Question about Kitchen Appliances - Others
Tube release broken
Tube rekease doesn't work
Tip
How to fix a Washing Machine if it Doesn?t Agitate
If your washer fills with water but doesn’t agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.)
1) Check the spin cycle. If this works, the motor is operating and the belt is not broken. If it doesn’t, the belt may be loose or broken. If you’re fairly handy, tighten or replace the belt; otherwise call an appliance repairperson.
2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during certain cycles. Press and release the switch. If it doesn’t click each time you do this, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repairperson.
3) There may be a problem with the controls, or the agitator solenoid may be broken. Call a repairperson.
on Sep 03, 2010 | Washing Machines
Broken hood release larch on '01 Pontiac Grand Am.
You can try going up from the bottom behind the bumper cover, or thru the grille opening. You may be able to pull the hood latch with a hook such as a coat hanger or pry it with a crowbar.
You may have to have the bumper cover removed to gain access.
Apr 30, 2013 | Cars & Trucks
Ge electric dryer dpsr483ea1ww, dryer stops when start switch is released
Broken belt or broken belt switch or broken wire or bad motor.
Sep 05, 2012 | GE Dryers
Car shakes when i take off its a 960 volvo
do you mean that on the attempt to move first gear? if is that probably you will have a clutch problem.Either is you clutch disc broken springs,your pressure plate doesn't release the disc properly,or your hydraulic clutch system -if it is hydraulic- doesn't work properly.
Sep 04, 2012 | Cars & Trucks
76 flh cluch dont move when handle is pulled
Check to see if the clutch cable is broken. Watch the long clutch release lever under the oil tank as you squeeze the clutch lever. If it doesn't move when you squeeze the lever, your cable is broken. If it does, you've got problems with the release mechanism inside the right side of your transmission most likely.
Steve
Sep 05, 2011 | Harley Davidson FLHR - FLHRI Road King...
Seat belt locked
Try pulling on it really hard, and then slowly release. If that doesn't work, you can remove the plastic trim piece and see if something is jamming the mechanism, like a petrified cookie.
If you poke around a bit on the mechanism, you will eventually hit the release, and the belt will retract as long as the wind-up spring is not broken. If it is broken, you should replace the belt.
Aug 17, 2011 | 2001 Ford Taurus
Washer will not spin just makes a grinding sound
if it is a top loader then there is probably something wrong in the basket drive tube area! the brake release arm could have broken off the 2 little pins that go into the cam,,, my washer had ground off the bottom of the tube and the clip that holds on the brake release arm fell off and would not release the brake to allow it to spin! so check that area!
Mar 14, 2010 | Washing Machines
Washer does not spin but makes loud clicking noise?
sounds like you could have a problem with your basket drive tube,around the clutch brake area! my machine would not spin and i found out the bottom of the basket drive tube had been ground off by the thrust washer which resulted in the clip that holds the brake release arm fell off and broke the 2 little pins on the brake release arm and it would not disengage the brake to allow the basket to spin, i bought a used basket drive tube and a new clutch ,installed and unit works fine now,,,so take a look also check your motor coupling see if it is broken ,,, and 1 more thing ,up under your agitator is the basket drive block sometimes it shears off the notches on the top of your drive tube!
Feb 17, 2010 | Kenmore 24032\24036 Top Load Washer
The spin cycle is not working. I already replaced the clutch assembly. Still, it did not wrok.
when you replaced the clutch did you look at the bottom of your basket drive tube to see if it was worn down,also the white plastic brake release arm could have the 2 little lineup pins broken off, or your drive block could be worn out,it is under your agitator,,,,,i found out on my machine that the bottom of the basket drive tube has a brass t post and the thrust washer had worn it off completely,the clip that holds the brake release arm fell off and broke those 2 little fingers off the arm,,,,,,i had to buy a used basket drive tube installed it with a new clutch and now the spin cycle works fine !! give it a good look at
Feb 15, 2010 | Kenmore Washing Machines
Kitchen Appliances - Others Logo
41 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
