Question about Canon Pixma MG8120 InkJet Printer
Wont print any black
Printer will not print any bacl or yellow
Why wont cyan and yellow print at all?
Use your machines built in programme to clean the ink jet heads
Feb 17, 2016 | HP Officejet Pro L7680 All-In-One Printer
Replaced black ink cartridge, ink wont come out
If any of the ink cartridges need to be replaced the printer will not work. Also, if you are printing only black you will need to go into print properties and select black.
Nov 07, 2017 | Brother MFC-465CN InkJet Printer
My HP 6500 only prints yellow and black. I refilled all three color cartridges and only the yellow is working. Any ideas?
This printer having four cartridges and two print heads.Each print head having two pens, black, yellow & magenta,cyan. As you said yellow & black are OK.. So replace Magenta & Cyan print head..
Oct 28, 2011 | HP Officejet 6500 Wireless All-in-One...
My HPLJ3500 Color Printer wont print black even tho we just put in a new cartridge. Prints magenta, cyan, yellow, but no black. HELP!
Run the PQ troubleshooting diagnostic.
See if the black is printing.
If not, run the Disable Cartridge check. This will allow you print with only one cartridge in the printer. Take out all the cartridges. Put the black in another slot and put the cyan in the black slot(the top). Print the config page. If the black is printing, is the cyan printing. If black isn't printing the cartridge is bad. If black is printing and cyan isn't something is wrong with the printer. If they are both printing put them back in the correct locations along with the other two colors. It isn't the printer.
Jan 11, 2011 | HP Color Laserjet 3550 Printer
Koadak easy share all in one, won't print in bacl
Check the version of AiO software you are using. We had to re-install the Aio Kodak software yesterday because the print que did not register when I changed the ink cartridges. The AiO would scan, but the computer side still thought it was out of ink.
Perhaps the latest software will fix your problem too.
Juliasew
Jan 30, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Magenta and yellow wont print. new cartridges,black and cyan ok cleaned heads
All new cartridges loaded but no black printing. I changed the black cartridge with a second new one but still no black text printing !
Is this Epson 5800 printer a wtite off at this stage ?
John
Dec 12, 2009 | Epson Stylus CX5800F All-In-One InkJet...
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
Wont print
what are you trying to print in black? the best way to test out a black ink is to open word pad and type some thing random and print it and see if that works. if you have a all in one printer u might have 2 inks one color and one black in the printer
Jun 01, 2009 | Brother MultiFunction Center MFC-440CN...
Canon ip 5000
If the print head moves left and right smoothly on the paper as it is printing and all the other colors and black print is ok the surely the Print Head is faulty, get it replaced and your printer will be OK.
Regards,
Joseph Manoj
+91 9352008418
Jun 28, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Ink cartridges wont print
same problem!!!!! temping to get another printer - help!!!
Dec 19, 2007 | Canon BubbleJet i560 InkJet Printer
Canon Pixma MG8120 InkJet Printer Logo
24 people viewed this question
old marine
old marine
