Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Replaced the lamp, 8 days later it`s out again.
I replaced the lamp and 8 days later during turn on it went out. now the tv powers up ,the fan comes on, the lamp turns on then it goes out and the lamp light turns red. sometimes it just wont even do all that instead the lamp light will turn red right away.when it does turn on the screen is flickering and the colors are way off.
any suggestions.
thanks
  • quadraporte Nov 19, 2007
    THANKS FOR THE REPLY, I ALREADY FIXED THE PROBLEM BY REPLACING THE CAPACITORS.
    BUT YOUR`E ABSOLUTELY RIGHT ON THE DIAGNOSIS.
  • ushco Nov 25, 2007
    Replaced lamp with new one and the Lamp indicator light still shows that I have a bad lamp.
You Have bad cap's on you power supply board causing the
5 volt line to go low. Call a service provider.
Posted on Nov 18, 2007
Lamp went bad so i replaced it.the picture is like new really looks good.2 weeks later the tv will not stay on for more than 10 mins.turn it back on stays on rest of the day.now it will not stay on for...
hi,
First You have to check the lamp cooling fan. if the fan didn't run at the correct RPM then the lamp will not get proper cooling and the lamp will get over heated. This will result in termal shutdown. And the tv will go to standby to prevent from burning the lamp. Just replace the fan. If the problem remains after replacing the fan then the problem is wiih lamp blasting circuit. If so you have to replase the lamp blast.
ok
Aug 07, 2011 | Mitsubishi WD-65735 Television
Our tv recently displayed projection lamp was about to go out and needed changed, so i purchased a new lamp assembly and replaced it. tv worked good as new for a few days, then in the middle of watching tv...
Most often, I find when servicing these televisions, the lamp has failed but it was due to poor fan circulation. This television has at least 3 if not 4 fans. If you take off the back and find these fans are filled with impacted dust, the fan may be causing the failure. Also check to be certain your door safety switch is making good contact. These tips should ber of assistance but check your fans. A clean inside of a tv is a happy tv!
Jul 11, 2011 | Sony Grand WEGA KDF55E2000 55" Projection...
Tv restarts while we're watching it
It sounds lamp is weak in tv and need to be replaced.
If lamp has not been replaced in last 2-3 years then replace it to get tv problem fixed.
Thanks.
Jun 07, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
The power went off at my house due to an overload and when the breaker was turned back on, the tv had no power, no green or orange light. I unplugged the power cord and plugged it in later and the tv...
The power supply board is dead,that the board where the power cord plug into it.Take ur tv aparts,replaced the power supply board,ur tv should work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 23, 2010 | Vizio L32 32 in. LCD HDTV
Sound went out, tv turned off, red light flashing...
The Lamp being bad as well as one of the three fans in the unit not turning could also cause the problem.
Hope this helps,
Skyassoc
Jul 23, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Lamp light blinks 3 times shuts down
The CLS problem. Im thinking that at least you made a visual inspection of the power suply and the capacitors around it. Then if everything normal in the area then the microdisplay (inside the ligth engine) can be damaged. (when the tv is working normally the microdisplay sends a pulse to turn on ballast and lamp finally.
The sweetkyman: when the fan is bad th tv shuts down imm. (if you unplug the fan when the tv is working normal the computer detects the overcurrent system works and shuts down the set) when a fan is all dirty and tons of dust on it the tv tends to work but after some hours the tv shuts down.
Dec 20, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
I have a mitsubishi WD-52525 DLP Tv; I replaced the lamp, powered on the system, I hear the fan go on, the green wait light goes solid after a few seconds and a few minutes later the lamp light goes solid...
Chances are the lamp is not bad. Is the lamp door reseated properly? The is an interlock on that door that must be activated in order for the set to turn on. If the unit was woking before the lamp went out this may be the problem
Nov 26, 2008 | Televison & Video
Mitsubishi WD62526 - Error/repair code
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
remove the back and lamp (make sure the lamp door is on) turn the tv on and look to see if the fan is running (keep you hand out of the tv when doing this - as the lamp connectors are empty) if the fan does not start - replace lamp - the connector is located under lamp housing connector JA - measure the red wire and ground (any metal part) for 12v at turn on - if 12v replace fan - if no 12v check the power pcb
Oct 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
