Question about Pyle PLDNV78I 7-Inch Double DIN Touchscreen LCD Monitor with
Pldnv78i operating system change
How to change the theme
Not able to active after reset pldnv78i
Not sure what connection method you have.. do you have USB driving the touch screen or all inclusive HDMI, or serial port... Anyhow, you need to check your drivers and remove and reinstall them. It is most likely a driver problem. Next check cabling if the touch screen is outside the video signal (non-HDMI modality).
Jan 29, 2014 | Pyle Pldnv78i 7-inch Double Din...
How can i change me themes in samsung corby 2 GT-S3850 Problem
To change the theme you will to go to SETTINGs>DISPLAY AND LIGHT>MY THEME. Hope this would help you.
Aug 12, 2011 | Computers & Internet
How to change icon into a regular icon on my laptop
Themes control the appearance of Windows XP, with themes you can change the desktop appearance, the look of icons, your screensaver, and have different sounds among other things.
Windows XP has some themes built-in, and you can also download themes from a variety of different places online.
below is the link , how to do it :
http://www.helpwithpcs.com/tipsandtricks/changing-theme-win-xp.htm
May 16, 2011 | Computers & Internet
Vista theme changes to windows classic upon restart
Are you wondering how to change the theme back to the "Vista Theme?" If so open "Theme Settings" by clicking the "Start" button, clicking "Control Panel," clicking "Appearance and Personalization," clicking "Personalization," and then clicking "Theme," then choose your desired theme.
If you've done this already, then you have a problem, usually when your appearance settings won't stay the way you want them to, and they keep revering to something else, it means that you have a virus on your machine.
To fix this you can try several things, try booting up in safe mode, and then restarting your computer.
You can reinstall Vista, by using the "Install discs" that came with your machine.
Hope this helps!
Sep 03, 2009 | Microsoft Windows Vista Ultimate Edition
I want to change my Windows XP theme to windows vista theme, so how can i change it?
Click on Start. Settings. Control Panel. Personalization. Theme.
Select the theme you would like, apply close.
Sincerely, Ryan Deschaine Systems Engineer Boxen Solutions LLC http://www.boxensolutions.com
Email address: ryan@boxensolutions.com
Office number: 262.432.3120
Mobile number: 262.364.6196
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
Jul 11, 2009 | Microsoft Windows Vista Ultimate Edition
Cannotchangetheme
rigt click on screen -personalize-theme,......if this doesn't work tell me
Feb 25, 2009 | Microsoft Windows Vista Ultimate Edition
I want dwonload vista theme . wt method of this
If you're an XP user seeking to transform the entire look and feel of
the operating system, i.e., themes, shell ext., GUI, sounds, boot,
logon, etc...........Go to this link.
If you already use Vista and you would like to change your existing
theme..........Go to this link.
Nate P.
Jan 28, 2009 | Microsoft Windows Vista Ultimate Edition
Vista theme working on xp
i have a thesme called luna tool simple easy fast like windows do u have aim or yaho msg
Oct 07, 2008 | Microsoft Windows Vista Ultimate Edition
Desktop Theme
ok go to safe mode with networking by tabbing the F8 key on the keyboard as soon as you push the power button to turn the system on then select safe mode with networjking and login as an administrator not with your username and then tryh to change the theme and reboot the system if does not work , then try to change the theme.Unistall spyware doctor and reinstall it later.Do not keep both avast and norton keep just norton.
May 28, 2008 | Microsoft Computers & Internet
Pyle PLDNV78I 7-Inch Double DIN Touchscreen LCD Monitor with Logo
Top Pyle Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Pyle Computer and Internet Expert? Answer questions, earn points and help others
