Question about Attachmate EXTRA! X-treme
Host machine check reset 501
Can't connect
How to fix error code 3501
if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
ENSURE YOU WAIT 10 SECONDS
1.
Turn OFF the main power switch. (Located inside machine) Leave control power switch in the on position.)
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Jun 14, 2016 | Konica Minolta Bizhub 501 Copier
Nokia 501 factory settings lock code
To reset your Nokia Asha 501: End all calls and connections. Select: Menu > Settings and Restore factory sett. > Settings only
Dec 03, 2013 | Cell Phones
Konica bizhub 501 take code c2806
actually code c28xx have 7 variant. for example, c2801, c2802, c2803 (error 3,4,5,6) and c2804. if follow the code code c28xx is TCR output abnormality.
ok, first you clean T/S block, do servicing and cleaning all parts.
second, if still same, do toner auto supply.
third, trouble reset. off your machine first, press and hold utility/counter and on machine, until trouble reset appear. press it and off/on again. ^^,
Oct 05, 2013 | Konica Minolta Bizhub 501 Copier
Popcorn machine stopped heating
Let it cool to see if the reset resets, if not, it is time to throw it away. There are no parts or repairs that can be done to that model.
Sep 13, 2013 | Nostalgia Electrics Mini Popcorn Popper...
My konica minolita bizhub 501 is showing the error code C3501. How do I fix this?
1.
2.Turn main power switch ON while pressing the Utility/Counter key.
3.Touch [Trouble Reset].
4.Check to make sure that [OK] is displayed and the it has been reset.
5.After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Oct 12, 2012 | Konica Minolta Bizhub 501 Copier
Fisher & paykel 501 smart drive washing machine
It does not seem like a problem of the unit. It might be a loose connection of supply code. Keep the supply code pressed to the unit in different directions and see if the unit takes power. If so, replace the supply code. It's not that expensive.
Jul 05, 2010 | Washing Machines
I got the error '' Unable to connect the printer , access denied , printer could not be started'' . I have a XP home m/c to which i have connected HP 1022 printer. I have shared it with all machines in the...
Are you on the same network as the host machine. In simple terms, the machine that you are trying to printer should be on the same network/domain.
click on start, right click on my computer and go to properties. Under properties check the computer name tab. specifically the workgroup. see if that matches the host machine. If it's different that's the issue.
If its different click on the button change, and type the domain in the box below.
hope this helps.
Feb 17, 2009 | HP LaserJet 1022 Printer
Computers & Internet Logo
492 people viewed this question
Top Attachmate Computers & Internet Experts
David Payne
David Payne
Are you an Attachmate Computer and Internet Expert? Answer questions, earn points and help others
