Question about Hoover Nextra HNL 3166 Z Front Load Washer
Black oil in washing,black sludge emptying grinding noise to the right
    Scholar:
  • 146 Answers
Black oil comes from a leak in the washer transmission seal.
Posted on Dec 06, 2014
What is needing done to stop oily smears on clothing after being washed in beko washing machine
beko front loaders use sealed bearings ..
would suggest try doing several empty hot washes with a strong liquid detergent
and as a tester ..put in a white piece of material
check for oil sludge in the lint filter
if oil persists
have it looked at by a professional
May 27, 2016 | Beko Washing Machines
1997 catera oil gauge is going crazy got oil been checked but they can't find anything help
if oil level and oil good and no noise from engine like ticking or grinding check oil pressure sensor , wiring ,connection ,sludge also check gauge wiring and ground
Aug 11, 2015 | Cars & Trucks
Signs of awheel bearing going on a daf cf85 430 articulated lorry 2004 ?
Wheel initally with start making a washing machine noise or grinding sound when doing sharp turns the opposite of the wheel side as the outer race will generally go bad first. You may also notice the rim heating up due to friction. Grinding at low speed or a growling sound would dictate an inspection.
Mar 19, 2015 | DAF 44 Cars & Trucks
2.4 l has top end rattle what do you think it might be ? im wondering that its lifters
CLATTERING NOISE COULD BE WORN LIFTERS OR OIL CONTAMINATED WITH ANTIFREEZE OR GASOLINE.OR THE OIL PASSAGES IN BLOCK STOPPED UP WITH SLUDGE.TRY CHANGING ENGINE OIL AND FILTER ADD A CAN OF SEAFOAM TO CRANK CASE.DONT OVER FILL CRANK CASE.IF CLATTERING DOES STOP NEW OIL GET REAL BLACK DIRTY.YOU PROBABLY NEED TO CHANGE OIL FILTER AND OIL AGAIN.WHEN SEAFOAM CIRCULATE THROUGH THE ENGINE BLOCK FLUSHING OUT CARBON SLUDGE BUILD UP IN OIL PASSAGES.IT WILL GO TO OIL CRANK CASE GETTING NEW OIL DIRTY.SO CHANGE ENGINE OIL AGAIN.ONCE LIFTERS QUIET DOWN.IF LIFTERS NOISE CONTINUE.YOU NEED NEW LIFTERS.
Feb 13, 2011 | 1999 Oldsmobile Alero
Oil light/noise/oil level good
you could have sludge in the crankcase that is blocking the intake screen for the oil pump ... that happens a lot if oil isnt changed regularly .. in some cars it happens even if you do. ...the clatter you hear is the valve lifters collapsing . they need oil pressure to keep them extended properly ... if your oil pump isnt bad it soon will be .. it needs lub also or it will quickly be damaged ...sometimes you can wash out the sludge with kero/oil mix but the safe thing to do is drop the pan .. clean up the sludge and replace the oil pump.while you are there ...once you have the pump working you can first run cheap oil to clean out things ..then drain and install synthetic ...that will do a better job of cleaning out remaining sludge ... of course make sure you have the proper amount of oil to start with .. make sure there is no water in the oil (milky oil) .. make sure oil filter is not clogged ...some oil filters have a one way valve ... that can stick if the car isnt run for a long time .. ....
Apr 11, 2010 | 2000 Ford Escort
When the internal drum rotates when removing the washing, there is a metal to metal grinding sound.
it's sounds like the berring are going, empty the machine and spin by hand if you hear a scapping noise or rubbing than the berring have gone, in most cases they are a right off
Mar 09, 2010 | Washing Machines
When we wash..you can see oil in the wash tub and smell of strong oil odor.
sounds like the spyder has leaked oil from the bearings into the drum, does it make a grinding noise on spin?
Nov 09, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
I have oil blowing out of the air cleaner and the dip stick tube. I allready changed the plugs (non were black)the truck does not smoke out of tilpipe. I disconected the 12v activaded canester on one side...
A clogged PCV valve or EGR valve is what I'd think of - mainly the PCV valve. Replace it along with any hoses that feed it or that it empties into, since if the valve is bad, or sludged up, it's likely that the hoses have a coating of oil sludge inside as well. A bad PCV will cause excess pressure in the crankcase, leading to oil leaks and losses.
Aug 02, 2008 | Ford F-350 Cars & Trucks
Hoover Nextra HNL 3166 Z Front Load Washer Logo
24 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
