Question about Samsung CXJ1964 19 in. TV/VCR Combo
Samsung model tt20a54 keeps cutting off, how do i stop it from doing so?
My tv will cut on but only for a few seconds then cut off, everything else with the tv seems to be fine other than it cutting off constantly
SOURCE: Samsung model SR-L38NMB refrigerator
that problem very likely is the control board. there is another brand of fridge in S.AFRICA THAT DOES THE EXACT THING OF WHICH THE BOARD HAS TO BE CHANGED.
Posted on Jul 25, 2007
SOURCE: Samsung RL36SBMS keeps cutting out,
This is not a full solution, but I'll tell you what I did. Somewhere along the way, something worked.
First, I defrosted for about 48 hours. I turned it on, and the same thing happened, as if it was broken.
I took off the back panel (and also the support for the ice rack) mostly. I got all but the top bit off, so it hinged on the top (I was afraid of breaking the plastic. I checked that there was no ice around. I spun the fan, and wiped the grooves where the air flows (to clean it off a little). I put everything back together. It was tricky making sure the wires on the left did not get caught.
Bizzarrely, having disassembled and reassembled everything, it all started working again as if there was no problem.
Incidentally, the blinking light under the "5" seemed to indicate it was in test mode. I tried to somehow get it out of that by holding down buttons for 8 seconds or so, but that did not seem to work.
If this or something else works for you, please do post, but at least this worked for me, and it is worth a shot before buying a new fridge.
Incidentally, I have read enough to know that I will not buy a Samsung fridge again.
Posted on Jul 28, 2008
ronaldo_ross
  • 1056 Answers
SOURCE: Samsung Rear Projection 47" TV goes into stand by on start up
I am sorry to disappoint you but a TV problem can only be fixed by electronic technician. If you want to do it yourself, you would have to learn electronics. Start by learning basic electronic, and then read a book on how to fix televisions. Without knowledge in electronics, you won't be able to understand a book on fixing a TV. I have been fixing TV since 1998, and I started after dropping out of electronic engineering class. I learned most about electronics on my own, and you can too.
Posted on Jun 27, 2009
  • 610 Answers
SOURCE: my samsung tv sound keeps cutting out. I have to
either you have a loose connector going to speakers or the main board is failing.call 1-800-samsung for nearest service center.
Posted on Dec 02, 2009
SOURCE: Samsung side-by-side fridge freezer model
HOW DO U CHANGE A WATER FILTER ON A SAMSUNG MODEL NO RS21DCSV
Posted on Feb 15, 2010
When cut tv on it cuts right back off after few seconds.
usually this is a fault with the power supply in the tv. the capacators only hold enough charge to turn on the tv but not maintain the proper current to keep it on. contact a repair technition or the manufacturer.
Mar 07, 2011 | Samsung PN50A550 50 in. Plasma TV
Power on T.V. keeps cutting on & off every second.
I believe that your TV's had a bad soldering. resoldering all the circuits may help.
if you bang or tap the top or side of your TV the video, sound, or anything will move or something happen.
warning: TV's has a high voltage. I prefer you to be careful if you open it.
have a good day and take care.
Jan 16, 2009 | Samsung DLP HL-P5663W 56" TV
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Samsung RL36SBMS keeps cutting out, it runs for a few hours the stops and gets warm if i turn it off and on again at the panal at the front it will start working for a while? any ideas?
Apr 17, 2008 | Samsung RB1955VQ Bottom Freezer...
Samsung CXJ1964 19 in. TV/VCR Combo Logo
26 people viewed this question
Jerry Greenberg
Jerry Greenberg
