Question about SWANN Home Security
Camera reads only static
Only one of four cameras has this issue, the other 3 are working
  • 1,631 Answers
Either you have a bad connection between the camera and the DVR, check both the power wire and the video cable, you may have a bad DVR port, or your camera could be bad?
Posted on Mar 27, 2015
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 133 Answers
Try to configure it alone separated from the holl system
Posted on Mar 05, 2015
My Kodak Z1485IS will now not read the photos already on the memory card. What is the problem and how can it be rectified?
I've run into the same problem but I don't remember ever solving it.
I have a few things you can try though.
You could try another card in the camera first. Also try the card in another device making sure both are functional but my guess is it's the camera.
1.Plug the camera into your PC. 2. Go through Windows Explorer
to get the pictures off the camera. (If that doesn't work go to 3.).
3. Take the card out and plug it into what ever you can to get the pictures off the card. 4. Put the card back in and plug the camera into your PC. 5. Go through Windows Explorer to the camera and format the card.
I think I did all this to mine and was able to use the card in other things as well as getting my pictures but wasn't able to use it in the camera (or any other card) again.
These digital cameras are sensitive to bumps, drops and static electricity. Some more than others but I'm no pro, just determined.
Good luck.
May 03, 2017 | Kodak Cameras
SAMSUNG SMO-211QN SECURITY SYSTEM
1. Connect LAN cable of Cable/ADSL modem or Direct Fixed/Static IP LAN Line to WAN port of IP Router.or hub/sw with cable/lan terminal
2. Connect LAN ports of IP Router/switch/hub(1~4 or 1~8) to Ethernet port SMO-211QN/SMO-150QN to be set up and to
Ethernet port of Local PC to use during setup.
3. Connect Video cable of Camera to MONITOR.
4. Turn on the MONITOR power.
This a basic setup local no internet static ip you will have to
follow directions for setup in the software program you install
on the computer the uset the computer. The computer connected to the lan terminal
I am just giving you the basics you are goilng to have to read
and understand the rest as far as the rest of the setup on the
computer This is from page 107 of your manual
Link to manual if you dont have it
http://www.retrevo.com/s/SAMSUNG+SMO-211QN+users+manual+?sub.x=75&sub.y=14
Dec 07, 2007 | Samsung Color Indoor Security Camera with...
Why is my camera reading err sd when I insert sd card
I can think of a few possible issues:
1. SD card not formatted (format it in the camera)
2. SD card bad. try another one.
3. SD card bigger than camera can handle.
Sep 16, 2014 | Wildgame Innovations IR4c Digital Game...
Coolpix L110 Flash Issue: At the end of June my L110 flash wouldn't work. This was after a 4 inch slip from my hand to the table, but shouldn't have caused such a big issue. The flash wouldn't...
You will need to know how a flash works. Basically there is a circuit that increases the voltage to insane levels - 2000-5000 volts, store it in a huge capacitor storage, and discharges it over an inert xenon gas tube.
a knock may damage delicate parts, especially the storage and the gas tube.
Have you tried other shops? How about sending directly to Nikon USA? or their fleet of authorised repair shops?
http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
Sep 26, 2011 | Nikon Coolpix L110 Digital Camera
My pictures wont download from my Coolpix P80. Sometimes it works after a few attempts but sometimes it won't detect pictures at all.
Hi
The problem with you Nikon Coolpix P80 needs to be narrowed down as it could be down to few issues.
  1. Faulty USB Cable - Can only narrow this down by trying the other solutions below
  2. Faulty USB port on computer - try another port or another computer?
  3. Static build up on the USB port. Switch the computer off AND unplug it from the mains. Leave it like this for 30 minutes to allow any static to disipate.
  4. Corrupt memory card - If you have a card reader you could try and read the card from the reader. DO NOT FORMAT THE CARD IF YOU HAVE DATA ON IT YOU WISH TO RETRIEVE. If required you may need to format the card in a PC and then place it back into the camera and format it in the camera.
Hope the suggestions help.
David
Dec 29, 2010 | Nikon COOLPIX P80 Digital Camera
Lens goes in and out four times then ask to turn power off and on
Option 1:
Try Initializing the Camera as follow; Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera.
1. Touch the HOME and select the SETTINGS menu in the Camera.
2. Now, please select the MAIN settings menu.
3. Then select the INITIALIZE option under the MAIN Settings 1 menu.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
Option 3:
If the issue still persists then Service may requires to resolve it.
Aug 26, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Canon G9 camera and G7 similar problem... checked out memory cards and they were reformatted. cards work fine in other digital carmeras I own. Can not get either camera to read a memory card
Usually this means there is a problem with the memory card part in the camera that reads the card. When this happens it will usually say either memory card error or card locked, even when the card is fine. Try emailing this site for help with this: www.camerasandparts.com All they help with are the Canon Powershot cameras and they're excellent for help with these models. Good luck with it. They'd be the place that could help with this.
Dec 31, 2008 | Canon PowerShot G9 Digital Camera
Camera stopped working
Try taking the actual lcd screen of and put it back together.. Its 2 screws and you pull it out and then put it back in and re-assemble it. If you need a guide let me know.. IT might work or it might be an internal or software issue!
May 21, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Camera wont turn on even with new batteries
In order to narrow down the issue, I suggest you the following steps. 1) First of all we have to power drain the Camera. Take out the battries and unplug adaptor, now hold the power on putton ( Click Button) for a minute this will clear the static power on Camera. If this doesn't fix the issue, Than.... 2) As cam is working fine with Ac adaport and batterys are not working you have to check the cam with the new battries. If you store battries for a long time with out using them, they may result in battery drain. If this doesn't work. 3) Then it need a Physical check, where we can track if Power suply from battries are reaching till its destination or not. This is the way to narrow down the issue. Thanks you.
Apr 08, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
Memory card not reading in camera
look into the camera with a bright light and see if any pins are bent where the memory card goes in. also check to see if the card is unlocked and check the card to see if it works in another device.
Mar 06, 2007 | Canon PowerShot A75 Digital Camera
Home Security Logo
119 people viewed this question
Top SWANN Home Security Experts
Todd Arndt
Todd Arndt
gaucherre
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
