Question about Acer Aspire One AOA150-1784 Netbook
At power on I get no display (black Screen), no beeps, and appears no HDD activity. Power on led stays on and steady, Battery indicator is green and steady.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 13 Answers
My dear you need to update bios that is right and easy way no need to unscrew or anything else............
Posted on Jul 10, 2009
    Champion:
  • 381 Answers
Hello.open the covers on the Hard Drive and Memory.remove both of parts then clean the memory stick/SODIMM then put it back only memory the HDD later u put it.good luck sir/mam and Have a nice day..
Posted on Jun 15, 2009
My 19v712m manga box tv goes black
The steady blue LED merely indicates that power is getting to your TV. The internal power supply may have failed
May 15, 2013 | Televison & Video
The battery backup beeps and the service light is on. The battery tests good with a volt meter
This is battery related. On top of your unit is a battery pack with three colored led lights. You can tell what is going on by looking at these. This information is in your manual or here it is.
GREEN LED: All systems are normal. A solid LED light indicates the batteries are fully charged. A flashing LED indicates the batteries are being charged. NOTE: Batteries do not have to be fully charged to operate the motor unit. YELLOW LED: The motor unit has lost power and is operating off of the BBU. A solid LED with beep, sounding approximately every 2 seconds, indicates the motor unit is activating the door and is operating off of the BBU. A flashing LED with beep, sounding every 30 seconds, indicates batteries are low. Once the power is restored the BBU will recharge. This is indicated by a flashing green LED. RED LED: An error has been detected and the BBU will automatically shut off. The BBU will attempt to restart by reconnecting to the batteries. If the error is still present it will shut itself off again. This process will repeat every 5 minutes or until the error has been resolved. This is used to prevent further draining of the batteries. If a red LED remains on when the power is restored, and is accompanied by a beep sounding every 30 seconds, please call for service.
Dec 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
MY SCREEN IS BLACK IS THERE ANY WAY TO FIX IT
if there is no power getting to the monitor ( indicator light ), test the fuse in the power lead first.Ensure it is inserted tightly.
If there is power to the monitor, the green indicator light should be steady, if it is flashing there is a problem with the display
Test the monitor in another computer or laptop.
If t stays black , I'd supect a faulty backlight or more probably a blown power capacitor whih will need checking and replacing
Dec 30, 2010 | HP L1955 19" LCD Monitor
Opener beeps
Nov 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
My acer aspire ones screen is just staying black and wont reboot what do i do ?
I have the same problem! I received a response to my email telling me to disconnect adapter and battery, hold the power button 30 minutes, connect ac (make sure it's plugged), turn on, wait 1-7 minutes, then attach battery after windows boots. After several tries, it still hasn't worked. When I turn on the system, my power led stays green, but the hdd indicator is not lit. My battery can still recharge, but the screen is still black, and there is no sound.
Apr 16, 2010 | Acer Aspire One Netbook 8.9" Notebook
Gateway 503gr has no power, the standby light flashes green when I remove power. Tried new PS and the standby LED stays lit. I then tried both new and old PS disconnected from board and shorted...
Disconnect everything from the motherboard except the power supply connections and cpu fan. Install one stick of RAM and connect your monitor. Then try starting up. See if you get any BIOS boot messages. This will tell you that the board and processor are okay.
With what you say you've tried already, I'm thinking you might have a bad processor. Most every other problem would result in some kind of error like POST beep codes or messages on screen. If the system still doesn't boot with the bare minimum parts installed, replace the processor.
Mar 02, 2010 | Gateway 503GR PC Desktop
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
Acer one AOA 150-1786 running Windows XP SP3 Home Ed.
Those signs are those of a dead motherboard, it is quite expensive to fix i would recommend to replace it with your dealer
Jun 15, 2009 | Acer Aspire One Netbook 8.9" Notebook
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Acer Aspire One AOA150-1784 Netbook Logo
195 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
