Question about Taylor 7506 Glass Lithium Digital Bathroom Scale
Only gives dashes for a reading
No numbers come up, just dashes
My opel vivaro van on 7 safe and I pressing the as button and on and wont give me the ----
You must leave the radio ON like this until the SAFE mode clears.
When it does, to get the code accepted, press AS and then a couple of seconds later the 'on' button, together until it beeps.
As you know you will then see 4 dashes. Each dash is a number from your code.
Use the numbers along the radio (1 is first number in code, 2,3 and 4 the other numbers and so on)
As an example, if your code was 4432
press button '1' 4 times (gives a 4)
button '2' 4 times (gives a 4)
button '3' 3 times (gives a 3)
button '4' 2 times (gives a 2).
When you see your code displayed correctly on the screen press AS until you hear a beep.
HELP Radio SAFE mode
May 14, 2016 | Opel Cars & Trucks
How do I find the VIN number, the decal is on the fire wall can not read engine block number is A28019B
Hi Don:
Vin number should be on dash in front of steering wheel. read from outside. Sould also be on tag on drivers door jamb, and on registration papers.
Dec 03, 2015 | Cars & Trucks
TEM NOT READING ON DASH
the dash board Temp. sensore is located in radiator near bottom or sides just search around the radiator for rlectrical wire check the wire is pluged into sensor probably check the wire is good and is connecting the signal then check the sensor it selfe by measuring its output resistance when its cold then but in in a dish full of boilng water take the reading again it should read resistance less than the cols state otherwise the sensor needs to be replaced (it could give you no reading due to internal open circit corrupted sensor or it can give u no resistance change or a ver slight change while it should gives a bog diffrances
unplug it test it
replace it
good luck sir
Apr 03, 2014 | 2007 Chevrolet Cobalt Coupe
Tacho and speedo incorrect readings
compared to what?
tell method of test.
tell numbers. my engines idles hot at 800 (hand tacho)
but gauge reads in dash 200.
or im going 50mph ,my cell phone with free GPS shows 40.
why?
like that, use real numbers.
Jan 31, 2014 | 1992 Toyota Celica
2001 chev monte carlo dash gauges are not recording any readings
does your car turn over or start? check for lose ground/power
Sep 13, 2012 | Chevrolet Monte Carlo Cars & Trucks
2000 Toyota Avalon - when you press the brake the light on the dash comes on and indicates a problem with the tail light. Checked all the bulbs, working fine. Replace two with new ones, light still on. ...
Make sure you are using the correct bulb numbers per manufactures recommendation. Diff types of bulbs even though they fit and light up will give light monitor false readings. You may have a malfunctioning light monitor which I have seen on a few of these models.
May 17, 2011 | 2000 Toyota Avalon
Recently i bought bmw z3 model 2001 battery was bad .after changing the battery i get the code on the radio. please help
I just did this yesterday for an M3...
pull the stereo out of the dash far enough to read the serial number... call the dealership and they will look it up free of charge and give you the code... write it on the radoi for future reference...
Sep 25, 2010 | 2000 BMW Z3
No mileage showing digital readout thanks
It is registering, but the light is burned out. You can probably use a flashlight on it and see a faint glow of numbers, but you just need a new bulb. Your radio is probably only half lit on the readout, too. Common problem with Pontiac sunfires. Dashbulbs. Cheap fix, but time consuming.
Nov 17, 2009 | 2001 Pontiac Sunfire
Taylor 7506 Glass Lithium Digital Bathroom Scale Logo
52 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
