Question about Lexmark Wheelwriter 10 Series II Typewriter
CARRIER THE CARRIER IS GETTING STUCK WHEN RETURNING FOR NEXT LINE
  • Lexmark Master
  • 3,594 Answers
Try some WD40 on the silver shaft that the carrier slides oin, if that doesn't do it lube the bearings on the carrier motor. It is located under the case in the R. rear corner.
DickyO
Posted on Mar 28, 2014
Brake Caliper will not release
The only things I can think of is ether a kink in the right side brake line or the proportioning valve is clogged or stuck or the ABS valving is clogged or stuck. Its possible the system has become contaminated with moisture???
Mar 05, 2013 | 2004 Ford Mustang
I have a 1993 Lexus SC 400 with a Nakamichi sound system. The 12-disk CD player in the trunk has a problem. CDs won't play because they get stuck halfway between the CD carrier and the internal part of the...
remove that cd carrier and replace it with a proper one that fit that place.
u might need to make it in ur own take the mesures and make one its easy u the man!!
follow me rate me!!
Aug 16, 2008 | Nakamichi Car Audio & Video
When I reach the end of the line and press enter, it goes to the next line but not to the beggining. Instead it jus come back a few cm. When I try to accent a word, it jumps a space. Pedro
Not returning is likely lubrication. Put a shot of WD40 on both sides of the silver shaft that the carrier slides on, and s a shot on the front and rear bearings of the carrier motor located under the case at the R. rear corner. You can reach the front one from inside the case the rear one you must fish nthe straw thru the case or remove it. The jumping a space I don't know if you are talking a vertical space or a Horz. space. You can put it a language mode (CODE "L") that eliminates spaces on "P" & "L".
Go to http://support.lexmark.com/index?page=content&id=SO4998&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT for a manual. I suggest you copy and paste this address.
DickyO
Sep 08, 2011 | IBM Office Equipment & Supplies
Air condition not cooling
If this is a heat pump it sounds like the reversing valve is stuck in the heat mode, replacing it requires opening the sealed system, which needs to be done by a licensed ac repairman.
Apr 17, 2010 | Carrier 38CKC060 Air Conditioner
Fuel not getting to motor, changed fuel filter, fuel pump is ok
Possible that you have a clogged line but more likely that your fuel pressure regulator is stuck open and the fuel is just bypassing the engine and returning to the tank. I would start there.
Sep 23, 2009 | 2000 Chevrolet Silverado 1500
My Carrier compressor model 38BRC060360 is getting loud. Does that mean it is going to fail? Thank you.
when you say "getting loud" is this only on start up or when the unit is operating? If it is on start up it could be a problem with the starting components, or with the time delay not allowing enough time to equalize on the off cycle. during operation it could be that the charge is incorrect, as the compressors are cooled by the suction gasses returning to the compressor, over or undercharge could cause excessive noise. It could be your mounts that hold the compressor to the case as well, there is not sure way to tell if it is getting ready to "go out" without performing regular megaohmmeter checks, and this process must be started when the unit is new, and checked periodically over its life.
Jul 12, 2009 | Carrier 38BRC060 Air Conditioner
Brakes are smoking
sound like brake caliper lock up .master cylinder pistons not returning.check brakes or hoses for restriction. your parking brake adjustment incorrect.
Jun 22, 2009 | 2000 Plymouth Grand Voyager
Nakajim AE-710 Will not return to next line indents & makes noise
Check for debris below and around the carrier, put some light oil on the silver shaft that the carrier slides on (wd40 works well) DickyO
Jun 11, 2009 | Nakajima AE-710 Typewriter
Line 1 of my phone is always busy.
From your description it sounds that you have a short on your Line 1. Its either on DMarc of your carrier or it cross connected improperly. However your post is not clear on voicemail. In normal operation if busy it doesnt go to voicemail.
Call your carrier first and report troubled line. Their technician will tell you what to do next.
Mar 15, 2009 | Panasonic KX TC1451 Cordless Phone
Ink cartridge
Not quite sure what you mean but if it is stuck under the housing then that would give the error. Could it be that the cartridge wasn't installed straight and this has caused it to become jammed?
Oct 08, 2007 | Dell 922 All-In-One InkJet Printer
Lexmark Wheelwriter 10 Series II Typewriter Logo
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
