Toshiba 37" hdmi tv port 1 only port working
Hdmi port 1 to cable box is the only port working, ports 2,3,and 4 seem not to work to the dvd player, help?
  • 3,320 Answers
What else are you connecting?
Posted on Mar 27, 2014
SOURCE: HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Return set!
Akai Tv is not HDCP compatible. Nothing worked akai was not very helpful. This model , a 2006. aparently will not communicate will the newer HDMI devices.
RETURN SET IF POSSIBLE. NO SOLUTION FOR THIS PROBLEM!
Posted on Jan 04, 2008
SOURCE: Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Posted on Nov 20, 2008
  • 668 Answers
SOURCE: TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Posted on Jun 18, 2009
  • 12 Answers
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
Posted on Aug 28, 2009
  • 3741 Answers
SOURCE: I have a 37" Insignia
Try plugging hdmi cable into hdmi 1 on your TV, then open the menu on TV and find the place it lets you to make selections on this, such as Satellite or hdmi 1. One of these selections have to work.
does the hdmi port gets detected when you try in other hdmi ports.if not getting detected then it can also be fault in the hdmi ports.because as you said that hdmi port number 1 works.that means wires are proper.but other hdmi ports not working that means the ports are faulty if all the setting are proper in setup.
as the ports are soldered to the unit internally.if the soldering gets loose the connection will not get complete.so re-soldering is required to the loose ports.
if you are not familiar with doing this you can get it done by local repair technician familiar with this model .
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 16, 2009
Just bought a 55" Lg Led tv and i hook up hdmi from cable box to tv hdmi 1 and hdmi from my blue ray player to the tv hdmi 2, ok then i turn the input on both now hdmi 2 work but hdmi 1 has no signal why...
try connecting your blue ray player to HDMI 1.
A) If it works there, then you know the port on the TV is OK & the problem is with either your HDMI cable or your cable box.
B)If it still doesn't work then you may have a problem with the port on your MAIN PCB. if it's a new TV your warranty will cover that as long as the input connector is not physically broken.
Mar 08, 2015 | LG Televison & Video
How to hook up DVD player to 19' led HDTV
The modern way is to buy a HDMI Cable
Plug it in to the HDMI Port on back of DVD Player
Plug the other end into spare HDMI Port on LED TV.
Put in a DVD & hit Play
Use remote control to select HDMI port on LED TV
If it does not have a HDMI port then you need a converter box which picks up the Red & White (sound) & Yellow (viideo) and converts to HDMI standard.
Aug 13, 2014 | Televison & Video
I continue to have to switch my HDMI cable between 2 ports on my TV because initally there is "no signal". But when I switch ports I get a signal. So is this a HDMI cable issue, port issue or my Insignia...
My best bet would be a port issue - see if another device will work plugged into that port. (Some HDTVs have a HDMI port strictly for Service and nothing else but a Technicians specified cable will work in this port, look at the Manual) Check to see if your TV is set to the same port as your connecting to. One will be HDMI 1, next HDMI 2 and so on, the input button on remote should switch from port to port, make sure port setting on TV is same as #port your connected to.
Jun 17, 2010 | Insignia NS-BRDVD Blu-Ray Player
After installation of ps3 and blue -ray disc remote control. tried using remote to turn on and play a dvd dics to no avail nothing works the ps3 player nor the remote does't appear to recognize each other...
Ive had the same problem with mine. I have a universal remote and a blu ray player separately installed on my tv. The only way i was able to play the ps3 without calling geek squad to reconfigure my tv was to unplug the blu ray and put the ps3 in its spot and push watch bluray. It worked great.
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
Only one HDMI port on new receiver/dvd player
Chances are good that your panasonic would not support HDMI 1.3b firmware and you would loose audio or video anyway. If your Panasonic has digital inputs, ie. coaxial digital or optical, run audio to your receiver and HDMI direct from Cable box/ DVD/other source to TV. On the TV settings menu, turn the speakers "off". If you need further help, post a comment and I can help you more
Oct 14, 2009 | Audio Players & Recorders
No picture out of hdmi for ky hd
The first thing I would like you to check is the back of the HD box. There is a port that look similar to the HDMI port but its called SATA.
Just Double check that it is in the HDMI.
Once that we have established that the HDMI cable is correctly fitter both to the TV and the HD box. what I would like you to do is turn both box and Tv off. with them still connect to each other. Now what I would like you to do is turn your tv on first. Select the HDMI input you are going to be using. Then turn the power onto the box.
Hope this sort your problem out
Little Dish Fitter
Sep 06, 2009 | Toshiba 37WLT58 37 in. LCD TV
SONY Bravia KDL-40XBR4 HDMI problem
Ok i am assuming that when you switched the cables you only did so on the devices and not on the back of the tv. Am I correct on that? If so then you did not actually test the ports on the or the cables. It is cheaper to replace the cable than it is the port on the tv. I recommend taking each cable one at a time, ( remove the other cable completely during the test) hook up one cable to dvd player, then connect it to port 1 put tv on that channel and see if it works, now hook up that cable to port 2 while leaving it connected to the dvd player and change the channel and see if it works. now remove that cable completely and try the same steps with the other cable and compare the results. If it is a bad cable one cable will work on both ports and one will not work at all. If it is a bad port then both cables wil work on one port and not the other port. There is no need to use both boxes for this test due to the fact that in your original post you switched the boxes and a different one worked when you did.
Jun 10, 2017 | Sony Televison & Video
Toshiba hdmi ports not working
I talked to Toshiba about his problem, this morning. They said they have never hear of such an issue. I told them the TV was less than 1 week old, and would hope Toshiba would do something in response to my alternative action of returning both my Toshiba HD DVD and 52LX177 for a new brand. They said all they can do is have me go to a service center for them to repair it. 1 week old TV and DVD, $4000, for repair; I don't think so. I talked to two different people a Toshiba regarding this, with the same answer. Very poor customer support, especially for a higher end product like this. I think I have no choice but to change brands.
Nov 18, 2007 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
