Question about Mushkin Enhanced Ventura Pro 64GB USB 3.0 Flash Drive
Usb drive write protected
No access
  • Mushkin Master
  • 27,725 Answers
You have to be the computers administrator to change any values on any hard drive on your computer.
Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control.
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Posted on Jul 29, 2014
How can I password protect folders / files on my sandisk cruzer glide 128gb
Use the software that came installed on the drive. Use it to secure the whole disk. To access it you need to enter a password. Be careful though. The drive may not be accessible on Linux or Mac.
Mar 04, 2013 | SanDisk Cruzer Glide 128GB USB 2.0 USB...
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
Device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How do i remove the write protection from a genaric usb pen drive
hi
go to following link you will get your solution
http://techsalsa.com/solution-to-remove-write-protection-from-usb-pen-drive/
Dec 08, 2010 | Imation Defender F150 Flash Drive - 16 GB...
How to remove write protect on my usb flash drive
If you have a write-protected flash drive that you need to access, it can be difficult to change it to allow you access, especially if it is a security-optimized flash drive. However, there are a few practical steps you can take to change the write-protection on a flash drive.
#1
Check for a write-protection switch. This switch, when engaged, will lock the contents of the flash drive and is a very common security feature. It is generally located on the side of the flash drive, and has an "enabled" or "on" position, and an "off" position. Slide this into the "off" position.
#2
Override password security. If your flash drive has password security, but you have forgotten the code, you can try to override the security feature by going to the Start menu and selecting "Run." A dialogue box will pop up, into which you should type in the path to the file on the USB drive you want to access. Note: This only works on USB drives with very simple security. If the security is complex, this will not work.
#3
Format the flash drive. If nothing else works, you can always format your USB flash drive, which will set all your write protections back to default. From there, you can customize them however you want, but all your data will be lost. To format the flash drive, go to the My Computer, right-click your drive and select "Format." A status bar will pop up. Once the status bar disappears, you can change the write-protection settings on your flash drive without incident.
Hope this might help
Thanks
Oct 07, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
About write protection
access it from a linux live cd, or winpe mini cd, where the file autorun.inf or a usb manager programe is not loaded, u can access the drive copy the files to your hard drive, format the usb, and its all done.
linux live cd: puppy linux
May 12, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How do i remove write-protection from a flash drive?
Usually there is a tiny hardware switch, hidden on a side. Most USB keys do not have it, and some that do have it internally, unaccessible, and of course set to READ ALLOWED. If a hit moves it to READ ONLY, you'd need to pry open the key casing to access it.
Also, some "advertising" USB keys, presented to customers as 'electronic brochures', are filled with advertising material and the switch flipped (or soldered, in some cases) before the key is sealed. You can make these read/write with a judicious use of a paring knife.
Finally there are some more advanced keys with internal control software, allowing for encrypted storage, password protection, boot-from-usb and read protection. You need the manufacturer's USB driver or utility to be able to access these functions, though. The DaneElec zMate has a password protection utility (you'll find it on their website), but I have been unable to find it for your model. You may want to check yourself.
Apr 03, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Reg Removable disk
Click start click on computer to open you should your drives
C: usually your hard drive D: or E: your cd/dvd drives if you have 2 and your usb drive possibly E:or F:
Click on your usb drive right click in it select new folder option you can name it
Then put all files or data you want to password protect
Right click on the folder select properties then click sharing tab tick in make this folder private box
Another message might appear you do not have a password on this account click yes
User and password account will open for you to put in place a password
This might vary depending on your operating system in XP
Select properties then security tab at learn about access controls at the bottom of the box
Also another option to change permissions click edit
Then click deny then click apply in W7
or
http://download.cnet.com/%7Bvalue=http://www.download.com/usb-safeguard-free/3000-2092_4-75115673.html
USB Safeguard is a portable software program to encrypt and protect data with a password on your removable pen drives using the AES 256 bits encryption.
The main purpose of using a USB pen drive is that you can bring your data with you wherever you go. But if you lose your USB pen drive your data also lose.
This is dangerous if you have confidential files stored in it. Protect the pen drive with a password. USB Safeguard offers users (novice and expert) a friendly yet extremely powerful security solution that fully protects valuable data stored on USB pen drives.
Also, the program has a useful feature that allows you to enter your email or phone if you lose the pen drive. Free version works only with USB Flash drive of size max 2 GB
Aug 01, 2008 | Kingston Data Express DE110, S21P104...
USB
Write Protected USBs are protected by some software that provide passwords to get access to it. So that you wont be able to write anything on that drive.
Else,
or sometimes it is protected by the operating system itself that provides the USB Drive to writeprotect. that have some executable files in the pen drive.
Aug 01, 2008 | Microsoft Windows 98 for PC
Mushkin Enhanced Ventura Pro 64GB USB 3.0 Flash Drive Logo
664 people viewed this question
Top Mushkin Computers & Internet Experts
David Payne
David Payne
Are you a Mushkin Computer and Internet Expert? Answer questions, earn points and help others
