Concertmaster Baldwin too loud
Our ten year old upright Baldwin concertmaster piano is too loud. I heard there wake a chip that could allow a softer sound, one that would still have all the keys being heard
  • 1138 Answers
SOURCE: I have a Technics digital piano with 1 dead key.
If your piano is the same as mine, there is a rubber membrane with contacts imbedded in it that sits on top of a circuit board. The key pushes the contact in the membrane onto the contact causing a note on. What happens is the cylindrical part of the membrane that holds the contact can get torn and the contact will no longer travel in a straight line to trigger the note. The entire membrane strip has to be replaced. The strip on my piano was discontinued and I had to manufacture one from an extra Roland membrane that had some bad contacts in it. You will have to contact Technicsat www2.panasonic.com/webapp/wcs/stores/servlet/PNAEndecaSearchCmd for support. If you don't feel comfortable tackling the repair yourself consult a good piano tuner/repair place in your area for advice.
Posted on Jun 23, 2009
  • 82 Answers
SOURCE: Kenmore top freezer, Refrierator shuts off with loud clunk.
It sounds like you may have a compressor that is working hard against high pressure due to a dirty condenser or a condenser fan not running or blocked. If all is well otherwise, the mounting springs inside the compressor may have broken or are weak. The only fix then is a new compressor.
Posted on Jun 26, 2009
  • 5603 Answers
SOURCE: It's a Roland HP-7e digital piano about three years old.
You may need to clean the contacts which are usually conductive rubber. I explained stuff for another Roland problem with two keys that were intermittent. I have an EP-7 that I had to do the cleaning of the key contacts. Use 91 or 99 % Isoprophyl alcohol to clean BOTH the conductive "pill" (Black under silicone rubber domes) AND the traces on the board where they press. Clean gently as the traces have a hard black coating.
Posted on Jul 29, 2009
  • 5603 Answers
SOURCE: Kurzweil digital piano unpredictable voices and volume
The contacts of various switches and keys are likely dirty. They are often conductive rubber and need cleaning with 99% isoprophly alcohol and q-tip. Clean both the conductive rubber pill and th circuit board traces they contact.
Posted on Sep 17, 2009
  • 5603 Answers
SOURCE: I have owned a Technics
You don't tell us the model, but most have a "demo" button which is first pressed and then there sometimes is a start and stop button tto control it.
Posted on Aug 16, 2010
I was wondering what the age of our baldwin piano serial #399572 is. thank you for any help
You did not state model, Check the attached links,for your model.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.pianoworld.com/baldwin.htm
Free Piano Age Research
Baldwin Piano Age
Baldwin Pianos Company History Serial Number Search
Mar 10, 2016 | Music
Chas f. Netzow upright piano Serial number 47686
I should write this out to save me keep typing it. Remove the front of the piano and the lid for the keyboard. Remove the middle C key completely. You may find the manufacture date and its full service history written in pencil on the side of the key.
Netzow Piano Co. Brand Name: Netzow Piano Co. Parent company: Netzow Piano Co. Location: Milwaukee, Wisconsin Serial Numbers Available: yes First date listed: 1904 Last date listed: 1931 Other brands:
Answer
Hi Robyn:
serial 10305
This was one of the original pianos made by this company in 1904. The serial number is the determining factor in telling a piano's age.
The worth rests on the piano's viability, configuration, and age.
Old uprights are generally worth little, especially if they are not serviceable. The furniture value is secondary.
If your piano is in perfect condition, inside and out, the value would top out around 200.00, USD.
What you have there is a typical upright piano, which more than likely has more furniture value than instrument value.
Age is not good in the piano world and pianos deteriorate year by year whether they are played or not.
Are you using this piece as furniture, or instrument?
9k= 3 yearsy ago #3 jim H. Guest I have a Netzow upright #41459. What is the manufacture date?
Made in 1913.
Netzow Piano Serial 13072 What is its manufacture dat
Feb 07, 2016 | Music
What is the year and worth of my Baldwin Howard upright piano? The serial number is 926365.
This is something that can only be given in person as we can't see the items condition, play it or hear it.
Jan 08, 2016 | Music
I have a Baldwin piano, I purchased around 1985 serial number 353361. How old and what would the value be? It is a dark oak and an upright
I am a pianist andi would say $300-500 because of age. If it was brand new I would say $1000.
Jun 02, 2015 | Music
What is the year this Piano was made? Baldwin grand- Model Bi serial 301587
Made between 1940-1946
http://www.total-piano-care.com/baldwin-pianos.html
Mar 20, 2015 | Music
What year was my Baldwin Acrosonic piano built? Serial number is 337856. Thanks
Your piano was made in 1946. Here's a link to the age/serial number list
How Old Baldwin Piano World
Feb 11, 2015 | Music
Curious on the value on a Baldwin upright serial #1484454 style 2056A
I hope this helps. I can tell you that pianos age like people. How old is your Baldwin? Baldwins also are not made anymore, but I don't think that makes them particularly prized. Alot depends on its condition. I do not know to what the serial # and style # refer. If by upright you mean not a spinet or console, this type is usually found relatively inexpensively (<$1,000), especially if it is not a player piano. I would suggest that you take several good pictures of it to a local piano store for an estimate.
Jan 28, 2015 | Music
What is my Baldwin spinet serial #1003855 worth?
Baldwins from the 70s and 80s are a bit notorious for various mechanical (and tuning) problems. Most of them pianos were good, but they might have a few parts that were bad, so be aware that you'll need to tune it to sell it, and you may need to do some repair work.
Most prices are listed by model number, not serial number, so you'll need to figure out which model you have. I found a pricing guide, but I don't know how recent it is. There is contact information on the page that might help, though. Baldwin Piano Prices
Jul 19, 2014 | Scripophily.com D. H. Baldwin Company...
 Grubhead
Grubhead
