Question about Sony KLV-S19A10 19 in. HDTV-Ready LCD Television
Audio distortion on VHF/UHF 75 ohm input
Have a Sony 19" LCD HDTV (KLV-S19A10) with analog tuner. The rf input for VHF/UHF yields a decent picture but the audio is distorting, crackling and yields a low volume output. There's a reason I'm using this input which I will not bore you with.
I have troubleshot with other cables and TVs.
On my old Sony crts, there is an internal service menu of additional settings that you access via the remote control.
Does anyone know if the same exists for this model?
If "yes", can you list the steps needed to access these settings?
If "no", do you think adding a 3, 6 or 10 db attenuator may correct the audio problem?
Or lastly, do you think that is this an internal problem on the circuit board?
    Scholar:
  • 89 Answers
Please try the steps provided below and check if that helps.
Press the WEGA GATE on the Remote Control.
Then, select the SETTINGS option in the Menu.
Then, select the AUDIO Settings.
Then, set the STEADY SOUND option under the Audio Settings to AUTO.
Also try changing the MTS Setttings under the Audio Settings.
Posted on Jun 18, 2009
I have an rca G36705 and I just need to know if it has a digital tuner or if o need a converter box to hook an antenna to it?
Its inputs include "Composite" and "S-Video".
Itttkk Its *ANALOG* tuner has channel coverage:
VHF:2-13, UHF:14-69, Cable:1-125, VHF:2-13, UHF:14-69, Cable:1-125
So, you will need a digital tuner.
So
Jun 05, 2015 | RCA Televison & Video
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
Cable input is grounded
This isn't an answer to your problem, but I just wanted to point out that your continuity tester may be misleading you. Cable inputs often have transformers on their contacts, both for impedance matching and to help isolate sensitive electronics. Those transformers are usually just a couple of turns around a very small iron core, and while they may look like a standard 75 ohms at VHF and UHF frequencies, they will look like dead shorts to a DVM or continuity tester.
Regarding your digital channels, I was somewhat surprised to discover that modern digital TV transmissions use the same VHF and UHF bands older analog TV did. And if the cable signal is poor for any number of reasons, it will still mess up the picture. Only now, instead of snow in the picture, you get weird pixelation that can resemble some kind of acid trip. If you're using an antenna, you may have to check it, its cable, and any new structures or structure changes in the area. If the signal comes in from a cable provider, you might have to get them to come and test your levels.
Nov 01, 2017 | Dell W2306C 23 in. HD-Ready LCD Television
Dvdr3320v will this model record digital tv programs
This device has 2 composite AV, 1 S-Video, 1 Firewire, 1 RF video inputs. The RF input is a way for it to accept a signal from say a VCR's or Video Game's output on Ch 3 or 4.
Your device also can record via internal tuner.. The tuner can tune VHF:2-13, Cable:1-125 and UHF:14-69. Unfortunately, if you only have a UHF / VHF antenna on your house for TV (do not have cable TV, satellite TV, or the like) you're not going to be able to find anything due to the change from analog TV to digital TV. For this, you would need to purchase a digital TV converter box, and put the output of it into the the DVDR3320V.
I hope this helps and good luck. Please rate my reply. Thanks.
May 06, 2011 | Philips Televison & Video
How do I connect an analog antenna to a 32 inch sharp aquos tv? and do I need a specific input setting?
antennas are not analog or digital, just VHF, UHF and they typically connect to a RF coaxial jack on the TVs rear panel. 75ohm silver round jack. Select in your TVs menus, AIR when you want over-the-air TV stations and do a new channel scan to pick up local channels.
May 06, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
What cable do I need to set up the HD and where do I plug it in? All the ones I lookes at have a rectangular end and I don't see one on the like that on the TV. I am using the 2 scart sockets for cable...
Any of these will work.
ANTENNA IN: UHF/VHF 75 ohm Din type (If in HD Broadcast)
EXT 1: SCART (AV Input/Output, RGB Input, TV Output)
EXT 2: SCART (AV Input/Output, Y/C Input, AV Link)
EXT 3: S-VIDEO (Y/C Input), RCA pin (AV Input)
EXT 4: RCA pin (Vomponant Input)
PC INPUT: D-sub 15 pin (ANALOG RGB), 3.5mm Javk (Audio Input)
Service Manual can be found here: http://www.givemefile.net/smanuals/lcd_tvs/sharp/file/45437.html
Feb 06, 2011 | Sharp Aquos LC-26GA5E 26 in. HDTV-Ready...
I can't program my tv to regular antenna channels
You can program to regular (analog) antenna channels. To do so you must use the original remote which has a TV/DTV switch in the top right corner of the remote. Choose the appropriate mode for the type of channel you want to see or scan for. Here is a link to the owners manual and a picture of the remote swithc. The info on the signal switching is on pg.13.
http://tv.manualsonline.com/manuals/mfg/funai/cr130dr8.html?idRes=707655
Oct 27, 2010 | Durabrand DWT1304 13" TV
I am not good with electronics. Have bought a jensen antenna for a tv - tv611 - how does the UHF n VHF wires both fix into the 300/75-ohm balun????
Go to walmart but UHF/VHF connector,one that you can connect both wires too and then plugs into TV.Cable IF
Aug 21, 2010 | Televison & Video
Vizio P50HDTV10A 50 in. HDTV Plasma HDTV Tuner out
The HDTV tuner is out. Analog tuner, and video inputs work fine.
TV Model P50HDTV10A
Screen Size 50 in.
TV Manufactured Date Jan 1, 2007
Part Type MAIN UNIT
Alternate Part Type SIGNAL BOARD
Part Number 3850-0042-0150(3A)
Alternate Part Number 0171-2272-2163
Jan 08, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Sony KLV-S19A10 19 in. HDTV-Ready LCD Television Logo
95 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
