Question about KitchenAid Superba Architect KSCS25IN Side by Side Refrigerator
Fridge to cold
Set 38 but lot colder
Freezer doesn't get cold enough (about 20 degrees) & refrigerator is about 38 degrees
check gaskets if ok lower the temp sensor on fridge coils to get colder
Jun 13, 2014 | Dometic RM2652 Refrigerator
Fridge not cold enough
The higher the number the colder the temp is supposed to be.
In order to prevent the formation of bacteria and other such organisms to affect food the way it does, the ideal temperature range of refrigerators has been mentioned here. Before we look at these settings, it is important to know the format in which temperatures are represented within a refrigerator. Commonly, you will notice a dial representing the figures 1-5 or 1-9 in the refrigerator, and a dial representing the letters A-E in the freezer. The ideal setting is usually in the middle of such figures.
If the dial is in such a format in your refrigerator, try a setting at 3 if the range is 1-5, and at 4 if the range is 1-9. For the freezer, a setting at C is suitable.
The ideal temperature in the refrigerator ranges between 34 degrees F - 38 degrees F or 1 degrees C - 3 degrees C. So that foods such as vegetables and fruits remain fresh and crisp, the temperature may be set around 38 degrees F or 3 degrees C.
The ideal temperature in the freezer ranges around 0 degrees F (-18 degrees C) or lower.
Read more at Buzzle: http://www.buzzle.com/articles/refrigerator-temperature-settings.html
Mar 05, 2014 | Belling Refrigerators
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
What cold setting should my fridge be on?
Put both dials on cold and wait 48 hours then adjust from there.
Aug 27, 2012 | Frigidaire Refrigerators
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
Freezer not cold enough
setting the freezer at 7 opens the baffle from the freezer to the fridge to make the fridge colder. It works completely opposite than a person would think. Feel in the back of the fridge with it on this setting. The freezer is dumping all its cold air into the fridge thus equalizing the two parts. if you move the selector to 1, you should feel the air from the freezer cut off in the fresh food compartment. try a setting in the middle and let sit for 24 hours. Hope this helps
Jan 25, 2012 | Amana Refrigerators
I dont understand temp dial on LG 232SBF Frost free fridge freezer
Hello there and welcome to fixya
this is actually a simple dial
this is what they mean
C= COLDER THIS IS THE SETTING IF YOU WANT TO LOWER THE TEMPERATURE FROM LETS SAY 38 DEGREES TO 35 DEGREES THEN YOU WOULD TURN THE DIAL A LITTLE BIT TOWARDS THE C
N= NORMAL RANGE THIS IS WHERE IT SHOULD BE SET AT AFTER IT IS AT THE TEMPS ARE ALLOWED TO STABILIZE
W=WARMER MEANING IF THE REFRIGERATOR IS TOO COLD MOVE IT TOWARDS THE W A FEW NOTCHES THIS WILL INCREASE THE TEMP MAKING IT A LITTLE BIT WARMER INSIDE OF THE REFRIGERATOR
OK? HOPE THIS HELPS PLEASE IF THIS HELPS GIVE MEA GOOD RATING I NEED ALL THE HELP I CAN GET
BEST REGARDS MIKE
Dec 21, 2011 | Radio Communications
My refridgerator freezes the milk, How do i stop it from doing that? The temperature setting is in the normal range and the condensor coil is clean.
There are two setting on a fridge. One that sets the temp of the freezer and one that adjusts the temp of the fridge part. The fridge setting just adjusts the opening between the freezer and the fridge. So the fridge gets it's cool by stealing a little from the freezer. i'd get a fridge thermometer and set it it the fridge and see what the temp really is. The knobs in the fridge may not be accurate. Set the fridge and then move the thermometer over to the freezer and set that. Move back and forth until you get what you want. Usually the lower part of the fridge is a little colder then the top. However if you use the fridge a lot then every time you open the door the cold falls out and the fan will come on and start taking cold from the freezer. Another very cold spot is next to the vent where the cold air comes out from the freezer. Usually up top near the ice maker.
Sep 22, 2010 | Samsung RB215LASH
Kenmore elite coldspot 106.55606400 --fridge not cold enough --
37 is the atual temperature that your trying to acheive. so to make it colder you would go down to 36 which is one degree cooler. hope that helps. thx peyton
Jan 31, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
KitchenAid Superba Architect KSCS25IN Side by Side Refrigerator Logo
13 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
