Question about SIIG Computers & Internet
Siig multi function device
Says it doesnt have enough free resources to run
spare_head_2
  • 47 Answers
SOURCE: Resource Conflict - PCI Network Controller in Slot 02
Hi akwasi,
Try pressing F2 and look in the bios for a setting that says "Load Bios defaults". If you have any PCMCI cards inserted please remove them first and try a re-boot.
Have you added any new components on the PCI bus? If you have you need to make sure that the BIOS is allowed to reconfigure the interrupts. The device in slot 03 is conflicting with the integrated network controller hosted on the PCI bus. Remove the device in slot 3 and all should be well.
Most BIOS manufacturers allow the PC/Laptop to manage it's own interrupts, so ensure the device you've inserted allows for this. If it uses fixed interrupts this might be your problem.
A good manual should details the BIOS setting you can adjust in order to get the PCI controller happy again and allow the machine to POST correctly.
Regards,
Spare head 2
Posted on Jan 04, 2008
check for an update of bios on acer.com it will fix your laptop problem....
Posted on Apr 24, 2008
  • 244 Answers
SOURCE: My laptop wil not boot. Not even in safemode
Hello Karen
Try removing and resetting your memory modules.
Blow some air in the slots to remove any dirt trapped in there.
They are locate don the back of your laptop.
The instructions are in the manual under how to change or upgrade memory modules.
Please don;t forget to rate this answer if it helps
Posted on Jul 22, 2009
  • 1087 Answers
SOURCE: Al encender mi ACER Aspire
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
Posted on Aug 16, 2010
alien_x
  • 281 Answers
SOURCE: I have Acer Aspire 5101
you need to flash your bios with a new version try the laptop manufacture's site.
Posted on Nov 02, 2010
Resource conflict error
I would run chkdsk/f on your hdd as errors like this can be caused by system file issues. Go to my computer, right click on drive C and choose properties than tools and then click Check Now. After that run ASC from iobit, a free registry cleaner that actually works!
Mar 23, 2014 | Computers & Internet
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
Hau I instaling GPS on my computer and than loagin on my mobailphone?
Installing programs are attainable on computer from where spaces are provided to capture through to displaying. Computer feature functions allow an extensive resourcefulness. In situations that several devices derive network connectivity requires sharing resources is attainable by allowing computer to capture the installation of extensive volume of media from where devices like mobile phone derives remnants of resources from network connections. Reason a factor with computers capturing the host functions are becomes has enough spaces as device to capture the entire volume to material programs. In the circumstance of mobile phones, spaces have least been provided by manufacturer to capture display an enormous program resources like programs. Mobile telephones derive an experience from network structure of computers however captures media in fragments necessary to user experiences. Once the global position program has been installed on computers as local devices, an area network connection of devices of mobile phones derive resources from that computer. Recognize the computer on which program was installed either as local device that sets the structure recognidsable as area from where mobile phone would derive resources. Mobile phones that derive resource from internet devices like World Wide Web least requires ascertaining the location computer from where tour guide feature as map guides are derivable. Phones that have internet world wide web's have browser page programs from where type searching map guides derives to display requested results from any available computer with media.
Feb 27, 2011 | Computers & Internet
Need a windows 7 driver for the siig ce-umcp12
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 31, 2011 | SIIG CE-UMCP12 Webcam
I have bought an SIIG JJ-P00112-S2 single parallel port card and installed it on an ASUS P5Q motherboard which does not have a parallel port on it, thus in the BIOS there is no where to see setting for a...
Access Device Manager and locate and double-click on Ports (COM & LPT). Right-click on the system's parallel printer port, and select the Properties command. Click the Resources tab and deselect the Use Automatic Settings check box. This enables the Setting Based On dropdown list, allowing you to choose a setting that matches the system's BIOS configuration. As you do so, keep an eye on the Conflicting device list box at the bottom of the Resources tab; you don't want to create other problems in the process.
Apr 21, 2017 | SIIG Computers & Internet
Wireless adapter cannot find enough free resources
please try to see if this steps will work. change the startup type of your wifi card into automatic by:
• click START, click RUN
• type services.msc
• look for WLAN Autoconfig and double click it
• change start up type into automatic and stat the process
• hit Apply and the OK
• restart the computer and also restart your wireless router
Hope these helps.
Jun 02, 2010 | MSI (CB54G2) 802.11g/b Wireless Adapter
Not enough resources to to use AIRCARD 881
Hi there.
Code 12 This device cannot find enough free resources that it can use. If you want to use this device, you will need to disable one of the other devices on this system. (Code 12)Cause
This error can occur if two devices that are installed on your computer have been assigned the same I/O ports, the same interrupt, or the same Direct Memory Access channel (either by the BIOS, the operating system, or both). This error message can also appear if the BIOS did not allocate enough resources to the device.
Recommended resolution
You can use the Troubleshooting Wizard in Device Manager to determine where the conflict is, and then disable the conflicting device.
Disable the conflicting device
  1. On the device Properties dialog box, click the General tab.
  2. Click Troubleshoot to start the Troubleshooting Wizard. The wizard asks you some simple questions and provides a solution to your problem based on the answers that you provide.
  3. Follow the resolution steps provided by the wizard to resolve the problem.
Good Luck and thanks for choosing FixYa!!
Jun 02, 2009 | Dell Latitude D600 Notebook
USB problem
i think u must upgrade the USB driver on ur pc go to this link and download the driver and save it in desktop and double click on it and install it
http://usb-1394-firewire.free-driver-download.com/SIIG/31991/SIIG-USB-2.0-Controller-Driver-v0.216-Windows-98SE-ME-2000-XP.html
rate me solved if its help thx
Oct 30, 2007 | 2wire 1000-200004-000 Network Adapter
Computers & Internet Logo
71 people viewed this question
Top SIIG Computers & Internet Experts
Eric Sutherland
PC Tech101
Level 1 Expert
Are you a SIIG Computer and Internet Expert? Answer questions, earn points and help others
