Question about Video Game Consoles & Games
Crystal white ps3
Has a hard time spinning and starting but will work after opening and closing a few times
2 Suggested Answers
litwinski10
  • 28 Answers
SOURCE: problem reading disk. Need to continue to open
i had same problem u NEED A NEW LENS a SWEAR once u change lens it will work perfect very easy to replace 7 pounds off internet
Posted on Nov 26, 2010
My Pontiac G6 Sunroof is stuck in the vent position.
might try spraying white lithium grease on the slides and open and close few times my g6 did the same thing grease it and open and closed a few times then it work
Feb 28, 2015 | 2006 Pontiac G6 GTP
How can you tell if your master cylinder is bad
Your problem is listed uner the "Clear White Soft Silicone Skin Case + Hard Crystal Case for Sony PSP 2000 3000" but you are asking about a master cylinder. Most times if your master cylinder is bad this will lead to engine knock and misfiring and can destroy your engine.
Oct 20, 2013 | Eforcity Clear White Soft Silicone Skin...
My 6.5 wf s6607TC will spin for a few times then would stop and keeps beeping. Ii tired opening and closing the lid but it didnt stop. Then i left it beeping, it would stop on its own but then it wont...
When it spin for a few times then stops the beeping is telling you to redistribute the washing(clothes) in different positions as it is out of balance Opening and closing the lid without doing this is a waste of time as you haven't fixed the problem.
Mar 09, 2013 | Washing Machines
Whirlpool High Capacity washer, start cycle , it fills with water then no agitation, and no spinning.
next time send the model number,open the lid,look on the right side and there should be a hole in the top,that's the lid switch,it's used so the washer won't run if the lid is open for safety reasons,set it to spin and with a screw driver push down on the plastic piece in the hole,if nothing happens push in and release,do this a few times,if you don't hear a clicking sound when you push up and down the switch is bad or close the lid and open it an inch,close it and open it a few times,no clicking sound the switch is bad.
Jun 12, 2011 | Whirlpool 3.2 cu. ft. Washer
Have a kenmore elite washing machine which i purchased in 2005. The machine will stop in mid cycle and will start again when the door (top load) is opened and shut again. Could this be a problem with the...
what cycle does it happen in?close the lid and open it a few times,does it make a clicking sound,if it does i would say the switch is good,also you can do this,next time it happens open the lid carefully without banging the machine so you don't disturb anything,get a screw driver and stick it in the hole and see if it runs, if it does i'd say it's the switch,but i've seen this before right before it goes into the spin cycles,the clutch doesn't fall in the tranny. and when the lid is opened and closed the clutch falls.keep an eye on it and see where on the timer this happens,make a mark and see if it does it in the same spot,depending on how hard you close the lid it could be the switch,the timer sticking,i've tapped the timer when something like this happens and it sometimes starts or the clutch in the tranny,when you close the lid did you ever notice if you heard a clunking sound and then it starts to spin..also if you open the top console,unplug the lid switch and stick a jumper wire in the two outside holes of the part you unplug,the lid switch is closest to the right side clip and it's a white connector, you can bypass the switch to check it, all it is is a safety so the machine won't run with the lid open or instead of doing that you can stick a screw driver into the hole and let the machine run like that if you think it's the switch,let me know what you find.
Apr 19, 2011 | Washing Machines
A few times the washer water drained but cloths were what we thought still to wet.I tried a spin cycle and it was not working.I then turned the auger a few time and retried.It then started to work.I have...
Try checking the small button under the washers loading door. If you open the door, under it there should be a switch or button looking sticks out. This offen breaks off. If the switch does not work it will not let the spin cycle run - you know when you open the washer when its running and the spin cycle turns off until you close the door again - thats the switch.
Costs about $3.00 east to install with a screw driver
hope thats the problem - aloha
Feb 13, 2011 | Kenmore Washing Machines
Game Saints Row 2 keeps freezing at certain points in the game
maybe you should try different games? see if those different games freeze, if so, then it might be your blu-ray player in your ps3, or your ps3 might be overheating. my games froze at certain points because my ps3 was overheating, just try a few different games
Jan 06, 2009 | Sony Playstation 3 (PS3) Console
Whirlpool Washing Machine Quitting during rinse cycle
I would say that based on your problem description that the lid /door switch has a loose or faulty contact .. If you open and close it a few times..it starts to spin and yet when you open it.. it doesn't always stop the spinning.. It is either the switch or the actuator that bumps that switch.. That is where I would begin diagnosing the problem... Hope that helps..
Aug 30, 2008 | Washing Machines
Broken PS3 with disc stuck inside.
Power off your PS3 (important)
hold the PS3 up in the air with the loading slot facing down.
Power on the and start pressing the eject button (if you can call it a button)
It took a few times but it will work;
Apr 25, 2008 | Sony Playstation 3 (PS3) Console
Washer won't start spin cycle
sounds like a lid assy issue, can you hear a "clicking" just before the lid is closed, try opening nad closing a few times listening for a distinct "click" if not the machine doesnt think the door is closed and for safety reasons wont spin and drain.
Mar 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Video Game Consoles & Games Logo
11 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
