Question about RTO Siemens Phoenix 313 Super-power Digital Bte Hearing Aid
Replace my heraing aid as my hearing aid stop working when i use the phone and can not hear with the hearing aid
R u there
How do I connect Bluetooth capable hearing aids to smart TV?
Hi Gary:
My hearing aid provider (Connect Hearing) provided my unit. It is paired to my hearing aids and is plugged into the audio output.
May I suggest that you review yours with your provider?
Odds are you'll be set up a lot faster than if I were to try to understand what you're working with.
All the best.
Dec 30, 2015 | Cell Phones
T coil. I do not use a hearing aid. Should the t coil be on or off?
Tcoil should be turned off for normal day to day hearing aid use so that the person wearing the hearing aid does not hear a "buzzing" sound. The Tcoil picks up teleloop signals which is a special signal sent out by a teleloop antennae.
Some students with hearing aids use tcoil for special programs that let them hear the teacher. Tcoils were popular in older hearing aids for phone use but now people use Bluetooth in hearing aids more.
Apr 28, 2015 | Health & Beauty
How do you add an app to
Only when your hearing aid has bluetooth, you could be able to connect it to a smart phone. But the manual that came with the hearing aid, should mention what systems are compatible with the hearing aid. Like iOS (Apple), Android or Windows (Microsoft)
Then the manual also will say what app you have to install and how to get it.
Pairing, goes with switching on bluetooth and most of the time you have to enter a code to allow the systems to pair. The code for your hearing aid should be in the manual.
Success
Sep 19, 2014 | Tracfone Wireless ZTE Valet
My right hearing aid is 4 momths old and it stopped working
The Bolero model requires clear passage of sound through the tube that connects it to the dome/tip that fits into your ear. To determine if the tube is blocked, with a good battery inserted and the battery door closed, unscrew the top of the tube where it connects to the hearing aid. If you cup the hearing aid in your hand, it should whistle/feedback. If not, there is something wrong with the hearing aid. If it does whistle, your audiologist should have provided you with a thin, flexible plastic piece (often green) and instructed you how to unscrew the tube at the top of the hearing aid to run the plastic piece through the tube, all the way out the other end of the dome/tip. If that piece can travel the entire tube easily, then sound should be able to. In any case, a Phonak hearing aid has at least a one year manufacturer warranty (a Q90 likely has a three year) and they will pay for shipping both ways to fix it. You need to send it via an audiologist, though.
Jun 08, 2014 | Phonak Bolero Q90 BTE behind the ear...
Dual repeating tone in both aids
Your question is several months old, so I hope you've solved this issue. However, if not, please take the hearing aids to an audiologist for evaluation. It may only be an issue with the batteries you're using (be sure you're waiting 2 minutes after peeling off the sticker before closing it in the hearing aid), a moisture issue (very inexpensive hearing aid dryers are available at your audiologist), or the processor/circuitry may need resetting by the audiologist's computer. In rare cases of this symptom, a hearing aid processor has been overloaded by an outside electronic signal (i.e., MRI, etc.). Please see an audiologist for any of these possibilities.
Feb 18, 2014 | Phonak Audeo S Smart V
I am hearing impaired and want to find a phone which is hearing aid compatible. Would you recommend this phone?
hi there!
yes that phone model is hearing aid compatible:
  • Hearing Aid Compatibility Rating M3/T4
  • you may want to visit the nokia site aswell for more info, but i looked for other nokia phones as well, based on the nokia site, this phone is indeed accessible for hearing impaired. =)
    http://www.nokiausa.com/find-products/phones/nokia-7020/specifications or you can also visit this information site for your quick reference:
    http://www.nokiaaccessibility.com/hearing.html
    post back if these are not helpful!
    Apr 13, 2011 | Nokia 7020 Cell Phone
    Hearing aid tubes for a Electone Tango 3p hearing aid. Where can i get them?
    rimcnaney,
    Where did you get your instrument? This is where I would go to obtain the hearing aid tubes you are requesting. Generally, unless you have the expertise to replace the tube you may be making another problem to solve by replacing this hearing aid tube for an Electone Tango 3p hearing aid.
    Consider this;
    Experience is a hard teacher, because she gives the test first, the lesson afterwords."
    -- Vernon Saunders' Law
    Thanks for contacting FixYa.com
    Nov 12, 2009 | Select Products Health & Beauty
    Hearing Aid Support
    Because every person has a different extent of hearing loss with a different type, this is difficult to answer. Some believe that there are benefits to wearing two aids. Obviously they provide for a more balanced hearing by better directing sound from different areas. Some believe that two aids provide more clarity and allow the user to hear better in noisy locations. A licensed professional or audiologist will best be able to recommend whether one or two aids will work best for you.
    Aug 27, 2008 | Sonic Super Ear - Personal Sound...
    Hearing others
    Nokia n73 i cant pick incoming calls
    Aug 13, 2008 | Nokia N73 Cellular Phone
    Mt phone wont work
    u have a volume buton on the side try that
    Aug 25, 2007 | Sony Ericsson Walkman W810i Cellular Phone
    RTO Siemens Phoenix 313 Super-power Digital Bte Hearing Aid Logo
    26 people viewed this question
    Top RTO Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
