Question about Ahead Software Nero 7 Essentials Suite Full Version OEM
While burning the Video DVD i'm getting a problem 'MPEG-4 video decoding feature is missing' what to do for this kind of problem?
    Sergeant:
  • 193 Answers
Sounds like it was a bad install from the nero cd, uninstall and reinstall to see if it fixes the problem
Posted on Jun 15, 2009
Video'o are half screen
Click "Start," "All Programs" and double-click "Windows Movie Maker" to open the application. Click "Tools," "Options" to open the "Options" dialogue box. Click the "Compatibilty" tab and locate "Xvid MPEG-4 Video Decoder." Remove the check next to "Xvid MPEG-4 Video Decoder" and click "OK" to disable it.
Feb 02, 2013 | iMesh
Tip
How to do Blu-ray playback using Media Player Classic Homecinema
Media Player Classic Home Cinema is an extremely light-weight free program for Windows. It looks just like Windows Media Player v6.4, but has much more additional features. You can use it as a Media Player Classic Home Theater. MPC Homecinema supports a wide range of decoding formats and file formats, following are the details:
Supported Decoding:
MPEG-1, MPEG-2 and MPEG-4 playback. Media Player Classic is capable of VCD, SVCD and DVD playback, without the need to install any additional software or codecs.
It has built-in codecs for MPEG-2 video and codecs for LPCM, MP2, AC3 and DTS audio, and also contains an improved MPEG splitter that supports playback of VCDs and SVCDs using its VCD/SVCD/XCD Reader. A *.mp4 and MPEG-4 Timed Text support added. An AAC decoding filter makes MPC suitable for AAC playback in MP4.
MPC Home Cinema also has H.264 and VC-1 with DXVA support, DivX, Xvid, and Flash Video formats is available in MPC HC. MPC can also use the QuickTime and the RealPlayer architectures. Media Player Classic supports native playback of OGM and Matroska container formats.
Supported Video, Audio and Image File Formats:
WAV, WMA, MP3, OGG, SND, AU, AIF, AIFC, AIFF, MIDI, MPEG, MPG, MP2, VOB, AC3, DTS, ASX, M3U, PLS, WAX, ASF, WM, WMA, WMV, AVI, CDA, JPEG, JPG, GIF, PNG, BMP, D2V, MP4, SWF, MOV, QT, FLV
To make commercial Blu-ray movies playable with Media Player Classic Homecinema, one thing you have to do is using a blu ray disc ripper to remove copy protections before your playback. The following contents will give you the detailed steps.
Note:
If you are using a powerful PC, you can do the following "Directly Copy". When playback, MP Classic Homecinema will automatically download codecs as needed, so you are able to successfully play m2ts files directly copied from the BD disc, which have the same quality as the original.
1. Load Blu-ray files to Pavtube Blu-Ray Ripper
Three ways are available – "BD/DVD ROM", "BD/DVD Folder", and "IFO/ISO".
2. Select output format
Click on the dropdown list at the end of "Format", then follow "Copy">"Directly Copy".
Note:
If you are using a slower PC, we suggest you not to select "Directly Copy", because your slower PC will attempt to play the output m2ts files, but the sound does not keep up. So other formats supported by Media Player Classic Homecinema are recommended. To remain the high quality of a Blu-ray movie, you can choose "HD Video" as output format as below:
3. Click "Settings" button to adjust audio and video parameters
Note that this option is unavailable if you are using "Directly Copy". Generally speaking, the default settings are able to satisfy your needs basically, but if you have higher expectations of the output files, you can adjust all the following video and audio parameters according to your own requirements.
4. Click "Convert" button to start Blu-ray ripping
As soon as the ripping work is finished, you can get the output files for MPC Homecinema via tapping "Open" button. After that, you can import the files to MPC HC for playback. Have fun.
Additional Tips:
More than "Directly Copy" and format conversion, Pavtube Blu-Ray Ripper also supports "Full Disk Copy", which enables you to get a standard Blu-ray structure ready for burning.
on Apr 20, 2010 | Audio Players & Recorders
Tip
How to convert and burn any videos to DVD?
This guide helps you to convert and burn AVI/MPEG/DivX/Mov/RMVB and any videos to DVD:
Tools required: Cucusoft video to DVD converter
More information of dvd creator
resource:free dvd burner
Install and launch Cucusoft video to DVD converter pro, you will see the UI below.
1. Select radio button "To DVD"
2.choose the "merge" or "batch" tab.
3.Click "Open" button to open your movie file(s)
4. (optional) Set your preference. Region "4" in red frames can set the output MPEG properties.
5. (Optional) Set the advanced settings as following.
6. Click "Convert" button to start the conversion task
7. After you click "Convert" button, the following dialog will pop up automatically.
8. After video conversion done, the "CD/DVD Burning engine" will be launched automatically. Please choose the DVD burner.
9.Please place a DVD-/+R/RW disc into your DVD burner. If it is arewritable disc, the program will erase the disc before burning DVDdisc.
10. When burning DVD is done, the DVD disc will be ejectautomatically. You can also find the output file at the output folder.
on Feb 03, 2010 | Computers & Internet
I BOUGHT SONY DVD PLAYER MODEL VIDE DVP-SR650P.. WHICH TYPE OF VEDIO FORMATS CAN IT PLAY...
It can play mpeg-4 video and divx video.
If you want to know how to burn video to DVD to play on your DVD player, this burn DVD guide will help you a lot.
Aug 30, 2011 | Sony SCPH-10420 Remote Control
Why is the lap top telling me i need a decoder to watch a movie
DVDs are one of the most popular types of media sold today. They hold feature length motion pictures, videos, audio and countless other types of media such as software and data. DVD's not only can be played in stand alone DVD players, but also most computers have a DVD drive. If a DVD includes media such as a feature length motion picture, this media has been encoded and sometimes compressed. In order for this type of DVD to be played on a computer's DVD drive, the data on the DVD must first be decoded; this is done with computer software which are know as Decoder. It should be noted that there are many types of DVD formats, hence several types of encoder programs to make a DVD accessible to computer users.
DVD's encode data in a variety of ways. For instance Dolby Digital data requires a Dolby Digital decoder. The same is true with DTS (Digital Theater System). These are both audio data that require decoding, but many video images stored on a DVD also require decoding including
MPEG (this is the most popular video format for DVD's). It should be noted that in order to play a standard DVD, the DVD player is not enough, you also need the software to decode the images making the data fully functional.
Hope this Explanation will help you,,,,,,
Cheers!!!!!
Vivek
Dec 15, 2009 | Compaq Armada M700 Notebook
When I try to run my live tv I get a message that files needed to display video are missing or corrupt and it asks me to restart the Media Center. I did that but it did not resolve the issue.
I think this refers to the MPEG decoders required to show TV in media center.
You need to install Power DVD or a stand alone decoder from NVidia or ATI
May 13, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Trying to put I-DVD movie on my digital photo frame
Re-edit the movies and pictures following the formats below: Video:
File Format: MOV
Video Compression: MPEG-4 ASP, MJPEG
Audio Compression: MP3, G.711, PCM, ADPCM, 8-bit linear
File Format: AVI
File Format: MPG / MPEG
Video Compression: MPEG-1
Audio Compression: MPEG audio Picture:
File Format: JPG / JPEG
Video Compression: Baseline JPEG
Music:
File Format: MP3
Video Compression: PCM, ADPCM, MPEG 1 layer 1,2,3
Apr 02, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Ahead Software Nero 7 Essentials Suite Full Version OEM  Logo
Top Ahead Software Computers & Internet Experts
SHIVAJI YADAV
SHIVAJI YADAV
Lakshman P
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
