Question about Homelite Pressure Washer. Honda 2700 psi 2.4 GPM Gas Pressure Washer
Homelite gas pressure washer wont stay running
Starts but wont stay running cleaned carburetor only used 4 times
#1 Taper
  • 1041 Answers
SOURCE: Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Posted on Jun 02, 2009
  • 1810 Answers
SOURCE: I have a Homelite 26vt Mighty Lite that will only start when I du
you have 1 of 3 things wrong
1 you have pluged jets
2 you have a pluged fuel filter
3 you have a stuck float
4 fuel line is crimped
1 2 3 4 thats all it can be
preasurise the fuel tank by blowing into it when almost empty
this will as times clear jets
if fuel line kinked un twist it
best bet buy a rebuild kit for the carb and enjoy some time with a screw driver
Posted on Jul 27, 2009
SOURCE: carburetor adjustment for Homelite 2 cycle engine
I have the same problem with my MightyLite 26cc Blower/Vac. If it does start it runs rough on full choke and stalls on 1/2 choke or run. I've tried everything, fresh fuel, Seafoam, etc. Nothing works. First time I used it the exhaust burned a hole in my brand new Carhartt hooded sweatshirt. Best solution, throw it away, never buy another Homelite product and tell anyone who will listen what a piece of junk Homelite products are.
Posted on Oct 18, 2009
  • 2468 Answers
SOURCE: My homelite might lite 26b will run in the choke
if it seems low on power,remove the muffler and clean out all carbon build-up,if it has power as in full throttle,then the carb is still dirty and needs to be rebuilt
Posted on Mar 12, 2010
  • 21 Answers
SOURCE: Homelite model UT21566 string trimmer runs only on
Your carb high and low settings may need tweaking if it's not a fuel or muffler issue. I believe needles are made only to be adjusted by a technician. If you want to try adjusting it yourself, google and you tube your to see how.
Posted on May 08, 2010
New snapper will start but wont stay running this started to happen after I used contaminated gas
best thing to do is drain the gas and blow out the fuel lines. take the carburetor of and clean it real good with carburetor cleaner. there is something in the bowl interrupting fuel flow.
Mar 11, 2017 | Snapper Garden
Briggs and Stratton intek 900 Series 205cc It will starts but it wont stay running.
The usual cause for the problem you describe is related to fuel/
carburetion. Today's formulation of gasolines have a shelf life of only 4-6 months before they start gumming carburetor. Other forms of fuel contamination (dirt, water, etc) may also be the culprit. First step is to remove and thoroughly clean both the tank and carburetor. Reinstall. Install a small engine filter in the gas line when you reassemble. Use FRESH gasoline after you are ready to start your engine.
Oct 14, 2013 | Briggs AND Stratton Intek Briggs &...
My gas trimmer starts but wont stay running
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, !!
Feb 20, 2012 | Troy Bilt Tb70ss Gas Trimmer
I just purchased an 86 suzuki gs550l.Will not stay idleing after the choke is open.Even after it is warmed up. I thoroughly cleaned the carbs,checked for air leaks around intakes,cleaned and tested the...
I did a Suzuki 550 carburetor over haul 10 years ago and had 3 of the 4 intake manifolds crack or separate. I would start by closely inspecting the manifolds. Have you tried draining a carburetor bowl to see if it is full of gas? If the vacuum line to the fuel petcock is not hooked up correctly you could just have fuel starvation. You can hold a spark plug to a cylinder head and turn the motor over to see if you have spark. Correct amount of fuel, correct amount of air, and spark is what you need.
I just gave that answer to some one else. The fact is I had to remove and clean my carbs 4 times . Each time I did it, I got one more carb to idle. The last carb to work for me was the vacuum nipple carb. By the time I was done I had to replace all four manifolds they had all separated or cracked. To get my carburetors working I turned them upside down and shot through them with carburetor cleaner in the morning before work and in the evening after work. The reason it wont idle is the carburetor passageways are still plugged in the slow circuit. Carburetor cleaner , air pressure, and in my case time to get the blockage out of the bodies. When I was done it ran great.
Sep 21, 2010 | 1980 Suzuki Gs 550 L
Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Jun 06, 2010 | Mantis 2-Cycle Tiller
My lawn mower will start, but wont stay on. What ...
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this help
May 20, 2010 | Mtd 22" White Outdoor Self Propelled High...
Model no. 31as6fef729 544332 ser.no.11235B80204
This is a good time to remind everyone that you should not leave fuel in equipment that is not used on a very regular basis. More than likely your carburetor is gummed up from the old fuel. This can happen in less than 30 days much less 2 years.
To properly clean a carburetor you need to remove the carburetor and purchase the correct kit for the rebuild. Disassemble the
carburetor carefully making notes where each part goes. Once you have the carburetor disassembled clean it by soaking it in carburetor cleaner for a few hours. Use anned aerosol automotive carb spray cleaner to fill a small glass jar with enough cleaner to submerge the carburetor. Use a jar with a metal lid so you can gently agitate the solution occasionally to make the process more effective. You need to allow the carburetor to soak as long as it needs to remove all visible deposits. After the carburetor is cleaned allow it to dry and reassemble.
Sep 20, 2009 | Garden
4 cycle engine wont stay running when pulling it has fresh gas
First, check the fuel lines for cracks/breaks.
If they are o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit abd replace all appropriate parts.)
If you need further assistance, just let me know.
Jim
Jun 12, 2009 | Troy Bilt Tb70ss Gas Trimmer
Gv 250 wont stay running
read my solutions on this site for clogged carbs.....Tim
Jun 01, 2009 | 2002 Hyosung GV 250 Aquila
I would push the prime button 3 or 4 times it starts then quiet
I took my carburetor off and blew it out with compressed air. Runs great now. Make sure to get all of it. Little screw on bottom has a hole in it too!
Apr 18, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Homelite Pressure Washer. Honda 2700 psi 2.4 GPM Gas Pressure Washer Logo
548 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
