Question about De'Longhi 1750w Easy Turbo Steam Iron - FXG175AT
Won't heat up
Lights up but no heat
My rowenta Dw9280 steam iron won,t heat up.
Failure of heating element, control, or both
Mar 14, 2018 | Rowenta Irons
Steam switch won't work
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
God bless you
Apr 01, 2013 | Rowenta Irons
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
Rowemta DA1560 won't turn on
1) No voltage to receptacle
2) defective cord or terminal connection
3)open thermostat
4) open heating element
4a) the heating fuse blown
5) test the outlet wal with lamp desk, if work, the iron is the problem follow the steps before mentioned. reset the c.breaker or change the blown fuse is necessary.SEE the diagram
God bless you
Sep 09, 2012 | Rowenta DA1560 Iron
Remington pearl plates won't heat with blue light?
1) you have to test the power cord for broken or fault with VOM
2) inside there are thermal fuse, test it and replace with VOM
3) test the heating element for open and replace, and test for ground
4) test the thermostat, and adjust it.
God bless you
Jul 22, 2012 | Remington T-Studio Pearl Ceramic 1" Slim...
Iron won't come on or heat
Hi
The problem could be the power cord or the element.
Try replacing the power cord first and see what happens.
Feb 28, 2012 | Irons
My Iron will not turn on! It hasn't seemed to heat up right lately anyway,but now it won't heat up at all.
Has found all with detailed operation and with comment that from itself this model.Manual HERE
Jul 29, 2011 | Rowenta Irons
No steam from a grime buster steam cleaner what is wrong?
Check the water reservoir for clogg. Be sure that the cleaner has water on it and it is heating. .If not heating there you'll sure it won't give steam. Check the heating element for open or no continuity.
Heated water needed to generate or produce steam and you'll need a continuity tester to test it. Replace it with similar model and rating also with same size.
Good luck.
Jul 07, 2011 | Irons
My iron won't heat. it has electricity but won't heat
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Ironnot Heating Up or not Working Right heatman101
Jun 25, 2011 | Rowenta DE-480 Iron
My iron's MODEL: 14977Z The iron's red light is on but won't heat to iron. was working a couple of hours ago
This is typical of a iron, it is cheaper to replace than to repair. The heating element is broken.
Jun 02, 2011 | Hamilton Beach 14977 Iron with Auto...
De'Longhi 1750w Easy Turbo Steam Iron - FXG175AT Logo
27 people viewed this question
Top De'Longhi Irons Experts
Are you a De'Longhi Iron Expert? Answer questions, earn points and help others
