Question about Home
Adaptor Taylor dest top clock
How do I program Taylor in/out thermometer-clock and get outside temp to register? How do I program the clock?
Hit reset next to batteries to have it sync with outside temp sensor. Push mode button to scroll thru date, time. Use up and down button on back to adjust numbers.
Mar 03, 2015 | Taylor Measuring Tools & Sensors
How do I reset the clock on a Taylor 5846-9 kitchen timer?
Press the Mode button until you are on the clock.
Then press and hold the Start/Stop button for 3 seconds.
There should be a beep and the digits will begin to flash.
Press the Min button to increase the Hours and press the Sec button to increase the minutes.
When you have the time set, press the Start/Stop button to finalize the setting.
Nov 03, 2013 | Taylor Hardware & Accessories
How do I reset the clock on a Taylor timer 5891-21?
1. Press and hold the "Clock/Timer" button until you hear a beep and the time starts to flash.
2. Adjust the time using the "Hour" and "Minute" buttons. Note the clock includes AM/PM.
3. Tap the "Clock/Timer" button to restart the clock.
Nov 17, 2010 | Taylor Hardware & Accessories
How do i reset clock for the taylor clock timer 5851-21?
my Taylor 5851-21 has Hour Min Then under thatt Timer/Reset abd Start/Stop. How do I set the time. I know how to work the timer and reset the timer, but I need to set the clock. But it does not have a clock button label as you describe above.
Nov 20, 2009 | Taylor Hardware & Accessories
Reset timer between batches of cookies
click the Hr/+ and the Min/- keys at the same time...the timer will reset.
Apr 27, 2009 | Taylor Dual Event Mechanical Timer, 00521
Taylor thermograph clock drive
Do you still have this thermograph? Maybe we can make a deal here. I have one that has a different problem.
Will
Sep 18, 2008 | Audio Players & Recorders
Home Logo
24 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
