Only filling in water
Wouldt start
Washer wouldt drain water or rinse or spin
What is the complete model number of your unit?
Nov 24, 2012 | Kenmore series 90 Washer Motor 3349643-
I had to manually unlock my washer when it wouldt cancel for me, so now i can open door, but when i plug machine back in it locks and makes draining noises again, nothing else but draining
A model number would help a lot, but I'll take a shot at this. Typically, when a washer locks out, requiring a manual unlock, it does so after the machine fails to drain within a specified amount of time. So, that being said, if your machine does not have water left standing in it, there is a good chance you have a bad pressure switch, which is telling the control that your washer is still full of water. With many models, one way to test it would be to disconnect the wire harness from the pressure switch, then try to start a cycle. If the washer then begins to fill normally, replace the pressure switch. Before jumping to the pressure switch though, make sure ALL the water is drained out of the washer, and unplug the machine for several minutes to allow a CCU reset.
Mar 17, 2011 | Washing Machines
Dishwasher does not fill with water when started. Problem began slowly with dishes not rinsing completely. Overfill float appears to work properly. Water fills pipe leading to fill solenoid but does n
I am almost certain that your problem is the fill solenoid.
If it does not work, there will be no water entering your machine.
I would either remove it and test it or just replace it at this point.
Tim
Apr 16, 2009 | Dishwashers
Water pump not pumping water through engine
it sounds like there is a blockage in the system look for very stiff coolant lines or it coulc be the heater core in the cab or on the fire wall. is the engine getting up to temp ? or is it just not getting hot in the cab?
Feb 13, 2009 | 2000 Jaguar S-Type
My palm centro wont turn on. it has the red light on but its not on the charger
hey i had the same problem but just a tad different, my phone just wouldt turn on in general so i plugged in the phone and just started messing with the keys, i dont know if that will help but its worth a try
Jan 21, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
10 people viewed this question
Top Washing Machines Experts
