in the cylinder using the Special Tool (09581-11000).b3dcdee.gif 4. Install the new pads. The shims are attached to each pad as illustrated5efc485.gif caution_icon.gif Be careful so that the disc or pad isn't contaminated by grease. 5. Install the bolt and tighten to the specified value. Tightening torque Guide rod bolt: 22~32 Nm(220~320 kgf·cm, 16~24 lb·ft)
Jun 11, 2008 | 2000 Hyundai Accent
Roadmaster Mt sport sx Logo
49 people viewed this question
Top Roadmaster Cycling Experts
ptpumpman
ray gallant
Mark Schmit
Mark Schmit
Are you a Roadmaster Cycling Expert? Answer questions, earn points and help others
