Question about Homedics Digital Scale
Error message on the scale - Homedics Digital Scale
What does Err3 mean on taylor body fat scale?
Remove your shoes and socks and wet your feet slightly with a damp cloth if you receive the "ERR3" error. ERR3 is a contact error and your feet should ideally be bare and wet to achieve an accurate body-fat reading.
  • Step off the scale and wait for it reset. Remove your shoes and socks and wet your feet slightly if you receive either the "ERR4" or "ERR5" errors, which means your body-fat or body measurements are out of range.
  • Reset the scale if it doesn't work or you continue to receive error messages. Remove the battery and set the scale on a flat surface. Stand still on the scale for five seconds and step off. Re-install the battery and place the scale back on the flat surface. Place one foot on the scale until it displays zeros or dashes. Remove your foot and wait for the scale to turn off. Step back on the scale to weigh yourself
  • Sep 28, 2016 | Taylor Health & Beauty
    Sw13 scale reads HHH
    Most likely HHH represents an error message telling you the weight of them item is higher than the scale can handle. For example if you had a very sensitive scale that weighed up to 50 carats and you put a 250 carats ring on the scale, it would give you an over load error message.
    May 17, 2014 | NATASHA COLLIS Gold nugget ring with mixed...
    Display gives Error message
    On my scales you have to have bare feet for it to measure body fat index, if you still get err, moisten ythe soles of your feet with a cloth to get a better contact.
    Jan 28, 2010 | Tanita Digital Body Fat Scale with 2...
    I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
    From the Taylor Site http://www.taylorusa.com/faq-scales
    Here are the basic ERR messages and their meanings:
    • Error 0: Initialization
    • Error 1: Instability (scale is on an uneven surface ex: carpet)
    • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
    • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
    • Error 4: Body fat is out of range
    • Error 5: Water is out of range
    I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
    1. Remove the battery from the scale.
    2. Sit the scale on a hard surface floor.
    3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
    4. Re-install your battery.
    5. Place the scale back on a hard surface floor.
    6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
    7. Wait for the scale to turn off again.
    8. Step up onto the scale for a weight.
    If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
    Jan 15, 2010 | Health & Beauty
    How to calibrate a taylor scale 5571
    The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
    If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
    Jun 13, 2009 | Taylor Body Fat Analyzer & Scale, Model...
    When setting Tanita scales specifics, after set, I get an error
    I had the same problem with the error message coming up and emailed Tanita. The regional representative contacted me by email. He had me check with new batteries and clean the contacts. Then he cross-referenced my model and lot numbers and said that my scale was still under warranty and if it met the warranty criteria would be replaced. Tanita has a 10 year warranty on this scale and my scale was 5 years old. He gave me an RMA# to submit with my receipt and about 10 days later I had my replacement scale!! Fantastic Customer Service! Thank you Tanita!!!
    Mar 26, 2009 | Tanita BC550 Innerscan Body Composition...
    Error message ErrL
    My scale had the same problem.  I replaced the battery, but still got the same message.  My wife noticed that one of the feet on the bottom of the scale was loose.  The feet are twisted on to the scale and held by two small flanges.  When I gently pulled the loose foot away I noticed that a small black wire had broke.  I used my fingernails to remove a small bit of the wiring cover and twisted the ends back together.  I then hide the wires back in a recessed area on the foot and placed it back on the scale.  Worked just like the day I got it.   Hope this helps!
    Jan 28, 2009 | Conair Weight Watchers Glass Digital Body...
    ERROR message
    This link allows you to troubleshoot directly with the company...I hope this helps.
    http://www.taylorusa.com/advantage/root/contact.html
    Jan 02, 2009 | Taylor 7506 Precision Tech Lithium Battery...
    Homedics Digital Scale Logo
    97 people viewed this question
    Top Homedics Health & Beauty Experts
    Ankit Chandel
    Ankit Chandel
    Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
