Question about Fender Bassman TV Duo Ten Amplifier
Where is the fuse in a fender bassman tv duo ten?
Fuse location unknown
My fender cybertwin amplifier wont switch on where is the power fuse..
remove the amp. section from the cabinet. you should see a fuse inside near to the main switch.
Nov 22, 2014 | Fender Music
110 volts 220 volts
If not, you can buy a voltage converter
Mar 08, 2014 | Fender Music
I think I may have blown the power supply on my Fender Passport 500 (Part No. 069-1001) when I inadvertently switched the power selector from 240v to 110v. I still had the power cord plugged in and the...
BAD NEG. 15V REGULATOR AND RELATED CAPS IN POWER SUPPLY.CAUSES UNIT TO GO INTO PROTECT. main supply caps and power transformer is gone. possible you'll have to trash. good success, meder's tv service
Sep 15, 2012 | Fender Passport Deluxe 500watt Sound...
My Fender LX1506 powered mixer keep blowing the fuse as soon as i turn it on what is the problem?
There is a direct short somewhere. Is the fuse the right size amps? volts? You dont want to put an dc fuse in an ac power amp. Double check your fuses.
Apr 11, 2012 | Fender Music
Fender G-DEC junior won;t power up the lights don;t come on it has a thermal cutout on the 12VAC transformer it was open circuit i tried bypassing it with soldered jumper still does not power...
Try changing out the Pico fuse. Only 50cents from online West Florida Components. Buy a few. Mine went out twice. It is Item # F021. It is a .5amp (500 mA)fuse-green and looks like a resistor. Location on the circuit board is near the transformer and on back edge or board behind the 2 brown wires connecting to the board and to the side of the 4 diodes there. I left the bad fuse in place and soldered the new fuse to it's legs-a lot easier and does not damage the PCB.
Oct 03, 2011 | Fender G-DEC Junior Modeling Guitar...
Hiss in new fender frontman 65R. Can't seem to dial it out in either input.
A certain amount of "hiss" is present in electronic amps due to the statistical noise in electronics.
The hiss should be WELL below the level you get when playing. If you put you ear to the speaker, expect to hear some hiss with nothing plugged in. Ten feet away it should be very faint.
Dec 30, 2009 | Fender Music
Where to buy fuse
http://www.fender.com/support/amp_schematics/pdfs/Bassman_400_Schematic.pdf Also note there is a thermal protection circuit and a current overload. If the amp turns on and there is no sound start with the speaker to make sure it isn't blown and work backwards through the wiring and connections up to the crossover circuit (all in one cabinet version). On the head separate versions check for a broken output jack problem. The fuses are 10 amp 250 volts for the 100-120 volt models and 5 amps 250 volts for the 230-240 volt models. NOTE: If you are at all unsure about opening your amp up to work on it, take it in to be serviced. It doesn't sound like a fuse problem to me. Necer work on an amp while the power cord is plugged in. Always replace parts with the proper replacement especially fuses. They are there to protect the circuits. If they keep blowing it means there is an internal problem. Remember that capacitors store a lethal charge and it is easy to touch the wrong thing when you are looking inside an amp even if it has been disconnected from power for a while.
Aug 04, 2009 | Music
Fender Bassman TV Duo Ten Amplifier Logo
Top Fender Music Experts
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Larry Stiles
Larry Stiles
Are you a Fender Music Expert? Answer questions, earn points and help others
