Message error when connecting DS-30 to PC: usb not recognized
SOURCE: olympus ds-30 voice recorder
I don't think the serial number is required to install the software. I didn't see DS-30 information on the Olympus website. DS-40 was the closest one. No information was availbable regarding serial numbers.
I have a VN-4100PC and don't recall being asked for a serial number. The software is the same thing for all Olympus players.
SOURCE: Olympus ds-30 deleted file recovery
on your computer, you will need some sort of media recovery software. also go to options under the tools menu and uncheck delete after transfer to turn off deletion. this is usually best since you can delete the files through the recorder by the erase button
SOURCE: need to download to PC the Olympus DS-2 software
http://www.olympusamerica.com/files/DSSPlayer.zip
After unzipping the file, click on the SETUP.EXE file to begin installation.
License key: 8360 0121 0002 6901 5480
Download update 7.1: http://olympusamerica.com/files/DSSV7UP2EN.zip
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your device to a PC, and have a try of Photo Recovery (also recover audio, voice memos, video files etc), a data recovery program which is good at recovering media files lost. If you are Mac OS X users, turn to Data Recovery for Mac.
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. Regards
