Question about Cisco 303 Ip Phone
No Response Cannot call out, does not ring on incoming calls, cannot retrieve voicemail.
I need to extend the length of time my phone rings on incoming calls
Hello, Mary -
I checked the user manual for your Alcatel 3003G cell phone:
https://www.manualslib.com/manual/1150047/Alcatel-Tribe-3003g.html?page=1#manual
I did not find any information regarding increasing the length of time of rings of incoming calls in the manual. So, I thought the incoming rings length of time may be dependent upon your cell phone service provider, Vodafone.
I found some information on a Vodafone Support page:
https://support.vodafone.co.uk/
How to increase the time before a call goes to voicemail?
(Quote)
Your Vodafone mobile is set to ring for 15 seconds before going to voicemail. You can change how long it rings for, choosing from 5 to 30 seconds in 5-second intervals.
To choose your desired ringing time:
  • Enter **61*121*11* on your Vodafone mobile
  • Choose the number of seconds you'd like your phone to ring for, followed by #
  • Press Call
  • A confirmation message will pop up on your screen with your new ring time
For example, if you want to set your Vodafone mobile to ring for 25 seconds, you enter **61*121*11*25#, and press Call. When the message pops up, you'll know it's all done.
Watch this simple video to find out how to increase the time before a call goes to voicemail.
https://youtu.be/rGJNpaaD5z8
(End quote)
Best wishes.
Apr 13, 2018 | Lands Phones
The phone does not ring for incoming calls, nothing indicates that I have an incoming call. However, if I check missed call and voicemail I can retrieve the call. Please Help
Go to phone settings then sounds and make sure your ringer volume is up and that you don't have a ringtone of Silent or off
Oct 07, 2016 | Cell Phones
Mobile phone,all incoming calls go to voicemail,without ringing
you did not provided what brand, model and year, therefore you need to read your manual...
you need to find in your setup section and enable calls, setup as to re-direct to voicemail after say 5 rings, enable ring.
unfortunately without model and year - more detailed directions cannot be provided...
Feb 08, 2015 | Cell Phones
Restore incoming call rings after power outage AVAYA
If you have a Backup & Restore card you can manually restore the system. If not you will have to restore everything by manually including voicemail greetings and automated attendants.
May 21, 2014 | Avaya Corded Phone avaparp18d
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Incoming calls goes to voicemail, then to receptionist. Also rings at three extensions at the same time.
It sounds like all the incoming calls are going to a hunt group. This would explain why three extensions ring, then it goes to the receptionist, and then ends up in voicemail.
Try looking for a hunt group that distributes to the three extensions in question, or that only has those 3 extensions active.
Dec 10, 2010 | Avaya 4610SW IP Phone
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Dec 01, 2010 | Panasonic KX-T7633 Corded Phone
Partner Plus 4.1 incoming calls problem
Voicemail is answering the calls. you need to program the system for voicemail and this will stop
Feb 02, 2010 | Avaya Computers & Internet
Incoming calls
i would got into your voicemail settings and check to see if you have it set to ring once then straight to vmail.. i'm not sure how your phone is set up completely but i would assume you can adjust the amount of rings before vmail picks up.. is this phone new to you?
hope this helps..
d
Feb 21, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Length of time phone rings with incoming calls
get your mailbox number then type in **61*44then mailbox mumber*11*then a two digit number between 00 and 30 (seconds delay).
Feb 19, 2008 | RIM BlackBerry 8800 Smartphone
Cisco 303 Ip Phone Logo
26 people viewed this question
Top Cisco Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cisco Audio Player and Recorder Expert? Answer questions, earn points and help others
