Question about Sony Grand WEGA KF60WE610 60" Rear Projection Television
Picture and sound come and go on antenna or dvd
Tv turns on 30 sec later sound and picture go away for 15 sec then comes back, keeps repeating. when you power off the stand by light flashes 5 times
    Sergeant:
  • 418 Answers
Try another lamp. Error 5 is Lamp power supply, but its usually always the lamp bad.
Posted on May 16, 2014
  • 173 Answers
SOURCE: sony LCD turns off 34 flash turn on 30sec repeats ...
The self-diagnostic function of the projection television will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue, some of which you may be able to resolve without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the television may be overheating. To resolve this issue, ensure that the back of the television is well ventilated.
NOTE: If the television will not turn on immediately after being turned off, wait for the fan to finish its cycle, then attempt to turn it on again. This is part of the cooling process of some projection televisions and is normal operation.
If the flash sequence is not listed above, or the light continues to flash after troubleshooting the indicated issue, follow the steps below to perform a power reset on the television:
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
lno2()
Posted on Dec 14, 2007
  • 3 Answers
SOURCE: Tv cuts off and green light flashes
The Best Solution worked perfectly, I replaced the XL2200 Sony Bulb and the TV is up and running again!
Thanks for the help.
BobE.
Posted on Aug 12, 2008
gsalmen
  • 77 Answers
SOURCE: Turns off after 30 seconds
i think the convergence amps are weak, or the akb circut has caused the tubes to go bad, google your model number to see if it is in the tube problem. sony made some projos w/ bad tubes in them. tv lasts only three or four years,no cause i had one
Posted on Jul 10, 2009
  • 1525 Answers
SOURCE: Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Posted on Oct 25, 2009
  • 3 Answers
SOURCE: screen goes black with green power light flashing.
after unplugging for 24 hours and hitting reset button. look at the replacement of the DM board capacitors.
Posted on Jan 26, 2010
When I turn the set on green leds appear for about 30 sec then it swicthes to red stanby and flashes 5 times intermitently
May I know what is the exact model number of your TV, it is located at the rear cover, manual, and on the receipt. It will help diagnose accurately where the fault came from and confirm the blinking error code.
Jdvillanueva
Jan 11, 2012 | Televison & Video
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Jul 10, 2009 | Sony KP-65WS500 65" Rear Projection...
Press power button green light comes on.But no picture no sound,
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25. Might be your problem.
Apr 04, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Turns on and turns off.
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. OR your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV. Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears .if your tv is very old than it might be due to crt getting weak crt base loose loose contact in power supply thanks
Sep 09, 2007 | Sony KV-32S12 32" TV
Sony Grand WEGA KF60WE610 60" Rear Projection Television Logo
57 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
