Question about GE G.e. Gtwn4950lws He Top Load Washer
How to remove rust from edge of washer lid
Inside rust on washer lid on bottom edge , how to remove the rust
I want to remove the lid only
Rusty on the edges
Maureen, I would just leave lid in place,Tape lower part under lid with duct tape to prevent scratches, then sand as much rust off as you can, then 2 coats of a good rust primer(Tremclad) and paint. Use masking tape and newspaper to cover areas not to be painted.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 29, 2016 | Washing Machines
How do I take the lid off my Simpson ESIset 750 as it is rusty on the edges
How do I take the lid off Maureen,Go to link below and download your manual, Bottom of page 14 tells you how to remove your lid and reinstall.
22S750N
Mar 29, 2016 | Simpson Washing Machines
Need to remove the glass lid to get to an area of rust caused by a maytag technician chipping the paint and they won't fix it
Tape the washer lid closed. Using a putty knife, press and unlock the two front top locks. The locks are approximately six and a half inches from the outside edge of the washer
Mar 10, 2014 | Maytag Bravos MTW6600T Top Load Washer
Maytag clothes washer model 2500 aae leaks along bottom edge
Sounds like a hose leak inside the machine. Possibly remover front bottom cover then check all hose connections.
Nov 14, 2013 | Maytag Washing Machines
How do I get to the lid switch on Frigidaire washer dryer combo? I need to get the washer top off, I am guessing. But where do I do that? Product replacement site states removed 2 screws from rear
Actually, if you look at the front panel on the washers bottom edge there are two screws located a few cms from each edge. Unscrew and grab both edges of panel and pull down. Whole front should come off and switch and mounting is visible and simple. Repeats steps opposite to get panel back on.
Sep 27, 2011 | Frigidaire FLSE72GC
My Kenmore 20902 washing machine lid is rusted. I...
Hello, Guest who?
Getting the lid off of your Kenmore is simple. Raise the lid. At the bottom on each side are a pair of screws that go through the lid and attach to a reinforcing bracket on the inside. Take these screws out, remove the bracket, do the same for the other side. A small bowl or ziplock will keep these small bits from getting away. When you have repainted or replaced the lid, insert the bracket with the loop down, and insert the screws from the outside through the lid.
Done!
May 19, 2010 | Kenmore 24032\24036 Top Load Washer
Have had numerous items ruined due to brown stain
My Maytag Front Loader also has periodically caused rust stains on clothes. After investigating it I determined the cause.
The top of the machine is rusting around the opening under the lid where you add the detergent, fabric softener, and bleach. Water apparently splashes up on the bottom of the lid and it rusts. The flakes of rust then flake off and fall into the plastic reservoir and are washed into the machine. The only fix is to replace the top of the machine, or take it off, physically clean off the rust and apply a coating of rust resistant paint to the inside. A quick fix is to remove the plastic cover (4 phillips screws) and clean as much rust off around the edges as you can. Be sure and keep the rust from falling down the hole where the water flows into the machine.
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore elite washer lid removal?
how do i remove the washing machine the top
Oct 20, 2008 | Washing Machines
Removing top component
kenmore washer
remove left right edge trims of control panel
remove phillips screws from bottom edges of control panel
slide control panel forwad and up ~1inch
flip control panel over the back
remove bronze body springs
remove lid switch connector
lift body ~1inch slide forward and off
reinstall in reverse order
Aug 10, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Help with Kenmore washer
most often the lid swtch is out of alignment, less often the switch fails
with the lid open examine the underside of the lid for the plastic 'tooth' that is supposed to engage the switch, if broken or missing replace, test
with the lid open and the washer turned on, use a ballpoint pen to engage the switch plate in the hole at the right side of the lid
If the washer starts, adjust the switch position, test
If the washer does not start
remove the edge trims from the console
remove the screws from the lower corners of the console
slide consloe forward ~1/2 inch, flip up and over
ensure cable is connected to lid switch connector
try lid switch again with ball pen
if washer does not start the switch has failed,
remove metal retainer clips from rear of washer top, remember installed position, you have to put them back
lift washer case 1 inch slide forward, lay down, remove switch
replace
reassemble in reverse order, test
3-5 times a month, takes about 25 minutes, the switch costs $7.95+tax
Aug 02, 2008 | Kenmore 15864/15862 Top Load Washer
GE G.e. Gtwn4950lws He Top Load Washer Logo
18 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
