Question about Lucent Lands Phones
Replacesysbat w/poweron the phone says "replacesysbat w/poweron"
When I turn on my phone it has a blue screen with a sad face
if the phone internal memory content isn't priceless for you use: windows phone recovery tool
http://windows-phone-recovery-tool.software.informer.com/download/
or try to swap to factory settings,it also cleans internal memory user data by using Lumia method:
Unplug the charger
Turn off the device
While pressing and holding Vol- key plug the charger.If it wirks,the screen will show you this:"(!)"
(To abort the operation press and hold both Vol- and PowerOn keys during 10 sec.)
Then press folowing keys:
Vol+ key
Vol- key
PowerOn key
Vol- key
If you see a couple of gears on the screen-the process of swapping to factory settings has begone,wait a few minutes,the device will turn on by itself.
after that you can try to recovery lost in internal memory myltimedia
May 22, 2016 | Blu Win JR Smartphone Unlocked
How to fix a gts- 5300
First of all, when you tray to unlock it with gmail, you must be near to WiFi network that you used before (you must have connection to the internet).
Second, if your WiFi connection is turned off from before, you can't unlock it with your google account.
Next step is to try wipe data / factory reset from android recovery menu. Press and hold VolUp+PowerON or, VolDn+PowerOn, or any combination like this with PowerOn button. But you will lost all your data.
Regards.
Feb 05, 2014 | Samsung Cell Phones
On the display it reads: ReplaceSysBat W/Power On...I need a picture of where the part I'm trying to replace goes. Where does the batteries go in the partner 18d phone? Is it located undernearth the...
There is a battery compartment on the lower front of the processor card. Your phone system should look something like the pic below. the processor card is the one on the far right. There is a battery compartment towards the bottom of it. Whatever you do don't turn the power off while you replace the batteries. LEAVE IT TURNED ON or you will lose all the programming.
Aug 25, 2011 | Avaya Corded Phone avaparp18d
ChgBat w/powerOn on id screen
Go toy your phone system. There is a battery door at the bottom of the processor. Change the batteries. DO not disconnect power or all programming will be lost.
Mar 29, 2010 | Avaya MLS 12D Corded Phone
My n70 lock idrunk and i don't open it
formate phone press * +3+call button + poweron button.
Jan 10, 2010 | Nokia 1600 Cellular Phone
I have a message that says replacesysbat w/power on what do I do
Well, then you have a Partner ACS. Go to the phone system, in the center of the 5 slot carrier, is the processor. You will see on the bottom, there is a grey cover, with a black poece that slides up. Slide black piece up and pull out the battery holder. Replace the batteries and reinstall. Make sure you do all this while power is on, as the programming will be lost if it loses power, those batteries keep programming if the power is lost.
Dec 17, 2009 | Avaya 5610 IP Phone
I tried turning my phone off and it didnt work and i have no idea what happened to it...
Take out the battery. Then insert the battery again and see if the phone restarts. if it does then your poweron switch is stuck in pressed position. Or it is faulty. get it repaired. if it does not poweron then the switch may be alright. Poweron the phone. It should. Then try to poweroff the phone. should work.
Aug 23, 2009 | Cell Phones
I have a nokia 6500s-1 slide phone and my 3 yr old daughter pressed something while she had it, and now i'm locked out of the phone, tried all I can to no avail. Can't give you an IMEI number as the phone...
It seems that the keypad is locked. Does your poweron? If yes then press the poweron switch and you will find an option LOCK KEYPAD or UNLOCK KEYPAD. If it is the earlier then your keypad is free. If the later then select Unlock option and free up your keypad. If former then your there is no way that you can unlock your phone except re-installing the firmware. The IMEI number is below the battery. But, it will not help despite everyone asking for a SW generated password. get the firmware re-installed. It takes about half an hour.
Aug 12, 2009 | Cell Phones
Lands Phones Logo
13 people viewed this question
Top Lucent Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
tfelton3
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
