Question about Philips LaserMFD 6020 (LFF6020)
Dark vertical lines in scanned files and copies.
There seems to be a physical problem with the scanning function. It doesn't work as smoothly as it did before; it has become extremely noisy and there are long dark vertical lines in scanned files or copied pages. I don't know what has caused the problem (i.e. no accident!). I have tried calibration but it has not resolved the problem. Any idea (other than getting it to a repair shop)?
  • 476 Answers
SOURCE: Problems putting ANY videos on Philips GoGear SA6045
Install and run the Media Convertor software from the product CD and follow the on-screen prompts. This will convert the video file to a .WMV file of the correct resolution for the player, and allow you to transfer the video to the player.
If this doesn't work, check that the original video format is supported by the convertor software.
Posted on Feb 22, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: file format not supported
You have to change the Rip Options --> Format in Windows Media Player to Mp3, or else the files will transfer as a raw CDA, and the Philips will keep giving you this message.
Posted on Jan 15, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: i can't put songs in
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Mar 07, 2009
eddiepeezy
  • 130 Answers
SOURCE: Ihave a Philips 50PL9126D tv and I just replaced
Sounds like you may have the wrong lamp. Make sure you purchased a Philips lamp that's 100% compatible with your television model. Philips pioneered that lamp, so naturally they make 100 different types for DLPs and LCD projections.
You may have an elliptical lamp instead of parabolic. The lamp for your TV should read P22h.
Posted on Feb 04, 2010
  • 3 Answers
SOURCE: I have vertical lines my
No you are incorrect, it MAY be an indication of a bad LCD panel if the problem exist in the LCD internally. Does the issue occur on a different computer? If so, read on. There are external vertical and horizontal IC driver's respectively driving a RGB grid, notice how the line colors do not stay the same in relation to the background? You should check the ribbon cable(s) corresponding to the location of the vertical lines whether on the left, middle, and/or right side that typically travel from the bottom of the LCD and terminating to the vertical IC driver on the PCB. This COULD be the issue because I have a Cintiq 18SX interactive pen display that exhibited a related problem. One way to know for certain is to push gently on the bezel below the lines, if you see the color change or lines go away, that is most certainly your problem. You may push on the ribbon cable connectors firmly after disassembly, if symptoms completely disappear you can try hot gluing or any other non-permanent means to fasten the connector down using firm clamping force and/or replace the ribbon cables. Hope this helps, please keep me updated if it does!
Posted on May 05, 2011
Why is the photocopy and scanned document coming out dark and unreadable?
Hi there, my name is Lisa and I'd be happy to help you with your J6410. I understand your copies and scans appear dark and unreadable. Although you may not be seeing vertical bands, lines, or streaks through your scans and copies, I feel the following document might help you to troubleshoot the issue you have described:
HP Officejet Flatbed Scanner All in Ones With ADFs Vertical Bands Lines or...
Since the issue occurs when you perform both copy and scan tasks the issue is somehow related to the hardware and not to the software. Do you have the printer connected directly to a wall outlet or is it in a surge protector or power bar? Even if you have been using a surge protector/power bar all this time and you feel it is not the cause, please connect it to a wall outlet just so we can eliminate the power source as the root cause. Issues when Connected to an Uninterruptible Power Supply/Power Strip/Surge Protector In this document you will see, ISSUE: Problems or issues may arise when an HP LaserJet series printer is connected to an uninterruptible power supply (UPS), a power strip, or a surge protector
^ This is not limited to Laserjet printers.
If the issue persists, what you can do, is use the following link to create yourself a case number, then call and it may help speed up the call process:
Step 1. Open link: h22207 www2 hp com
Step 2. Enter Product number or select to auto detect
Step 3. Scroll down to "Still need help? Complete the form to select your contact options"
Step 4. Scroll down and click on: HP contact options - click on Get phone number
Case number and phone number appear.
I hope this helps.
I work on behalf of HP.
Jul 12, 2015 | HP Officejet J6410 All-in-one InkJet...
Vertical black line on scans or copies;
Hello James,
Please click Vertical Bands Lines or Streaks in Copies Faxes or Scans to access the troubleshooting steps that should resolve the issue.
Mar 03, 2014 | HP Officejet Pro L7680 All-In-One Printer
I have an HP Officejet 6500 wireless printer. If I scan or copy a document through the feeder the scanned or copied document has vertical lines from top to bottom. If I lay the document on the glass and...
Lift the scanner top, then look at the narrow pane of glass. There probably is a spek of dust or ink on it. Clean it with alcohol. I've had to remove the glass, due to the speck being on the undersaide of the glass.
Also, lift the ADF cover and clan the rollers with a damp cloth.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 17, 2011 | HP Officejet 6500 Wireless All-in-One...
My scanner copies have a vertical yellow streak covering half the page. What can I do to solve the problem ?
Lines or Banding Within the Image
If the scanner is generating lines or banding within the image during preview and/or scan, below is a list of possible solutions.
Horizontal Lines: If the lines run horizontally throughout the image, it is almost definitely interference of some kind. First thing to try is reverse the cable (Astra series only, except for 2400S), trying with and without termination as well. It could also be the SCSI card itself that is causing the interference. Try reseating it in a different slot, away from other cards. Try moving the scanner itself to another location, farther away from computer components such as monitors and CPUs. If none of that works, search for the file ?prescan.dib? on the hard disk and delete it, then try the scan again. If that still doesn?t work, follow the clean uninstall and safe mode install of our software. If these troubleshooting steps do not work, it could be a physical defect within the cable that?s generating extra interference, and the cable should be replaced. If the cable has been replaced already, it may be the UDS-IS11 itself generating the interference from being defective. Replace it.
Vertical Lines: If the lines run vertically throughout the image, it is probably a hardware problem, most likely with the scanner itself. However, follow the cable-reversing instructions above, remove the ?prescan.dib? file, and try the scan again. Often, if they are thin lines they are from dust within the optics. Open the case and blow out the dust with compressed air.
Nov 25, 2010 | Umax Astra 2100U Flatbed Scanner
A yellow vertical line on the copy, which now takes half the page.
What causes the lines in an image?
Dark, vertical stripe on copy on Sharp AR-M160
Have you cleaned the small, narrow glass window leftmost of the platen? It is directly above the scanning bar's "home" position, and that's where the document is scanned, while it's fed by the feeder, passing over the bar (the paper moves, as oposed to platen scanning, when the bar is moving and document remains still).
Feb 10, 2010 | Sharp AR-M160 Laser Printer
Very crisp vertical grey line appears (glass clean)
I have the exact same problem. It was there since I first bought the MFC-7840W.
Vertical line appears in scans using the automatic document feeder (ADF).
Vertical line does not appear when scanning single page (placing it directly on the glass -- i.e. not using the ADF).
Cleaning the glass strip for the ADF (or the white pressure bar overhead) does not solve the problem.
The problem does not occur with copies using the ADF (using the COPY button which is basically a scan and print). This would suggest that dust and dirt is not to blame because that would also appear on the copies.
But since I believe a copy is basically a scan plus print, they should be using the same electronics -- a hardware problem on the scan would likely appear on a copy also -- there is some difference between how they accomplish this.
It's definitely not a software issue since it occurs on all versions of Windows and Mac OS X (and multiple computers). It also does not matter whether I "push" the scan to the computer by using the scan button on the MFC... or "pull" the scan from the MFC using the Brother Control Center software.
Aug 12, 2009 | Office Equipment & Supplies
Black line while scanning and copying
Open up the document feeder and clean the scanner glass
Jan 25, 2009 | Brother Multi-Function Center MFC-240C...
Dell All in One Printer 962-dark vertical line on photo copies
If you are running your copies through the document feeder then see if the line goes away if you make a copy directly from the glass. If the line goes away then open up the doc feeder assy. by hinging it to the left. Underneath you will find that there is a thin strip of glass that the document passes over when it is scanned. Clean this strip of glass and this should correct your problem. If there is a smudge of dirt or small line, it will come out as a solid verticle line when scanned.
Jul 31, 2008 | Dell 924 All-in-One InkJet Printer
HP PSC 1610 - multiple lines in scans and copies, prints OK
Try a sky scan (No paper on glass and lid up) watch the scanner to see if it is smooth or a somepoint jumpy. If not smooth, you will have to open it up and 1 of two things, dirty and needs lubracation, silicone grease is best vasoline will work. OR 2 the drive belt is loose because the spring tensioner is broken or the belt is dammaged. Good luck
Aug 28, 2007 | HP PSC 1610 All-In-One InkJet Printer
Philips LaserMFD 6020 (LFF6020) Logo
24 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
