Question about Fujitsu ESPRIMO P5905 PC Desktop
HD5450 dont boot
XFX ATI Radeon HD5450 2GB DDR3 driver download
Go to ATI's Web Page. Select the area of interest (Video Controllers) and find your model. Go tot the updates, drivers etc. and download the current data and run it from there.
Dec 26, 2013 | XFX ATI Radeon HD5450 2GB DDR3 VGA DVI...
Trouble with install second video card HD 5450 to emachines t6532
Unclear of your statement. (More like run-on sentence)
Problem heading statement reads,
"trouble with install second video card HD5450 TO eMachines T6532"
Need clarification
The eMachines T6532 Desktop PC uses an MSI MS-7207 motherboard.
Also known as the MSI K8NGM2-L,
http://www.msi.com/product/mb/K8NGM2-FID--IL--L.html
(Click on photo for a better image)
Has one long white PCI Express x16 slot. (Expansion Slot)
Only uses one graphics card at a time, will Not use two.
[Graphics card / Video card. Same/same]
Therefore I surmise you are not referring to adding a Second graphics card, but are referring to;
A) This is the second time you have added a graphics card.
Or,
B) This is the second ATI Radeon HD5450 graphics card.
Had one before. Removed it, and are using a new one.
Or,
C) This is the second time you have added a graphics card.
It is not an ATI Radeon HD5450 like the old one is.
Know this;
1) You can ONLY use the OnBoard (Integrated) graphics,
OR the graphics card.
You CANNOT use both.
When using a graphics card the monitor is plugged into it.
You cannot plug into the onboard graphics of the motherboard, with it installed in the computer.
Said differently;
With the graphics card physically installed in the computer, you cannot just unplug the monitor from the graphics card; and plug it into the OnBoard graphics of the motherboard.
[Also; Computer on, you CANNOT unplug a monitor, and plug it back in.
This = NO ]
2) Driver: Small piece of software that allows the Operating System to communicate with a device.
The device is the graphics card.
The version of Windows operating system was not stated.
Did you install the software from the Installation Disk? (CD/DVD)
Has the drivers on it, and the user interface software.
User interface software for an ATI graphics card, is Catalyst Control Center.
(Just to note; I'm using a Powercolor Radeon HD5450 graphics card, right now.
I'm using dual monitors.
HP 2009M - 20 inch widescreen LCD monitor, and an RCA L26HD31 HDTV as the main monitor. (26 inch HDTV)
They work GREAT! ]
(It is an ATI Radeon HD5450 graphics card just like yours, IF yours has 1GB of graphics memory.
Doesn't matter what graphics card manufacturer, makes that HD5450, it is still an ATI (AMD) design.
Powercolor, VisionTek, Sapphire, Diamond Multimedia, Mickey Mouse, or Goofy. It is still an ATI graphics card )
The ATI Radeon HD5450 graphics card, has to have a MINIMUM power requirement of 350 Watts.
Does your power supply have 350 Watts or more?
If it is the original power supply, the answer is NO.
Back then power supply manufacturers were 'fudging' the true maximum rated wattage.
Why?
Sold more power supplies.
Power supply rated at 250 Watts?
Nope.
More like 60 to 70 percent of that.
Divide 250 by 10.
= 25.
Take that times 6. = 150 Watts (60 percent)
Times 7 = 175 Watts (70 percent)
Would like your opening statements clarified.
Post back in a Comment.
Regards,
joecoolvette
Mar 15, 2013 | E-Machines eMachines Desktop PC
HD5450
I would listen to how many beeps then search google for how many beeps and whats it mean and a list of codes should come up ... but if you just bought the HD i would return it.. or make sure everything is connected properly
Jan 15, 2013 | IBM Lenovo ThinkCentre® M52 PC Desktop
Radeon hd5450 compaq sr1810nx
Is the Radeon HD5450 a Video Graphics Card? If so just remove the power cord, open the case, then put the Redeon HD5450 into one of the open pci slots.
Hopefully you did your homework to make sure it will fit and is compatible with your compaq.
Apr 22, 2012 | Computers & Internet
Why won't my ATI HD5450 work on my ASUS P5LP-LE mb?
Are you sure that the 5450 works? Try it on another PC, if it does work fine on another system then it could mean that the PCI Express slot on your ASUS board could be faulty. Uninstalling the on-board drivers won't make a difference.
Dec 15, 2011 | Computers & Internet
Hi when I try to install vtx radeon hd 5450 graphics card no display is shown on monitor and all fans run fast computer appears to be booting but can't tell. compaq sr1519uk with MSI MS-7184 mbo,...
Hi Dave,
1. Have you ever tried testing your VTX HD5450 GPU to another system or try bringing it to the store where you purchased it.
2. After removing the VTX HD5450 GPU, did your Nvidia 8400GS worked? - If it works there might be a compatibility issue between your MOBO and HD5450 GPU if the card is good.
3. I think there is nothing to configure on your bios regarding Graphics setting because your Nvidia 8400GS worked without any problems.
4. Did you check the VGA/ DVI cable and power cable if it is plugged to the proper ports. There are times that even tough we are that good we miss something.
Hopefully this information helps.
Thank you for using FixYa.
Aug 20, 2011 | Computers & Internet
System will not boot with card installed. Replacing VT 3450 PCIE 512M H/D/V
Make sure you have uninstalled and deleted all drivers from the previous card.And any other files pertaining to the old card.
Jul 13, 2011 | ASUS ATI RADEON HD 5450PCI EXPRESS21DDR3...
My graphics card will not install. (Asus ATI Radeon HD5450 Silence). My computer is compaq presario sr1620NX with integrated graphics. (ati xpress 200 chipset) I disabled display driver in device manager...
How did you get your drivers and graphics? Did you install the whole package? What is the Asus model #? How much Ram do you have? I'm going to do a little research but let me know what you have.
Dave
Mar 26, 2011 | HIS RADEON HD 5450 Silence 1 GB DDR3 HDMI...
What is the cost of Radeon HD 5450 1GB DDR2 PCIE HDMI and .......
Amazon show a XFX ATI Radeon HD5450 1 GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card HD545XZCH2
For $34
Amazon com XFX ATI Radeon HD5450 1 GB DDR3 VGA DVI HDMI Low Profile PCI...
eBay shows one USED for $19
XFX ATI Radeon HD 5450 HD 545X ZQH2 HD545XZQH2 778656056176 eBay
GOOD LUCK getting a seller to ship to India! Have a friend in the US buy one and let THEM ship to you!
Anthony
Jan 07, 2018 | ASUS Computers & Internet
Fujitsu ESPRIMO P5905 PC Desktop Logo
16 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
